Question about Craftsman Sears Chain Saw Manuals Model 358.351061
Replacing fuel lines on sears model 358.351061 chainsaw forget routing anyone have schematic?
2 Suggested Answers
  • 1169 Answers
SOURCE: craftsman chainsaw model 358-350260 routing gas lines
See if this helps.
Posted on Nov 27, 2014
Replaced fuel lines,vent line is my major problem!
Make and model please.?
Where is the fuel leaking from exactly?
Generally you don't get diagrams od fueling routes. They often go via the most direct route from tank to carb/primer
May 26, 2016 | Garden
Sears model 358.350270 fuel line replacement
Sears is pretty good about getting you the information you need. Go to the Sears lawn a garden area for help.
Nov 07, 2013 | Craftsman Sears Chain Saw Manuals Model...
Need to replace fuel lines that is rotten
Hi randy waldrop...
Here is the fuel routing for chain saws
Please rate me
Bud
Sep 29, 2012 | Craftsman Sears Chain Saw Manuals Model...
Need diagram of fuel lines from tank to primer bulb and carburator on a Poland chainsaw model 1950 wood shark
There are 7 different types of the 1950 model (types 1 - 7) and it came with one of these 2 carbs Walbro or Zama. The carbs are different as are the fuel line connections for each one.
Although this video is for the promer bulb you can see the routing of the fuel lines.
http://www.ereplacementparts.com/article/4262/How_to_Replace_a_Primer_Bulb.html
You will have one line from the fuel tank connecting to primer bulb the 2nd line going to the carb. If you connect it backward it does not pump fuel into the carb.
Kelly
(FYI Types 1 - 5 all have the same fuel line routing.)
Apr 12, 2011 | Poulan Pro 14" Gas Chainsaw 33CC P3314
Routings of fuel line to Poulan 14 inch chainsaw Model 2025
No drawings or pix, but will try for description--the line from the tank that has the fuel filter is the main fuel source which goes to the upper connection on the carburetor. The lower carburetor connection goes to the intake side of the primer bulb, and the outlet side of the primer goes back into the tank, which has no filter inside the tank. The main problem is determining the correct primer port to connect back to the carburetor. When everything is connected, try priming the carburetor. If fuel fills the bulb, you have everything connected correctly. If nothing happens, try switching the two primer port connections and try to pump fuel again. If still nothing, hook the main supply line from the carburetor over to one of the primer ports and try for fuel again--if still nothing, switch the main supply line to the other primer port and pump again. If still nothing, check for a plugged fuel filter in the tank. If the filter was plugged, then go through the previous procedure again. Make sure to replace the fuel lines with original rubber lines, not plastic. Hope this helps!
Jul 13, 2010 | Poulan 14" Chainsaw
Replacing gas line
Your fuel lines are routed like the schematic below. I suggest you replace the filter, all hoses (2 different sizes), and the purge button (bleeder).
http://www.fixya.com/support/r3706813-2_cycle_fuel_system_repair
May 07, 2010 | Poulan ES350 16" Chain Saw
Sears model 358.356280 chainsaw. Just replaced
Sounds like you need to pull out the spark plug and put some fuel directly into the cylinder to get it fired up.
Nov 14, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
My McCulloch chainsaw 3200 internal fuel line in
Try your friendly neighborhood chainsaw seller/mechanic. Take a piece of the old hose with you.
Fuel Line Replacement
SmallEng.com
http://www.youtube.com/watch?v=JrXpU70Hmi0
Routing runs from fuel tank to carburetor, (if equipped) through carburetor to primer bulb, bulb returns excess to fuel tank.
Oct 13, 2009 | Garden
Craftsman Sears Chain Saw Manuals Model 358.351061 Logo
590 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Dean Gruber
Roland W VanLue
Roland W VanLue
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
