Question about Sport & Outdoor - Others
I would like to know what battery goes in a Jetco Treasure Hawk Metal detector?
4 Suggested Answers
  • 6 Answers
SOURCE: ERROR CODE L6
possibly low systm battery.......
Posted on Oct 18, 2008
SOURCE: blue hat metal detector doesn't work
We are having the exact same problem. Looks like we either got a dud or the thing is a piece of junk.
Posted on Jan 10, 2010
  • 34814 Answers
SOURCE: Night Hawk Combination Detector beeps often and
It is telling you that the battery needs replacement
Posted on Sep 02, 2013
My night hawk carbon monoxide reads L6. Then Err.
Lb (rather than L6) indicates a low battery. You need to replace the 9V battery in the carbon monoxide detector. The Err suggests an internal error but could just be due to the low battery.
If the Err persists after you replace the battery, press the peak level button (the right hand button) and check for an additional error code. If the Err message continues, replace the Night Hawk unit. If the unit is still under warranty, contact the manufacturer. Most of these units have a 10 year warranty. There are several models available from Kidde. The manual is available on the product site. For the KN-COPP-3 Night Hawk carbon monoxide detector, the documentation is available here: http://www.kidde.com/home-safety/en/us/products/fire-safety/co-alarms/kn-copp-3/ . Click on the Documents tab. The manual for the KN-COPP-3 999-0100 is here: http://www.utcccs-cdn.com/hvac/docs/2001/Public/06/User_Guide_KN-COPP-3_900-0100.pdf .
I hope this helps.
Dec 12, 2016 | Night Home Security
Tip
Dig out your own treasure
Some people wrongly consider "treasure hunting" with the use of a metal detector, as a potential source of enrichment. However, as almost all metal detector treasure hunters will testify, this activity is almost completely of an entertaining nature and rarely brings any real valuables.
All metal detectors can be set to detect different levels of signals coming from the metals, buried underground. According to its settings, the metal detector finds bigger or smaller objects, of different metals, buried deeper or more superficially. What most people aim for is gold. Lost rings or chains, old gold coins etc.
Coins are the most common "treasures" found with metal detectors.
They can be found more or less easily both on beaches or buried in fields. In the latter case, it's easier to find older coins rather than modern ones; witnesses of history, lost in more or less ancient times. Many metal detector hobbyists like collecting them as historical tokens, engraved with images and scriptures from the past.
On the other hand, beaches are abundant with modern coins that people lose, for example, when dropping the wallet in the sand, or when shaking the towel, forgetting they had been hiding money or jewelery in it.
Rings are also often lost in the water and washed ashore by the waves.
Therefore, the two places on the beach that may prove the most fruitful, are the round-shaped areas where the waves touch, especially at their tip, and the farthest outskirts of the beach, where people usually set their towels and belongings, and where they are likely to shake off their towel, dropping "treasures".
on Nov 07, 2013 | Retail Supplies
How do i set my green youth metal detector to only to coins
u cant set these for only COINS but u can use the u can exclude unwanted or limit these with the anolog controller settings.. it can be good and bad though..if u set it to discriminate to high..u will then take the chance of excluding smaller items.. to low and u then get cross signal issues and dig up lots of junk.. best to learn the way it behaves with diff kinds of metals and at diff depts so u dont miss out on that one chance to hit it big..
When out hunting with a metal detector, you could come across more junk than treasure. You may detect and dig up rusty nails and bottle caps in the hope of finding coins or other valuables. To resolve this issue, most detectors are equipped with a discriminator. Setting the discrimination level allows you to distinguish between good and bad tones when hunting for specific metallic objects. One of the most effective ways to use your discriminator is with a technique known as reverse discrimination.
Chadman
Aug 19, 2013 | Wildgame Innovations Youth Analog Metal...
Pls 360 laser level
Get a good quality <a href="http://detectorsforgold.com/gold/category/metal-detectors-
gold">metal detectors</a> would make only 50% of your task. Only by adding accessories to
the Executive setting could be improved. A good pair of headphones, SIP, carrying pouch and a
few of the components should be obtained for any treasure hunter. You'll find audio equipment,
as well as that might help you capture even faint sounds.
Jun 27, 2013 | Measuring Tools & Sensors
Random beeping metal detector
Get a good quality metal detectors would make only 50% of your task. Only by adding accessories to
more metal detectors
Jan 29, 2013 | Bounty Hunter Digger Metal Detector
Need owners manual for gc-1036 metal detector
http://www.treasure-cove.com/support/user-manual/ the manuals for all treasure cove are here
May 27, 2012 | Bounty Hunter Digger Metal Detector
I need to know what batteries to put in my inductive voltage tester, Greenlee model 1010..
It takes two type 357 button cells. Fry's sells for $2, Radio Shack for about $3.
Make sure + sides goes into the body, not the cap.
Aug 12, 2010 | Greenlee GT-15 Non-Contact Low Voltage...
ERROR CODE L6
Oct 17, 2008 | Kidde Nighthawk Combo Gas/co Detector
Sport & Outdoor - Others Logo
69 people viewed this question
Top Sport & Outdoor - Others Experts
Are you a Sport and Outdoor - Other Expert? Answer questions, earn points and help others
