Question about Uniden Bearcat Inf 5xl Scanner Operating User Manual
How do you program the frequencies? - Uniden Bearcat Inf 5xl Scanner Operating User Manual
Why wont my scanner model 60 channel pro-2029 scan
Hi Chad,
Do you have any frequencies programmed into your radio scanner?
If not, then that is why you're not receiving anything.
If on the other hand you do have frequencies programmed, are they the correct frequencies for your location?
Are the frequencies the Tx or Rx frequencies that you programmed, The Tx frequencies are the correct frequencies to program, as Rx is the mobile(usually) Tx frequencies, and unless you're within 5 miles of that mobile, you won't hear it, and you certainly won't hear the base transmissions, unless it's a high powered Simplex Frequency.
I hope this has been useful to you.
Cheers,
Peter
Mar 15, 2013 | Radio Communications
Tried programming 7 digit frequency but scanner wont accept it-any solutions - Deo
The scanner rounds off frequencies to six digits so if, for example you are programming a frequency with a 5 on the end drop it and the scanner will store it
Sep 24, 2012 | Radio Communications
Lost owners manuel. need code install instructions. and also how to clear off all old codes
There is no general reset function that will clear all of the frequencies (they're not codes) from your scanner, but there are two ways to clear individual frequencies:
1. Programming "0.0" (zero point zero) into a channel will remove the programmed frequency.
2. Programming a new frequency into any channel will remove/override the previously programmed frequency.
You can download and print the manual for your scanner, at no cost, here:
http://www.uniden.com/pdf/BC248CLTom.pdf
For a comprehensive database of active frequencies in your area, and a lot of other useful scanning information, visit:
www.RadioReference.com
Bill B.
Listening in since the 60's
Nov 16, 2010 | Uniden BC248CLT Base Scanner
How do i delete a frequency already programed? and can i get a frequency at 46.5000?
Programming a new frequency into a channel automatically deletes and replaces a frequency already programmed. Or, to just delete, and leave an unprogrammed channel, just program 000.000 into that channel
Yes, you can program/receive 46.5MHz. The full tuning range of your scanner is 25-54, 108-174, 406-512MHZ.
Need the manual for your scanner? You can download and print it, at no cost, here:
http://www.uniden.com/pdf/BC72XLTom.pdf
Bill B.
Nov 05, 2010 | Uniden BC72XLT Handheld Scanner
How do delete a frequency code from my scanner i know how to program but dont know how to take a frequency off thanks
Just program 0.0 (zero point zero) into a channel to clear the existing frequency. Also, programming a new frequency into a channel will overwrite/delete the previously programmed freq.
Bill B
Aug 02, 2010 | Uniden BCT8 Base Scanner
Im trying to program my Pro-70 Hyperscaner
To program a known frequency into your PRO-70:
- Press PGM. PGM appears on the display, indicating that the scanner is in programming mode.
- Enter the number of the channel that you wish to program (1 - 50), then press PGM again. As an alternative, press PGM repeatedly until the desired channel number appears on the display.
- Enter the desired frequency, including the decimal (for example, 156.045).
- Press E/L-OUT to store the frequency.
- Repeat steps 2 - 4 to program another frequency.
Your scanner's operating manual has details on other programming steps. If needed, you can download/print the manual here:
http://support.radioshack.com/support_electronics/doc62/62177.pdf
Bill B
Apr 23, 2010 | Radio Shack Pro-97 Handheld Scanner
How do you manually program a Uniden BC355C?
Turn on the radio
Press the "band" button
Keep pressing the "band" button until you come within the parameters of the frequency that you want
Let the radio scan until it gets close to the actual frequency that you're looking for
Press the "hold" button and use the arrow "up" or "down" button till you lock in the correct frequency
Once you have the frequency locked in, press the "program" button
Press the "private" button
The unused channel will be flashing
Press the "program" button, this locks the frequency into that channel
Continue this process until all of the frequencies are loaded into the radio
Feb 22, 2010 | Uniden BC350C Base Scanner
How do you set up the scanner to scan police and ems channels
First you'll need a list of frequencies to program. For a comprehensive database of active frequencies in your area, visit:
Once you've selected your frequencies, power the scanner ON and
1. Press E/PGM to enter the program mode (the scanner turns on the
PGM icon).
2. If the current channel is not the one you want to program, enter the
memory number then press HOLD.
3. Enter the frequency including the decimal point, then press E/PGM.
4. To program the next memory, press  or  and repeat step 3. To
program a different memory, repeat from step 2.
5. To exit program mode, press HOLD or SCAN or change the scanner’s mode.
Notes:
• Any frequency you program replaces the previous memory contents.
• If you enter a frequency you have already stored in a different
memory in Step 3, the scanner beeps and displays the channel
where you have previously stored the frequency. If you want to store
the frequency anyway, press E/PGM a second time in Step 3.
• To clear the contents of a memory, enter “0” in Step 3.
• Channels you program are automatically unlocked (see
“Locking/Unlocking Memories) and have Delay turned on (See
“Setting Channel Delay”).
If you would like to download/print the operating manual for you scanner, visit:
http://uniden.com/pdf/BC340CRSom.pdf
BillB
Jan 11, 2010 | Uniden BC340CRS Base Scanner
I have a realistic pro-2021 scanner and dont know how to operate it other than turning it on or off can you help ??
Programming Frequencies
1. Select the desired channel.
2. Press [PROGRAM] to enter the programming mode.
3. Enter the desired frequency.
4. Press [ENTER].
Selecting the Channel
Step 1:
1. Press [MANUAL]. Continue pressing until the display shows
Channel 20. Press [PROGRAM].
2. Press [2][0][MANUAL]. Press [PROGRAM]. (or press [PROGRAM],
press [2][0], press [PROGRAM]).
Step 2:
Press the keys (example 162.55)
Step 3:
Press [ENTER]. To program the next frequency, move to another channel in
this way. Press [PROGRAM] to advance to the next channel. Repeat the
same steps to add more frequencies.
SKIPPING BANKS
1. Turn the power on.
2. Press the number key that corresponds to the bank to be skipped.
3. The corresponding bank number indicator disappears from the display
and the entire bank is skipped.
NOTE: To restore the banks, press the number key again.
SEARCHING WITH YOUR PRO-2021
To search for transmission, press [PROGRAM], enter limits of frequency
range, and press [up arrow] or [down arrow] to activate "search."
1. Press [PROGRAM].
2. Press [LIMIT].
3. Enter the lower limit of frequency range to be searched.
4. Press [ENTER].
5. Press [LIMIT].
6. Enter the upper limit of frequency range to be searched.
7. Press [ENTER].
Activate "search" by pressing [up arrow] or [down arrow]. [Down arrow]
starts search from the highest frequency and goes down. [Up arrow] moves
in the opposite direction.
Press [SPEED] to accelerate or to slow down the search.
Jan 07, 2010 | Radio Shack Pro-2096 Base Scanner
Uniden Bearcat Inf 5xl Scanner Operating User Manual Logo
47 people viewed this question
Top Uniden Radio Communications Experts
Jason
John
John
AnyMHz.com
AnyMHz.com
Are you an Uniden Radio Communication Expert? Answer questions, earn points and help others
