Question about HP Pavilion Computers & Internet
HP pavilion 23xi shuts off - Pavilion HP Computers & Internet
HP 23xi. Half of the screen has a blue tint. I have already tried another screen and works fine. How do I fix it?
when you have an issue like that the only way to fix it would be to replace the lcd panel or replace the whole monitor. If it is still under warranty you should contact HP for a warranty replacement.
Feb 17, 2015 | HP Televison & Video
Why won't it connect to my DIY PC?
I have no idea what a DIY PC is but I am going to "assume" you built the PC yourself. Your monitor probably came with a CD and on it will be drivers. You can either load them from it or go to HP website and download them from there. First place to start.
Aug 03, 2014 | HP Pavilion 23xi - LED monitor - 23"
Mouse pointer disappers
I've seen this happen a couple of times when Word uses the initial preview "Read Mode" or Protected View . Try changing the mode by clicking on the View tab and changing the mode to Print Layout. When it happens to me, that seems to do the trick. If you don't want Word to use the Protected View, go into the Trust Settings for Protected View and uncheck the options in there...this may also keep it from happening in the future...good luck! :-)
Apr 24, 2014 | HP Pavilion 23xi 23" LED LCD Monitor -...
Hp laptop pavilion shuts off by itself
its either a bad power chord or the power supply or fan
Jan 05, 2013 | HP Computers & Internet
HP Pavilion dv6500 Notebook PC
Open Power settings, Advanced Power settings, Adjust shut down settings
Dec 20, 2012 | HP Pavilion dv6000z Notebook
I have a hp pavilion dv1000, it keeps shutting down, I had the fan replaced by Hp six months after I bought it. Is there a recall for this lemon?
are you sure that it shutting down because of fan
it may be a virus problem or OS problem too
try to find out main problem
thanks
Nov 12, 2010 | HP Pavilion dv1000 Notebook
I tried replacing my sata drive in my hp pavilion a1330n with my ide drive that was from my hp pavilion a510n. When i boot up the a1330n with the ide drive i get a blue screen saying that it has shut down...
yes the 2 computers are different. Different processors, different memory,different graphics card.To get your ide drive from your hp pavilion a510n to work in your hp pavilion a1330n, you will have to completely re-load the drive when it is installed in the hp pavilion 1330n. Then it will work fine, but you will not be able to use that drive in your hp pavilion a510n. because you will have the same problem but in reverse.
Oct 01, 2010 | HP Pavilion a1330n (EL466AA) PC Desktop
HP Pavilion m7750n shuts off randomly
go to your bios and and regulate shutting dows temperature
Jun 28, 2010 | HP Pavilion m7750n PC Desktop
Pavilion dv4000 PC Notebook: My hp pavilion dv5 laptop runs very hot and then t...
The easiest way to clean it is to use a can of compressed air and blow it through the airflow vents.
Check out this link for other solution.
http://bootmylaptop.com/laptop-shuts-off-after-a-few-minutes/
May 18, 2010 | HP Pavilion dv4000 Notebook
Hp pavilion a1220n shuts dwn after loading hp8500 pr drv xpsp3 os
If you can boot into safe mode, then once in safe mode open system restore and then restore to a couple days prior to the install of the hp drivers. This should fix the problem. If you need to know how to get into system restore let me know your operating system (Vista or XP)
Jun 27, 2009 | HP Pavilion a1220n (A1220NED904AA) PC...
Computers & Internet Logo
328 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
