TV Receivers and DVRs
Problem for TV Receivers and DVRs
Generic problem for all TV Receivers and DVRs
Center speaker will not work
By jetstar88 on Sep 25, 2007
i have a Onyko HT-R540 reciever. I have no sound through the center speaker. When I run a test, all the speakers work except for the center speaker. All other speakers work well. Other than a possible defect with the reciever, is there any adjustment or setting I am over looking ?
Best Solution
posted on Sep 26, 2007
Very Helpful)
ElecEngTech
Rank: Wiz
Rating: 92%, 79 votes
If you had the Speakers Set to A (not B) and no headphones connected when you pressed the TEST TONE button on the Onkyo HT-R540 (also known as the HTS-790) remote, and you had no sound from the Center Speaker then try the following steps.
1) Check the Center Speaker wiring at both ends under a bright light and make sure that there is not a strand of wire touching the Receiver Chassis or another speaker post. Check both + and - .
If that looks okay,
2) unscrew the Center Speaker Post connections on the Receiver and verify that the bare stripped wire is making contact. Often, the insulation is too far into the connector. When screwed down, the wire's insulation is crushed and keeps the bare wire from making contact.
If this looks okay and the unit is under Warranty, your last test is to:
3) temporarily swap the wires from the Center Speaker with the Right Front Speaker. Turn the volume down low and try the TEST TONE button again.
If you now hear sound from the Center Speaker box itself and none from the Right Speaker box, then the Receiver is the problem.
If you still do not hear sound from the Center Speaker box, then the Center speaker itself is defective.
Was this helpful?
Yes
No
Popular Solutions for TV Receivers and DVRs
Questions and Unsolved Problems for TV Receivers and DVRs
Answer
I need to buy a good quality TV receiver (on air telecasted TV channels) How does this product... (More)
Answer
how can I use my westell 327W modem as a wireless router? It came with a USB wireless card inside a... (More)
Answer
Guide or menu does not come up using remote or directly on box
Answer
I have a goodmans freeview gdb3 box with 4.2 software since 2nd December anolouge to digital... (More)
Answer
Philips freeview box........will not retune! All others ok just this one!!!!
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top TV Receivers... Experts
Top Audio & Video Equipment Repair
(888) 737-1752
XBOX360 & PS3 REPAIR EXPERT SERVICE We can...
xbox360 fixer
(888) 399-5512
EverGreen Electronics is the ONLY Apple iPod and...
Apple iPod Service
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
