Question about Acer Aspire 5500 5570-4421 Laptop
When i formatted my laptop the sound is not possible to hear,
Before formatting it was better, i could adjust the volume,i think i need a sound driver for my laptop aspire 5500z fl50
  • 696 Answers
Go to this address and then select "audio" from the first drop down box, a driver will download automatically at that point, if a yellow bar appears near the top of the window, your security is active, click the bar then click download file on the menu that pops up
http://support.acer-euro.com/drivers/notebook/as_5500z.html
Posted on Apr 24, 2009
  • 84 Answers
Rear speakers not working after formatting the system. Please. Help.
if your computer came with a motherboard disc the sound drivers could be on it
click start control panel administrative tools computer management device manager scroll to sound video and game controllers you might see a yellow question exclamation mark? ! or a red X Right click to
reinstall drivers
click start control panel sounds and audio volume advanced speakers make sure you have selected the
(appropriate speakers) also audio you will find 3 drop down lists make sure you have selected the correct settings there
click start control panel sounds and audio devices select advanced there might be a tick in the mute box untick it
if his does not fix the problem
click start control panel sounds and audio devices you can adjust the volume there also select speaker
volume you can change your settings there you can also tick in the box place icon in taskbar for any
further volume control settings you will need to right click on the speaker volume icon system select adjust volume
click start control panel sounds and audio volume advanced speakers select the appropriate speakers
from the drop down list or navigate to the device manager scroll to system devices + to expand system
speaker right click properties then select use this device (enable) also you might check
the speaker plug/outlets is usually at the back of the computer or if its a laptop on the side
you will have to open up the computer to check the lead attached to the rear of the input plug make
sure the connection is good with no dust as dust causes static electricity
clean your computer of dust using a fine air blower from a compressor making VERY sure that there is
no MOISTURE in the air line specifically around the sound card and the CPU central processing unit
dust causes static to build up in a computer
hope this helps
Jun 06, 2012 | Audio Players & Recorders
No sound after format
you might have to uninstall then reinstall both the sound drivers and the sound card make sure you have both of these devices backed up to a disc before uninstalling
a yellow? question mark means you need to install/update driver to do this
right click to install driver also
click start control panel administrive tools computer management device manager scroll to sound,video and game controllers you might see a yellow question mark? Right click to reinstall drivers
click start control panel sounds and audio,volume,advanced,speakers select appropriate speakers also audio you will find 3 drop down lists make sure you have made the correct adjustments there
click start control panel sounds and audio devices you can adjust the volume there also select speaker volume you can make adjustments there you can also tick in the box place icon in taskbar
hope this helps
Jan 19, 2011 | Creative Labs CT4870 / CT4780 Sound Card
I formated my hp laptop and after i finished formating there was no sound on my laptop
Formatting your hard disk erases everything on the disk. Including drivers for hardware.
1. find out the make and model of your laptop.
2. Go to the manufacturer's website and look for "Technical support" or a similar section.
3. Generally within most "technical support" sections is an area for "Driver downloads." You will want to look for sound card drivers for your model of laptop.
4. Look for your model of laptop within the driver downloads section.
5. Download the package and run it's install program.
Alternatively, you may Google "Sound card drivers for [insert brand and model of laptop here]."
It will take a bit of effort using this the google method. The laptop manufacturer's website is usually the best place to look. (Note that in some cases, the manufacturer's website can identify the sound card in particular for your laptop model. You can then google the "driver for [insert soundcard brand and model number]". Or go to the soundcard manufacturer's website and download the driver for your brand and model of laptop from there.).
Alternative to the two above options (Assuming you have windows, and it is functioning after a reinstall), try the basics:
-Turn up the volume knob.
-Turn up the volume on the operating system through the sound control panel.
-If you have Windows, turn up the volume by right clicking the little speaker in the lower right corner of your screen. Be sure that there are NO mute options checked. Muting All turns off the volume for everything. Muting just the speaker, mutes the sound volume, but not everything else.
Most likely you need to replace your soundcard drivers, though. The process isn't difficult, but locating the right driver can have you pulling your hair out sometimes.
Dec 05, 2010 | Computers & Internet
Help my ltop canot sound, HP Compaq Presario F700
if you mean that you cant get any sound on your computer
control panel sounds and audio,volume you can adjust the volume or advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make sure you have selected the right speakers or control panel,administrive tools,computer management,device manager scroll to sound,video and game cotrollers could be a yellow question mark? right click to re-install drivers
hope this helps
Dec 01, 2010 | HP Compaq Presario F500 F700 and G6000...
After formatting my pc i hear no sound pls help
if your computer came with a disk the sound drivers could be on it
control panel sounds and audio,volume,advanced,speakers select appropriate speakers or audio you will find 3 drop down lists make the necessary adjustments there or control panel,administrive tools,computer management,device manager,sound,could be a yellow question mark? right click to re-install drivers
hope this helps
Nov 24, 2010 | Computers & Internet
I took my laptop to get re formated at some shop and it worked fine but i think the guy forgot to install the soundcard or something anyway now i cant hear anything from my laptop how can i fix this
go to the website and check for your laptop model and download the drivers or better still search follow this link and download the drivers:http://support.dell.com/support/downloads/index.aspx?c=us&l=en&s=gen
Oct 25, 2010 | Dell 181UR Sound Card
Could not hear sound
check all the settings of your sound installed....if still not maybe you installed wrong driver....
but first, check all the settings,volume control in the windows or physical volume control down in the laptop or check also Fn+ sound volume.
Jan 04, 2009 | Computers & Internet
No Sound on my laptop
my pc computer same problem
Aug 20, 2008 | Computers & Internet
Sound problem
8d63985.jpg if audio shows ? mark that sound driver nor install
Aug 09, 2008 | Microsoft Windows XP Home Edition
Acer Aspire 5500 5570-4421 Laptop Logo
148 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
