Question about Sewing Machines
Calibrate the embroidery arm for the Designer SE
dupina
  • 110 Answers
SOURCE: embroidery stick
You need the USB Manager software to view the files. Have a look at all the software that were supplied with the machine. Load the embroidery software on your laptop and then open the USB manager.
When it opens it will show a light blue screen and grey icons to the left. Click in "disk", then click on "read disk" and you should be able to see your designs. The grey icons will turn orange were designs are stored, and the grey ones indicate empty space for more designs.
Enjoy your fantastic machine
Posted on Dec 18, 2007
SOURCE: viking designer se limited
You can find this information by touching the configuration icon (this looks like pliers). The item that shows you how many sewing hours is called Timer. You should know that this can be reset to 0 by anyone.
Posted on Dec 29, 2008
kent581
  • 87 Answers
SOURCE: Designer 1 touch screen freezes
Static Electricity and Designer 1:
The designer 1 is susceptible to static electricity. They sell static removers for electronics. Try that 1st. Don’t spray your machine, just the rag and wipe the machine. Endust for electronics makes a pump spray and you can even use it on the screen (DONT spray the screen). Then try to recalibrate the screen in the set menu. If you can’t get into the set menu keep trying until you can otherwise, there is a way to get into the service mode to set it.
Posted on Mar 18, 2009
  • 192 Answers
SOURCE: cant get rid of message
I think that you need to have an authorized Husqvarna Viking repair center look at your machine.
The only thing that I can think of that you can do is place your left hand on the embroidery arm that moves left and right. Put your thumb into the opening where the hoop holder comes out and lift the cover slightly. I have seen the cover get pushed down too far so that the sensor inside is not able to move when the hoop is removed so the machine thinks it is still there. Look at the end of this opening in the arm that is closest to your stomach to see if it looks as if the cover is pushed down too far.
Beyond that, several things could be causing this problem, only one or two being serious. Most are simple.
Posted on Apr 09, 2009
  • 201 Answers
SOURCE: Husqvarna Viking Designer I breaking needles
Dls8864's suggestion was a very good suggestion - make sure the metal stitch plate is pushed all the way to the back. Also make sure that the thread is feeding freely - if it is catching on something it can cause the needle to be pulled aside and make it break. Does the design fit properly inside the hoop you are using? If the foot and/or needle strike against the side of the hoop, that will cause a breakage. Is the bobbin thread okay - not making a bird's nest underneath?
Posted on Feb 01, 2010
How do I take off the arm
On the embroidery unit or regular unit? I have a designer
both comes off easy
Jan 28, 2015 | Husqvarna Viking 1
Embroidery Arm is not moving right/left
Check to notice if when the embroidery arm is installed and you turn the power on does the embroidery unit move as it calibrates the stepper motors. If not I would first check the plug where the machine and embroidery unit attach. If this looks ok and is not out of place it could be a cable, or the main circuit board. Both of those are for your dealer to repair.
Feb 08, 2014 | Husqvarna Sewing Machines
My Husqvarna designer SE embroidery unit keeps giving an error message "install hoop correctly". I've checked everything but can't get around the message. can anybody help ,?
You have probably got the machine set to use a different size hoop. Click on the hoop icon and change it to the size you are using. Hope this helps you.
Aug 04, 2013 | Husqvarna Sewing Machines
Recently during an embroidery the needle started "fixing" very rapidly and wouldn't stop. Had to unplug it. Now designs will load to the point where I touch them choose the one I want. The...
Make sure the embroidery unit is plugged in securely. If it is only a tiny bit out of its socket, the machine will behave erratically. Also ALWAYS "park" the embroidery arm before removing it by pressing the Needle Down button. Do this before you turn the power off when you are done embroidering. If the arm is not in the correct position when you plug it in (i.e. has NOT been parked) then it won't calibrate properly. I believe you can manually move the arm into the parked position. It's not something I would want to do myself but if you are really stuck it might be worth trying. You need to exert quite a bit of force. Also be sure to remove any hoops before you "park" and remove the embroidery unit.
Can you access the Menus properly when the embroidery unit is not on the machine? If you can, recalibrate the touch screen by going to the Set menu, scrolling through the "More" pages until you find "Calibrate Touch Screen Adjust". Use your stylus or the blunt end of a machine needle to touch exactly in the centre of the crosses, starting at No.1. It will turn green then do No.2 and exit the screen (OK) without touching anything else.
If you can make the machine work, try doing a different embroidery - there may be a problem with that particular one. If you cannot get it to work properly, it will need to be seen by a repair technician, sorry.
Jan 16, 2011 | Husqvarna Designer I
Viking designer se screen is stuck in welcome screen when turned on. update did not help me! my steps: 1turn on Designer SE le and connect to computer. 2install Designer SE 3D embroidery Software...
