Question about Apex Digital GB5108 51" Rear Projection EDTV-Ready Television
How do i reset my tv - Apex Digital GB5108 51" Rear Projection EDTV-Ready Television
How to reset Seki tv when it goes off and will not come back on
Seiki hard reset tv factory settings Flat Panel Televisions ...
www.fixya.com > ... > Flat Panel Televisions
Seiki flat panel televisions hard reset tv factory settings related questions and answers. Ask your Seiki questions. Get free help from flat panel television experts.
How to reset a seiki hd tv that keep reading no signal? - The ...
www.askmefast.com > Family & Relationships > Singles & Dating > Signal
To reset your seiki hd tv you just need to press on the menu: 0000 The TV will ....Getting to factory settings seiki tv ..... "How to reset seiki tv that reads no signal?
FAQ's ' seiki
Dec 19, 2015 | Seiki Televison & Video
Lg 42px-4dv/ea sustain pcb fails after 6 hrs running.
Try hard resetting;
NOTE:
Some TVs have a reset button. If available and accessible, try using the reset buttons before using the steps below. Using the reset buttons can save time.
Figure 1: Example of the reset button labeling on the LC2600N
1. Unplug the TV power cord from the power outlet.
2. Unplug any connected devices (DVD, Set-top boxes, etc...)
3. Press and hold the TV power button for five seconds.
4. Plug the TV power cord back into the power outlet and turn on the TV.
5. Open the on-screen menu to confirm that the TV is responding again.
6. Turn off the TV and reconnect the devices.
7. Turn on the TV.
Jul 21, 2008 | Televison & Video
Where is the reset button
Sanyo Service Menu - Factory-Reset.com
factory-reset.com/wiki/Sanyo_Service_Menu
Jump to Sanyo TV Service Menu Method 2 - Unplug the power cable. Press and hold the {VOL -} button on the TV while plugging the power cable back ...
Sanyo TV reset button location? ' Yahoo Answers
https://answers.yahoo.com/question/index?qid...
Jul 27, 2007 - Does anyone know where to find the reset button on a 32" Sanyo TV? The thing is just totally dead and I am thinking maybe if I push the reset it ... I have a Sanyo TV, I accidentally hit the reset button twice. I ...
Aug 6, 2012
36 inch sanyo tv won't change off video 2?
Apr 17, 2010
I accidentally hit the 'reset' button the remote of my sanyo tv ...
Jan 6, 2010
Sanyo DS32224 TV Problem!!?
May 21, 2009
More results from answers.yahoo.com
Nov 29, 2015 | Sanyo DS31520 31" TV
How do I reset my LG 55"UHD LED LCD 100Hz Model No 55UBB850t TV. When tv was initialy set up we said yes to set top box accidentally but we don't have one. I have TV running through Austar but we ha
http://www.lg.com/us/search/srch_manuals-tab?customerModelCode=55UB8500&mobileFlag=N#
Restoring the Default Settings
mr14_home.png ">w14_settings.png ">General > Reset to Initial Settings
Delete all the TV settings data and reset the TV. All the options in the Settings Menu will be reset to the default settings.
After reset, the TV will automatically turn off and on.
Type the password to Reset to Initial Settings
Do not turn off the power during initialization.
Jan 04, 2015 | LG 55" Black UHD 4K LED 3D Smart HDTV With...
Dull green screen
reset the TV and fix it. God bless you
  • Reset component settings. Usually, the problems you encounter with a projection TV may be resolved through the resetting to its factory settings. If you experience inaccuracies in the color, reset the television's PerfectTint/PerfectColor capabilities. Simply press the Menu tab and then highlight "Perfect Color" using your right key arrow. After this, press "Enter" and then "Reset" in order to reset to factory settings. If you have audio / video problems (VCR or DVD player), simply press "Menu" and highlight the "Reset" option.
Reset television controls. In case you cannot fix your TV via its component settings, there are other ways of resetting. Just select "Menu", key in "1, 2, 3", and then press "Enter." In doing this, the TV's manufacturer's specifications will all be restored. If your TV's power system does not function, you should perform a complete system reset. You can do this by clicking on Reset System button located at the TV's control panel. Your television will be turned off and then a green light (LED) will quickly flash for approximately one minute. Once the light has stopped flashing, your TV should immediately turn on.
Jul 30, 2013 | Philips 51PP9910 51" Rear Projection HDTV
How do i reset a sony wega kdf55wf655 tv?
Hello
To reset this set to its factory settings:
Press when in a Menu, to reset the settings to the factory defaults. Also user to clear Labels, Channels or Favourite Channels.
To reset the TV fully to its Factory Defaults:
Turn ON the TV while Holding Down the "RESET" button on the remote control, Press the POWER button on the TV. The TV will turn itself OFF, then back ON again. Release the RESET button. OK.
Oct 08, 2011 | Televison & Video
Sony kp-65wv600 projection tv error code. My tv blinks 7 times.
The Standby LED blinks when the TV is turned on, then shuts off when the picture is displayed. If the LED blinks continuously, this may indicate that the TV requires service. Before getting the TV serviced, try power resetting the TV and factory resetting. Try the below steps also: Connect the TV to a different wall outlet and check if it helps. This is to check if the issue is with the Power. Disconnect the TV from the Power Strip or the Surge Protector and connect it directly to the Wall outlet and check if it helps. To Power Reset the TV, disconnect the Power cord for a short period of time (approximately 1 minute). Then, reconnect the Power cord and power ON the TV. To factory reset the TV, turn it ON. Then while holding down the RESET button on the Remote Control, press the Power button on the TV front panel. The TV will turn OFF and then turn ON again. Then release the RESET button to complete the reset procedure. If the issue persists, service may be required.
Good Luck!!
Nov 09, 2010 | Sony KP-65WV600 65" Rear Projection...
The blinking green lite that wont go off wont allow the tv to come on tv must be reset each time sometime reset works and sometime tv off for days have to unplug from wall for couple days then replug and...
The blinking green lite that wont go off wont allow the tv to come on. We tried resetting the tv it doesn't work Also the tv has been off for days have to unplug from wall for couple days then replug and reset. It still doesn't work. Please help.
Sep 25, 2009 | Televison & Video
MIT WD-62525 DLP TV blinking green light on front won't stop
Hi!
It means your TV needs to reset. Although you have reset it previously, now again reset the TV as per procedure given below:
Please press the SYSTEM RESET button on the front panel with a pointed item such as the point of a ball point pen or end tip of a paperclip.
The TV will turn off and the green LED will flash quickly for about one minute. After the green LED stops flashing, turn on the TV again. The changes you made while the TV was most recently on, before you used the SYSTEM RESET button, may be lost; the changes you made previously, however, are not lost. Only those changes since the last power on may be lost when the system reset button is pressed. All other settings are retained.
TV Reset Menu
Read on-screen warnings before proceeding, as some user data or settings may be erased.
1. Press TV MENU and then 1, 2, 3 to see the RESET SERVICE MENU to reset the TV.
2. Select Reset System Defaults (CAUTION: All settings, except V-Chip, will be reset to the original factory defaults.
Please do rate this solution as FixYa and revert for further assistance.
Thanks
Rylee
Jun 20, 2009 | Mitsubishi WD-52525 52" Rear Projection...
Apex Digital GB5108 51" Rear Projection EDTV-Ready Television Logo
Top Apex Digital Televison & Video Experts
Jaime Hernandez
Electro Med Services...
Are you an Apex Digital Televison and Video Expert? Answer questions, earn points and help others
