I have a new roper washer model rtw4640yq1 that is not flushing the water out after the wash cycle. After it washes the lid lock light will come on and then it wont do any thing. what could be the problem?
3 Suggested Answers
SOURCE: My Affinity Front load washer, Model #ATF7000ES1
I am having this same exact issue, have you figured out what the was?
Posted on Sep 11, 2010
some1cares_m
  • 5323 Answers
SOURCE: Roper Washer Model RTW4640YQ1 cycle completes and before lid unlocks starts a new cycle. What is causing this to happen
control board?
Posted on Mar 29, 2015
Model RTW4640YQ1. How can I disassemble?
Go to www.repairclinic.com and enter RTW4640YQ1. You will be presented with a list of common replacement parts and may be able to view a general video that shows disassembly of a Roper machine.
Apr 23, 2016 | Roper Washing Machines
My Roper washing machine keeps filling and draining in the final rinse cycle.The lid lock light flashes and the machine will not complete the wash cycle, just keeps filling, spinning and draining!
Depending on your model, it will either have an electronic or mechanical timer. If electronic which it sounds like, you likely have a bad board or control unit. If mechanical you will need a new timer.
My old washer was mechanical and I had to replace the timer several times over 18 years. My new Samsung is all digital so when it goes bad, will have to diagnose the circuit that needs replacing. Normally there is an error code on the LCD readout.
Mar 20, 2016 | Roper Washing Machines
Roper washer new will not fill with warm water on rinse cycle it fills and spins
if its only a new machine make sure transport bolts have been removed
Apr 09, 2014 | Roper Washing Machines
Machine will fill and wash , but will not fill and rinse
AS YOU SHOULD KNOW KENMORE APPLIANCES MADE BY MANY DIFFERNT COMPANIES AND WITHOUT FULL MODELL NUMBER IT IS HARD TO SAY WHAT IS PROBLEM BUT COULD BE DOOR LOCK OR MAIN CONTROLL BOARD PROBLEM
Dec 09, 2013 | Sears Kenmore Elite 3.9 cu. ft. Front-Load...
My Roper washer will not spin on the spin cycle.
IF ITS A TOP LOADER YOU MAY HAVE A BROKEN LID SWITCH. LOOK DON THE HOLE IN THE TOP WHERE THE LID PIN GOES CAN YOU SEE THE LID SWITCH ARM? IF ITS NOT FLUSH WITH THE HOLE ITS BROKEN. SOMETIMES YOU CAN STICK SOMETHING THROUGH THE HOLE TO ACTIVATE IT
Jan 15, 2010 | Washing Machines
Roper washer stopped mid-cycle full of water
A washer that fills and doesn't do anything, or stops right after the wash cycle and then does not advance to the rinse cycle and drain is commonly caused by a lid switch malfunction. The lid switch is usually mounted under the washer top casing, on the right hand side on most top load models. It is activated by a plastic piece on the lid (called a "Lid Strike") through a small hole on the rim of the wash tub opening. In many cases the lid strike breaks off the lid, or the lid switch becomes loose and no longer makes contact. Inspect the lid to make sure the lid strike is still intact, and then inspect the mounting screws (adjacent to the small opening on the wash tub rim) and make sure they are snug. If you determine the switch to be defective, the following link explains how to replace one:
http://www.fixya.com/support/r385198-replacing_lid_switch
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price.
NOTE: You do not have to drain the washer to complete this repair. Once the lid switch is adjusted or replaced, the water will drain. This will save you time in having to bail water.
Jul 05, 2009 | Roper RAS8445KQ Top Load Washer
Washer fills with water then does nothing
If the switch requires replacement, a new one can be purchased on line at searspartsdirect.com, pcappliancerepair.com, repairclinic.com, appliancepartspros.com. Just use your model number as your search criteria. All these sites offer competitive pricing, so shop all them for the best price. If you still need assistance, please contact me and let me know. If my diagnosis is not correct, please post back and elaborate a bit more so I can assist you further. If your washer is not configured this way, or if you still have questions, please let me know.
May 26, 2009 | Roper RAS8445KQ Top Load Washer
Washing Machines Logo
22 people viewed this question
Top Washing Machines Experts
