Question about Texas Instruments TI-84 Plus Calculator
Missing options in APPS
My TI-84 calculator has only one option in APPS. Before it has complete options. How can I have it back?
Thanks a lot.
Jaycee
Conflicting app error on TI-84 plus silver edition.
When either of them is loaded in memory once, it remains there and takes over the graphing features of the calculator. If one is loaded in memory it must first be unloaded before you can use the other.
To recover the normal calculator behavior both must be unloaded from RAM. Overwrite one by the other, and uninstall the other. That will not delete them.
May 13, 2012 | Texas Instruments TI-84 Plus Silver...
How do I restore my APPS selcetion? I have no more options listed under APPS. How do I restore to factory settings again????
If you have the CD that came with the calculator, the apps are on there. If you can't find the CD, you can download the apps from
http://education.ti.com/educationportal/sites/US/productDetail/us_ti84pse.html?bid=7
Mar 16, 2011 | Texas Instruments TI-84 Plus Silver...
APPS are missing
You can download them to a computer from http://education.ti.com and transfer them to a calculator using the USB cable, and/or you can transfer them from one calculator to another using the unit-to-unit cable.
May 20, 2010 | Texas Instruments TI-84 Plus Calculator
Reset
First, turn it on. Once the calculator is on, press the "2ND" key (I believe it is a blue key in the ti-84 plus silver edition). Now press the plus key (+). A little above that key, you should see the word "mem." When you see the screen titled MEMORY, move the cursor all the way down to the option that says "Reset." From here, you can choose to reset either the RAM memory, or the factory settings. The factory settings are the "Defaults" option. I hope this helps.
Thanks.
May 23, 2009 | Texas Instruments TI-84 Plus Calculator
Ti 84 plus silver edition language change
The easiest way to fix this is through the Apps menu. Hit the apps key, then scroll down until you see any language(espanol, Deutsch, etc.). It should give you the option of switching to either that language or restoring to English. I just tried this on a calculator that was set to German. I hit Apps and scrolled down until I recognized the option for Spanish, and it still worked. It let me switch back to English.
Hope this works for you.
Nov 09, 2008 | Texas Instruments TI-84 Plus Silver...
Cannot find ram option when downloading apps!!
Hope you had your data backed up. If not u might want to browse the web for a package to download with all the original stuff. ALWAYS back up ur stuff just so this doesnt happen.
Oct 01, 2008 | Texas Instruments TI-84 Plus Silver...
CANNOT ACCESS MEMORY ON TI-84
Yes i know exactly what that is. This happens when you are in mirage OS and you set that option. What you need to do is take out the batteries when its on or go to mode and press alpha and s (LN) and then it should ask for self check say yes and press enter for like ever. I prefer to take out the batteries Then quickly go to memory and delete the avtar. It should do the trick.
Sep 09, 2008 | Texas Instruments TI-84 Plus Calculator
How to restore applications on TI-84 Plus Calculator
THIS WILL HELP YOU 4 SHO
the best way to get all your applications back is to link your friend's ti-84 plus and make a file backup, ( do this by first installing Ti graphing Product CD wich is included with the calculator) after this just connect your calculator and store the files back onto your calculator! ZOMG??? IS it that easy???
yes it is, just apply some clear thinking and ull be just as smart as i am
Mar 23, 2008 | Texas Instruments TI-84 Plus Silver...
Receiving Apps
That is because the cable directions are wrong. The sending is B the receiving is A.
Oct 01, 2007 | Texas Instruments TI-83 Plus Calculator
Changing from Spanish to English
In APPS, there is no option for English. You need to select another language (DANSK usually comes first), then select option 2 for English (option 1 will be the language you chose in APPS).
Sep 17, 2007 | Texas Instruments TI-84 Plus Silver...
Texas Instruments TI-84 Plus Calculator Logo
147 people viewed this question
Top Texas Instruments Office Equipment & Supplies Experts
k24674
Stevan Milanovic
Are you a Texas Instruments Office Equipment and Supply Expert? Answer questions, earn points and help others
