Question about Camping, Backpacking & Hiking
Refuel alpen lighter (yellow weatherproof case)
Wiring diagram for Sg7520accpk4
POWER
RED IS THE +POWER
BLACK IS COMMON
SIGNAL
YELLOW IS + VIDEO
GREEN IS -VIDEO
Mar 01, 2014 | Lorex Corp SG6184S Weatherproof Mini Color...
Cut wires on bunkhill weatherproof security camera#95914
My bunker hill has a black, white, yellow and green. I am confused with the white. Help
Oct 17, 2012 | Home Security
What does PO 455 code mean on a 2002 Chrysler Sebring?
Diagnostic Trouble Code (DTC) P0455 "EVAP LEAK MONITOR LARGE LEAK DETECTED"
This simply means that your Evaporative Emissions Leak Detector monitor has detected a large leak in your Evaporative Emissions (EVAP) system.
It is common for this code to set if you refuel your vehicle with the engine running, forget to put the fuel cap back on after refueling, or do not properly install or tighten the fuel cap after refueling. In these cases, it can be fixed by simply installing the cap properly and clearing the code. Also, make sure your engine is turned off when refueling so it dos not happen again.
If none of the above is the cause of this code, then you either have a large leak in one of the hoses, connections, or the fuel tank itself, or the EVAP leak detection pump is defective.
Oct 30, 2011 | 2002 Chrysler Sebring
I see double
Sounds like the prisms got knocked out of alignment. This would be difficult to repair on your own unless you happen to have access to the right optical equipment.
Aug 16, 2011 | Alpen Sport 200 (8x40) Binocular
Need wiring diagram for Lorex SG6184S. Cut off connectors and hardwired camera, not it does not work.
Lorex Corp SG6184S Weatherproof Mini Color Security Camera with Night Vision,where can i download manual,wanting to set it up to my vcr and clueless how this is done,i have camera's yellow white cables in tv[video/audio but unsure how to connect or what to do so i can record from vcr,please specifies
Sep 03, 2010 | Lorex Corp SG6184S Weatherproof Mini Color...
1998 Chevrolet Malibu fuse chart? Need to find why my interior cigarette power, and cigarette lighter are not working.
The fuse will be a yellow 20 amp fuse. The lighter element has a wound peice of metal that gets hot so it will light your smoke. If debries are left stuck in that coil eventually the coil will short out. Inspecting that coil for an open is firat thing to check. Next the casing the lighter fits into has a balast which operates like a fuse. That can be shorted out as well. If either one of these items gets weak and shorts out the fuse will not be blown
Jul 27, 2010 | 1998 Chevrolet Malibu
I can not locate the cigarette lighter fuse in any of the fuse panels. Will it be named under something else for a 2005 grandam? Everything else electrical still works
Radio and ciar light are on the same circuit
The element or the case to the lighter is at fault if the radio works
The elements windings can have an open which can be seen if burnt out.
The case you need to check the continuity to see if its ok
Jun 27, 2010 | 2005 Pontiac Grand Am
Camping, Backpacking & Hiking Logo
78 people viewed this question
Top Camping, Backpacking & Hiking Experts
Tom Chichester
ray gallant
Are you a Camping, Backpacking and Hiking Expert? Answer questions, earn points and help others
