Question about Panasonic ToughBook 18 PC Notebook
Keyboard problem keyboard on my cf-18 touchbook dont responds as i want. d and shift activates by itself. need to replace the key board by my self can any one provide me how to dismattle my cf-17 loptop.
Cat sat on keyboard. not a limerick... keyboard slow to respond with arrows and typing. Also light on top LHS under '1'... what is that ?
Hold down the shift button for a few seconds to disable sticky keys. This is a windows feature to help people with disabilities and is activated and disabled by holding the shift button down for a few seconds. You can also disable it under start menu/programs/accessories/accessibility
Jan 22, 2015 | HP Compaq nx9030 Notebook
Forward slash on panasonic toughbook
It sounds like you have a ToughBook with a NON-US Keyboard or keyboard layout. The physical "SLASH" key is the last key on the bottom row above the SPACEBAR row.
It is the key on the FAR right side just to the left of the right-side
SHIFT key. Make sure in the taskbar that the EN sign is shown
(on the bottom right side of the screen next to the date/time.
If it is shown FR or ES then your keyboard is in French or Spanish.
You can try to use the ALT+SHIFT key combination to toggle
the FR or ES back to EN (English). If not, then you must
ADD the English keyboard in the Control Panel under
Regional Settings (Clock, Language and Region in Windows 7).
Under Keyboards Click "keyboard" then Click "add" then
choose English (United States), Keyboard then US (only).
That is it. Make sure you select US as "Default" and then you
won't have to go thru all this ever again.
Good Luck!
Regards,
Richard - Montreal Based
Panasonic Canada Toughbook Authorized Dealer since 1989.
Apr 28, 2014 | Panasonic TOUGHBOOK CF-18 Tablet PC
Shift keys dont work
If it's just the one shift key messing up it may be dirty. Pick up a can of Air-dust and blow out the key board and all around the "shift" key....also look to see if anything is spilled on it too....this can be fixed with isopropyl alcohol and compressed air. if this don't work then you need a new keyboard.
May 27, 2011 | Compaq Keyboard
Panasonic toughbook cf 18
You will, at the very least, need to have the screen and screen cover replaced. If the hinges also damaged the bottom case to which they are attached, then it too will need replacing.
If you can't get it repaired locally, let me know.
Jan 09, 2010 | Panasonic TOUGHBOOK CF-18 Tablet PC
I have a Panasonic Toughbook CF-18. The keyboard
Connect an external keyboard to your laptop. If the external keyboard works properly that means the keyboard of your laptop is defective and you have to replace it. If you get the same problem with the external keyboard reinstall your operating system (it could be a virus).
Oct 08, 2009 | Panasonic CF18DJAMXKM Notebook
Need to disassemble
to remove the keyboard on the cf-18 keyboard you must remove the 4 screwsby the ESC, F4, F10, and PAUSE key. once removed lift the 2 covers and holding the keyboard from Function key sides lift up slowly. There are 4 sticky tapes holding the keyboard, once some of the tapes are off you can slide the keyboard up towards the LCD to remove. The connector to the keyboard can be removed by removing 3 screws from the aluminum center cover found under the keyboard
Jul 17, 2009 | Panasonic TOUGHBOOK CF-18 Tablet PC
Panasonic touchbook cf18
When I touch the touch pad my screen display goes off. it comes on sometimes by itself or when touch pad is touched. I have connected the toughbook to an external dispaly and can work no problems. help
Oct 22, 2008 | Panasonic TOUGHBOOK CF-18 Tablet PC
Keyboard key not active on front of computer
keyboatd controls are found by going to control panel--keyboard --and clickong or the tabs
May 22, 2017 | Panasonic TOUGHBOOK CF-18 Tablet PC
Dell Lattitue C400 keyboard partially not responding
Hi!
If you have replaced the keyboard and still the issue is there, then you are right. The controller is shot. You need to replace the motherboard again for this type of issue.
Karlox
Dec 05, 2007 | Dell Latitude C400 Notebook
Keyboard Circuit Faulty?
Since all of the failing keys are on the right hand side, I'd try a short (maybe 15 minutes) soak in warm soapy water of the right hand 1/2 of the keyboard. While it is soaking, every few minutes try depressing the failing keys several time each. Follow this with a good rinse with warm water and a good drying. A hair drier will help to speed up the process. If that doesn't work, you'll probably need to find a replacement keyboard.
R-
Nov 01, 2007 | Panasonic Toughbook 48 Notebook
Panasonic ToughBook 18 PC Notebook Logo
104 people viewed this question
Top Panasonic Computers & Internet Experts
micky dee
Computer Repairing
Computer Repairing
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
