Question about Dual XDM6830 CD Player
Stored settings and auto eject
The last few days when I turn my Dual player on it automatically ejects whatever CD is loaded. The unit also keeps losing all the stored power on settings (volume, bass, treble etc) along with losing all stored radio stations. The auto's digital clock hasn't reset, so it isn't a simple disconnect of the car battery. No other electrical problems with the car itself that I'm aware of. I've tried reseating the removeable faceplate, but it shouldn't lose the above settings even when that's removed. It plays fine, but of course I have to manually find radio stations and set manually the bass, treble etc each time I turn it on. Help?
  • 1 more comment
  • Tom Remmiz Oct 17, 2007
    Probably correct, but I haven't been able to fix it yet. It's probably as simple as a loose connection between the Crutchfield wiring harness and the car's wiring. Hope to get to fixing it soon (if I can find the "keys" that allow one to extract the unit).
  • Tom Remmiz Oct 26, 2007
    Turned out to be a weak battery. Battery replaced. Problem gone.
  • Anonymous Mar 23, 2014
    bass treble bal and fade work radio wont change station
  • 709 Answers
Hi Factus, Ampman is right about the two power sources. I wish to add that the you should check to see that the yellow wire is powered. You may want to run another yellow wire from the 12V always on terminal on your fuse block to the radio. This will eliminate any possiblilty of a problem in the wire between the radio and power source. The Red wire is powered only when the key is turned on.
Posted on Sep 26, 2007
    Scholar:
  • 98 Answers
Hi. SOunds like another case of power problems. Your deck has 2 power wires. One is yellow th eother is red. One is constant 12 volt battery power, the other is a switched 12 volt power, only has power with the ignition key on or on accesory. Get yourself a test light. I almost bet you do not have the constant 12 volt power to the deck, therefore your deck cannot hold its presets...
SOURCE:
XDMA6438 CD Receiver
pls. unplug the unit then plug it again, turn power on, eject. just repeat this sequence until the cd tray will open.
Jun 22, 2013 | Dual Xdma6438
Nakamichi cd cassette player 1 not spinning discs
There's a Music Bank 7-disc player in use in my bedroom these days. Nice unit, but they used to come in for service once in a while- from what I could tell, these units don't 'park' the CD drawers on a soft power off- they simply shut down. When powered up again, they sometimes let the disc last in play slide off the tray & jam the machine. I've had no issues, as long as I always hit stop, wait for it to park, and then shut off. The analog output's sound has been very good (has a coax out as well).
Jul 28, 2012 | Nakamichi Audio Players & Recorders
Pioneer cdj 400 unit turns on, takes cd, cd spins and then just ejects it.
There are two reasons for this fault. The first one is with its disc loading mechanism. If the mechanism do not place the disc properly on to the reading chasis, this fault can be. It will spin for some time and will ejected automatically
The second one is with its optical pickup unit. If optical pickup unit do not read the disc; due to some fault to it [dust or dirt over the optical lens]. But in this case, there will be only "No Disc" display will be there. No automatic ejection will take place.
With your player, the first sated might be the case. The disc loading mechanism might need replacement.
May 29, 2012 | Pioneer Audio Players & Recorders
When i switch my teacpdh300 cd player on the drawer open and when i close it, it reopens
hi,
Check the tray loading belt of your cd player. If the loading belt is over sized then this problem can occur. Normally the loading belt will become over sized after a few years of use according to the weather condition. . If so the loading tray will not go inside fully and will not engage with close sensing switch. if so the it will open automatically without any external command .Normally in all players the loading belt will be under the loading tray near the frond side of the mechanism. check the same. keep the player in eject position remove power and then try to replace the belt.
ok
Jun 16, 2011 | Teac PD-H300 CD Player
It will not load cd or dvd it keeps coming up
The loading mech or poss. the read portion of the disc player is out of whac. In other words the cd dvd portion of your deck is defective and short of having it repaired by a techinition there isnt much you can do. Its a **** shoot but you may be able to unplug the unit let it set for a few minutes and plug it back in may rest the mech., but like I say its a **** shoot. Sounds like its time for a new deck or a trip to the repair center.
Jul 30, 2010 | Dual Electronics XDVD710 Car DVD Player
CD will not eject from unit.Word'IN' keeps
you can try either pushing the reset switch (which will be a small indentation either on the face or the subpanel behind the face) or disconnect power to the radio for a few seconds.
Nov 30, 2009 | Car Audio & Video
DN- S3500 Cd stuck
HI,
Please reset the unit for 4 hours by unplugging all the cords,even the power cord from the unit and then plug them back again after 4 hours.Now try ejecting the disc.Let me know the result.
Feb 10, 2009 | Denon DN-S3500
Stanton C303 wont eject CD
Remove the power completely replug and then quickly turn it on press eject emediatly..... this should work
Jan 01, 2009 | Stanton C-303 Single Top Loading CD Player...
Cd ejects
New CDs may have some rough spots around the inner and outer edges. If such a CD is used, this unit may reject the CD. To remove these rough spots, rub the edges with a pencil or ball-point pen, etc.
Nov 21, 2005 | JVC Arsenal KD-S6250 CD Player
Dual XDM6830 CD Player Logo
220 people viewed this question
Top Dual Car Audio & Video Experts
xxxxxx xxx
Mike Duncan
Mike Duncan
Are you a Dual Car Audio and Video Expert? Answer questions, earn points and help others