I purchased my designer se in 2006, and the frozen screen happened for the first time tonight as I was installing fonts on the machine. I did as suggested...got into update mode and installed the latest update and it worked! Thanks so much. I thought I would have to pay a lot of money to have the problem resolved. I am a happy DSE owner.
Dec 04, 2010 | Husqvarna Designer I
I bought a new embroidery unit for my designer 1 when I but it on it makes e terible noise and says to slide of hoop and clear position for i . embroidery position'But it won't go into embroidery...
Don't know for sure what is happening, but you should not put on a hoop until you are actually ready to embroider. The unit goes on while the machine is turned off; turn on the machine; it will make a noise; you should get a pop-up on your screen to Calibrate the unit. Touch this button, and the arm moves into position ready. Load your design and choose the correct hoop then put the hoop and project on the machine. Also be sure that your design will fit in the hoop selected.
Sep 01, 2010 | Husqvarna Designer I
On 955E embroidery unit, the large black gear snapped
Welcome to FixYa. Hi - Viking has online tutorials for several of the 955E features, including embroidery.
Here is a link to the 955E tutorials. If the link isn't active, paste it into your brower window.
http://www.husqvarnaviking.com/us/6616_393.htm
As mentioned in the next paragraph, you can order a manual from your Viking dealer if you don't have yours. The Viking manuals aren't very expensive, and it is well worth having. You'll find detailed instructions for inserting and calibrating the embroidery arm, which happens everytime you insert the emb arm. See the Hints and Tips paragraph below.
If your machine is broken, the 955E Parts manual lists each part number in the machine, and the 955E Service Manual should provide instructions for repair. But because the 955E is not discontinued (as far as I know), the dealer might not be willing to sell you those manuals or order the parts you need. eBay often has Parts and Service manuals for sale for current model Viking machines, or you might be able to find them for sale on other web sites. Keep in mind that if your machine is still under warrantly, you risk voiding the warranty if you attempt to remove the covers and perform a "non-consumer" repair.
Some general hints and tips for inserting and removeing your embroiodery arm and navigating the Viking web site:
  • Always turn your machine off when you attach or remove your embroidery arm or when you insert or remove an embroidery design card.
  • When you insert your embroidery arm, insert an embroidery design card. When you turn your machine back on, you should see a message on the info screen that says something like "embroidery arm will move". Press OK, and the embroidery arm will calibrate.
  • After the embroidery arm has calibrated, place your hoop on the embroidery arm.
  • Look at each end of your embroidery arm - you will find a connector that must slip into a corresponding connector on the embroidery machine. This connector slides into a corresponding connector on the machine. The connector on the machine has a cover that slides open and closed. If it is closed, it you might not spot it right away. You must open this slot when you attach the embroidery arm - slide the embroidery arm straight back (not at an angle), so the embroidery arm connects to the machine securely. Although you might need to nudge the embroidery arm in place, do not force it!
If you or other viewers have a minute to rate my response (good or bad), your rating will help me to determine whether I unserstand your question and provided useful information. These ratings help me provide better service.
If you have additional questions or more information to add about your situation, please feel free to comment.
Cheers,' Ginny
Feb 10, 2009 | Husqvarna Designer I
Trouble with Viking 955E Embroidery Unit and Control Panel
Here is a link to the 955E tutorials:
Some general hints and tips:
The Viking site also has projects for the 955E that will help you learn to use some of the features - you can probably sew most or all of the free projects on the site, but projects for the 955E incorporate features on your machine that might be available on others. And look for the free designs!
Hope this helps get you started.  If you and other readers have a minute to rate this information (good or bad, or indifferent), your rating will help me determine if I understood your question and if my answer is helpful.
A few more recommendations...You can order a manual for your machine from any Viking dealer and probably online, and I recommend that you do. Your machine has some very cool sewing and embroidery features. I sold Vikings, so I can answer specific questions about many individual features, but Viking manuals are not expensive and can help you save time and avoid irritating problems.
If you have more questions, please comment and I will do my best to help you further. I am pleased to answer general questions about embroidery, if you want hints and tips or run into problems.
Cheers, Ginny
Jan 16, 2009 | Husqvarna Designer I
Embroidery unit
Do you have a hoop already on when you first re-calibrate the embroidery arm? You need the embroidery arm ONLY when you first turn on. Don't put the hoop on until you are ready to start embroidering. If this is not the problem, try re-loading the machine operating system. If you did not save your floppy or USB file, go to Husqvarna website and download the latest one, and re-load it. (Be sure to select the correct file for your particular machine i.e. floppy or USB.)
Pamsquilt
Aug 10, 2008 | Husqvarna Designer I
Husqvarna Des 1.. won't recognize hoops
The embroidery unit needs to be calibrated. Can only been done by a trained dealer. you can relax, it is not a major issue and shuold not cost you a arm and a leg. Ask the dealer to also calibrate your touch screen and download the working hours on your machine.
Regards
dupina
Dec 11, 2007 | Husqvarna Designer I
Sewing Machines Logo
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
