Question about Whirlpool Cabrio HE 4.5 cu. ft. Washer
Wtw6700tw1 My whirlpool Cabrio WTW6700TW1 has water coming from under the front left corner. After lifting the top up you can see that water has splashed in the inside of the front of the machine and runs down on the floor. I do not see any leaks on the tubes going to the dispensers or cracks. Can the rods that let the tub move around cause the tub to be out of alignment so that when the water going through the dispenser it could possibly not meet up with the inner ring around the tub and splash over? The first Cabrio I had the tub was too far back and after 3 attempts of repairman trying to fix the machine, Whirlpool finally replace the machine. The first machine had the same problem with water splashing over and running down the inside on the front left corner. When you look at the tub ring while not in use it does not look in line with the opening, but further towards the back of the tub. That's why I am wondering if it's the rods making the tub out of alignment.
SOURCE: Water splash sheild ineffective
My machine may be a different model, but seems to have similar problems. I resolved this by: a) making sure the splash shield is fastened correctly at all points round the tub (it worked loose) b) as a temporary fix reversed the foam gasket inside the splashshield until I get a new one
Posted on Sep 05, 2007
  • 1294 Answers
SOURCE: leaking from the dispenser
Try to pull out your dispenser drawer gently to clean out thoroughy. If you cant succeed, use a tooth brush, see that the brush does not fall in. Probably you have dried powder blocking the passage, nothing else.
Rate me pl.
Posted on Nov 30, 2007
  • 16 Answers
SOURCE: Necklace fell into soap dispenser
you have to unclog your drain pump
Posted on Nov 23, 2008
robocop
  • 90 Answers
SOURCE: water leaks
If there is water leaking from under the washer, then you have a water leak from one of your water hoses. Check the back of the washer, where the water comes into the washer, to see if its leaking water or the hose is cracked. If its leaking water from the intake hose, then unscrew the hose and check the rubber washer, to see if it needs reolaced. Sometimes those rubber washers get cracked or broken. If that doesn't help, unplug your washer from the power cord and unscrew your intake water hoses and flip the washer gently on it's side and check the water hoses under the washer for leaks or cracks. Replace the hoses if cracked. Your local hardware store should have replacement hoses. This should solve your problem, but if not, then you need to call a washer repair person to look at it. I hope this helps.:)
Posted on Jan 19, 2009
beltronic205
  • 1466 Answers
SOURCE: whirlpool front load leaking water from the detergent dispenser
Could be pressure too high reduce feed to machine only ....Slightly...Also try cleaning just in case its blocked
Posted on Sep 28, 2009
I have a whirlpool washer model wtw6700tw1 see #cw2273416 It's reading Lp and not working at all
sure its not LF that's long fill check water is turned on all the way or change water valves on washer
Dec 02, 2016 | Whirlpool Washing Machines
Whirlpool wtw6700tw1 liquid bleach dispenser will not empty
3 possibilities the hose fell off inside, , the solenoid is bad, the switch is bad.
Jul 14, 2014 | Estate ETW4400VQ Top Load Washer
Whirlpool cabrio wtw6700tw1
You can buy a new pump from partsclinic.com The following link is for the part and a video on how to replace it
http://www.repairclinic.com/PartDetail/Drain-Pump/W10217134/1472275?modelNumber=WTW6700TW1
Oct 13, 2012 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool cabrio WTW6700TW1 only fills little bit, won't turn or agitate, buzz sound/humming noise,code F51 flashes??
The F51 error is a RPS (rotary position sensor) board failure where the control board looses contact with the RPS during the machines operation. The RPS uses hall effect sensors to determine the speed and direction of the drive motor, allowing the control board to constantly monitor the motors operation. Because this error is a communication error and not a mechanical error with the motor itself (that would be and F52 error) we can limit our trouble shooting to the three items that make up the RPS circuit, the control board, the wiring harness, and the RPS itself.
Jan 16, 2011 | Whirlpool Cabrio HE 4.5 cu. ft. Washer
My cabrio wtw6700tw1 does no rinse so the water not drain out of the basin
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkoutthis tip...
Front Load Washing machine not draining and or not spinning
heatman101
Oct 07, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Water is leaking onto the floor underneath my Whirlpool Cabrio (top-loading).
If its a small intermittent leak from the front left corner its the tub ring, whirlpool has redesigned the tub ring to fix this concern..
Sep 19, 2010 | Whirlpool Cabrio WTW6600SBT Top Load...
Whirlpool Cabrio WTW6700TW1 that is making a banging noise
The Cabrio unfortunately has many problems. Your problem however is the four suspension rods. If you know someone who is handy it's not that bad to do yourself. Just need a little patience. There are two clips just between the top panel and the front panel. Use a screw driver and a flashlight to see the clips. Then using the screw driver, push in on the clips to lift the entire top panel. This can be difficult. Once open you should be able to see the four rods that support the tub. That's what you need. Hope this helps...
Jan 17, 2010 | Washing Machines
Whirlpool Cabrio HE 4.5 cu. ft. Washer Logo
Dan Webster
Dan Webster
Sal DeAngelo
