Question about Maytag MEW6530DDS Stainless Steel Electric Single Oven
Control panel board
Replaced the control panel (again) but none of the buttons work after the re-install
2 Suggested Answers
marka19
  • 1430 Answers
SOURCE: I have a Magtag wall oven MEW6530DDS model. The
The control board. As long as none of the buttons appear to be stuck. Press each button one at a time feeling for the retraction or click. If this checks good replace the control board. Here is a link that should help http://appliancehelponline.com/ovenerc.html
Posted on Sep 18, 2010
None of the control panel button work on my GE profile oven is there anyway to reset it
No you will need to replace the entire control panel to correct this, it is all one piece, buttons and board.
Nov 04, 2016 | GE Ovens
Only some of the keys on the keypad of my oven work. I have replaced the control board (computer board), but they keys still don't work. What specific part do I need to replace?
Hello, Thank You for using FixYa. I will be helping you today.You didnt have to change the computer you need to replace the control panel. The control panel is the whole front piece which has the touch membrane on it. This is common on these units.
Thank You and please rate my answer if it was helpful..
Jun 10, 2011 | Maytag MEW6530DDS Stainless Steel Electric...
I have a Magtag wall oven MEW6530DDS model. The panel buttons do not work. I've had the oven about 3 yrs. Do I need to replace the control panel or control board?
Sep 18, 2010 | Maytag 30" Built-In Single Electric Wall...
Amana AOES3030 oven. There are two control pads. One is the clock/timer that is working fine. The other is the bake/broil/clean which is unresponsive, no matter which button you push. I am considering...
Sam, Lost my chat window once again, but yes those are the part numbers for your control board and your key-panel respectively use them to be sure you are getting the right part.
Jul 10, 2010 | Amana Ovens
I have a Whirlpool double oven (model RBD275PDS14). The control panel goes blank about every 2-3 months, and the oven won't heat. Although, the light inside the oven will still work. When the panel lights...
Your error code is for a stuck keypad. You can try pressing every button at random several times each to unstick.'
When the control board is changed on these ovens the keypad assembly is supposed to be changed also.
Nov 21, 2009 | Whirlpool Ovens
Maytag wall oven Model # MEW6530DDS control panel failing
HI, unfortunately, it is not just dirt, this is a faulty touch pad that is combined with the control board. most touch pads are separate parts that are clipped in front of the circuit board but, in this case, the touch pad and control board are one piece. You will need to replace the entire control board in this case. the touch pad is faulty.
Jun 03, 2009 | Maytag 30" Built-In Single Electric Wall...
Kenmore gas Range -- Control Panel not working
Hi. your assessment is correct. when you have normal operations with the stove top and the control panel is blank or non operational, this will confirm either a wiring harness issue or a dead control circuit board. The wiring harness can sometimes become lose or the connectors can become corroded but, in this issue, i am sure its the ECB(electroninc control board). In this case, you will have to replace the board it self.
Please rate and god bless:)
Apr 16, 2009 | Kenmore 33464 / 33465 / 33469 Gas Single...
GE JTP70 convection oven - defaults to self-cleaning mode
I believe your control board is going bad. This isn't that expensive. However, get one from a GE parts store. They tend to be better priced.
Jan 29, 2009 | GE JTP70 Electric Single Oven
Amana Convection Oven - Beeping Continuously
F1 code and continuous beeping. This is a common problem with that type of Amana control. The control panel has a design problem I think, and it gets dirty and worn over time. I have replaced mine once, and it happened again less than 2 years later. I took the control panel out, and inspected it. I found a web solution, that said to shim the control panel out away from the housing slightly because it rubs on the metal around the opening and damages the control board contacts. I could see little scratch marks on the plastic skin around the edge of the button area, so that made sense. I tried that, and it still did not work.....panel was still beeping. Mine seemed to be the timer control that was going on and off, and then eventually an F1 error. So, I took the panel out again, and actually peeled the control surface off of the control board. No going back now, I thought. I got it off....it is really sticky.......and looked at the control panel itself . It looked fine, but there was a lot of gunk and wear marks around the edge of the plastic button area. I cleaned it up with alcohol swabs, and checked to make sure none of the printed circuit paths had any wear or damage, and then put the cover back on the board. It was still sticky enough to go back on, and stay in place. I reinstalled it, and "bingo" no more problem. It has been fine for 3 months now. Yahooo! The pic below is just an example pic from the internet. My model is slighty different, but the panel looks basically the same. 1_23_2012_2_51_28_pm.jpg
Aug 22, 2006 | Amana AEW3530DD Electric Single Oven
Maytag MEW6530DDS Stainless Steel Electric Single Oven Logo
Top Maytag Ovens Experts
Dan Webster
Dan Webster
 Fix Your Board
Fix Your Board
Mack Baxter
Are you a Maytag Oven Expert? Answer questions, earn points and help others
