Using different sizes of same brand memory on a PC
I have a few OCZ memory modules...they are the same PC3200 but I can't use them together. Do I have to change something in my bios to make them work?
  • 5 more comments
  • PitVipermd
    PitVipermd Apr 24, 2009
    I'm using Win XP
    AMD 3200+ CPU
    SFI
  • PitVipermd
    Sorry page refreshed before I was done..
    AMD 3200+ Cpu
    DFI
  • PitVipermd
    DFI Lanparty nf3 250 GB
  • PitVipermd
    They are the same speed... PC3200...but different sizes and steps.
  • PitVipermd
    The issue is not the total amount of memory, which will be less than 2 gigs...its having the memory work together...same brand...same speed..PC3200...only difference is type...ie platinum..titianium...and the steps...ie...2-3-2-5 are different. I thought if you used the same memory it would just take the slower speed...but accept the memory...if I use them together...it will only recognize one or the other. There has to be a trick to make it work :-(
  • Dwayne May 11, 2010
    what is your operating system
  • Dick
    Dick May 11, 2010
    Sometimes forcing a specific timing in the BIOS will allow the modules to work together but normally they either work or they don't. Some motherboards are more tolerant than others.
  • 83 Answers
If its a 32 bit os it will only recognize 3 gb of memory.
Posted on Apr 24, 2009
  • Dwayne Apr 25, 2009
    place the 2 higher speed in the first slot closest to the cpu and in the 3rd slot. then slower speed in slot beside it and farthest to cpu. or side by side if your memory slots are set up that way. usually the slots are colored in pairs and will tell you how they are set up. if they are all one color then its slot 1-3-2-4 just be sure the highest is closest to cpu. also you have to atleast have a pair of same speed if you are installing 3 memory modules, and with 4 each pair have to be matching speeds. if not it will slow your pc down more.
    sorry. i meant higher memory size. follow steps with memory size. highest to pc, smallest away from pc. keep in mind how the memory slots are set up. same rule aplies to memory size too when installing 3-4 modules, but you can run with different sizes. just follow the same steps.
  • 31 Answers
Did you check thoes ic on them that should be same
Presario sr1710nx what type memory
Crucial.com has an excellent wizard for locating memory.
Computer memory upgrades for HP Compaq Presario SR1710NX Desktop PC...
Lists memory compatible with your machine.
Memory Type: DDR PC3200, DDR (non-ECC)
Maximum Memory: 4GB
Slots: 4icon_note.gif Although the memory can be installed one module at a time, the best performance comes from using matched pairs of modules.
I have also found that the memory occasionally is not recognized. To fix remove the ram and clean electrical contacts with a clean pencil eraser. (Rub the contacts to clean.) Then replace memory. (My machine failed to boot, cleaning the contacts fixed the problem.
Nov 16, 2011 | HP Compaq Presario SR2150NX PC Desktop
I bought P3200 ddr 400 1gb memory and when i install it , it does not show up. any ideas why and if there is something i can do .
The Intel® Server Board S875WP1-E supports both ECC and Non ECC Unbuffered PC2100 (266 MHz), PC2700 (333 MHz), or PC3200 (400 MHz) compliant Double Data Rate (DDR) memory modules. Dual channel memory functionality requires two DIMM modules installed into DIMM sockets 1A & 1B, and then DIMM sockets 2A & 2B. The DIMM module size, speed and vendor must be the same.
You can install a single 128 MB memory module into DIMM socket 1A. The minimum supported memory size is 128 MB. The minimum main memory configuration is a single 128 MB memory module, and the maximum configurable memory size is 4GB. With only a single memory module installed, the system will only operate using a one memory channel.
Third party memory vendors may use the same module part number with different
DRAM vendors and die revisions. To insure proper system operation, verify that each DRAM
vendor and die revision has been separately tested and qualified. Please notify CMTL if there is a discrepancy.
Apr 10, 2011 | Intel Server Board S875WP1-E (S875WP1LX)...
I have a dell optiplex gx270, tried to upgrade my memory with samsung 1gb pc3200 ddr1 but doesnt work, just beeps on start up.
That is the correct memory module (Non-ECC).
Remove all memory modules.
Insert the one Samsung PC3200 module and start up.
If it doesn't boot, then try a different slot.
If it works ok, then add-in your original mamory modules. If they are PC2700, then they may not work together.
Oct 12, 2009 | Dell OptiPlex GX270 PC Desktop
Tried to add RAM but now computer won't turn on
Didn't we speak online about this a couple of days ago? You can't mix and match RAM. What you added is probably not the right config for that machine. You need to go to this link, plug in your machine information and then REPLACE, NOT ADD TO what you have.
May 26, 2009 | E-Machines eMachines Desktop PC
MS 7142 TO INCREASE RAM
hiya
its a case of purchasing the new ram modules taking the old ram out and popping the new ram in
i wud recommend using OCZ, GEIL or Crucial memory modules as these are the best makes
the spped of the ram varies from system to system depending on the system bus speed
the most common speeds for this board is pc2100, pc2700 and pc3200
these speeds are as follows pc2100 - ddr200
pc2700 - ddr333 and pc3200 - ddr400
hope this helps
Rik
Feb 27, 2009 | MSI K8MM-V Motherboard
Will 2 different memory modules work together on dimension 2400??
it will work, but not optimal for a good performance. Always choose memories with same ratings for best results
Jan 10, 2009 | Dell Dimension 2400 PC Desktop
I have purchashed additional ram (ddr 400 pc3200 1gig) after installation the pc locks up and informs that new hardware has been found! what do i do next?
Generally this will happen when you install the RAM with diff specifications or unsupported size (MBs).
Points to be noted before replacing the RAM:
* Maximum memory supported by your computer.
* Memory specifications compatiblity.
You can get the memory module specfications of your computer from its manufacturer.
If this is happening even after installing the correct RAM then you have to try with diff brand RAM.
While manufacturing the RAM, they have to follow many standards. If they won't follow those standards, then this issue may accout. So, check with another brand.
Pls reply if you need more information
Aug 09, 2008 | Medion Computers & Internet
Adding a second 1GB pc3200 DDR ram!
Are you sure memory is same (type and make) as they can have different timings and speeds.
remove 2nd memory module see if computer starts if it does i believe memory module could be faulty
Jul 23, 2008 | Asrock M266A Motherboard
Memory upgrade
you can use any DDR 180pin. But having two RAM of different speeds may not be compatible sometimes, so upgrade it to 1Gb by just using (1) 1Gb pc3200.
May 15, 2007 | EliteGroup P4VMM2 Motherboard
Computers & Internet Logo
83 people viewed this question
David Payne
David Payne
