Question about Masterbuilt 20070106 Electric Smoker
Guide book for masterbuilt smoker 20070410 - Masterbuilt 20070106 Electric Smoker
SOURCE: Element won't heat on Masterbuilt smoker
I called Masterbuilt and they said they no longer sell the elements. you have to buy the cabinet @ $189 for the 40" model. I decided to pull my element and see if i could find one that would work by going to an appliance repair parts store.
When i pulled the element, i found that the terminal that plugs into the element was burned/melted in two. i replaced the terminal end, pluygged it in and tis working fine.
to remove the element, you need to remove the element cover/chip loading chute first. its easy, 2 sheet metal screws and 2 nuts and 2 machine screws. one of the nuts/machine screws is a little hard to get back on when you reassemble but it can be done. after the cover is removed, you will see 3 screws where the element goes through the back wall. only removed the left and right ones. do not loolsen or remove thecenter one. after you remove the 2 screws, you can coax a small amount of the wire leads out into the open and you can inspect them to see if they are broken.
if the problem is truly a bad element, you will have to find an element somewhere. i cant help with this except to say that Masterbuilt customer service says they are negotiating with their supplier to see if they can sell the elements seperatly. they hope to have that resolved by summer.
hope this helps.
D Smith
Posted on Dec 09, 2008
  • 7 Answers
SOURCE: My Masterbuilt electric smoker stopped heating will cooking
I just bought a new Masterbuilt Smoker by default two weeks ago I borrowed a friend’s to smoke about 30lb. of Salmon to then can. Ran the smoker every day for three day. ON my last batch the heating element would not work. Talk about Frustrated! The Smoker was only 2 yrs. old.
Knowing I borrowed I felt I had to replace. So online to Cabelas and I ordered my buddy a new smoker and had it shipped. I then found this website... GOT TO LOVE the internet. I saw many other people had the same problem. Found an Answer...
The Problem was one of the connector to the heating element was poor quality and if you don't clean your smoker on a regular basis. The heat and moister caused the small copper connector to corrode and the wire to come loose. I took a wood chisel and cut off all the rivets on the back. I was then able to pull the back off with no damage and access the small box in the lower back. I found the connector. Went to the hardware store and bought a replacement for .75 cents. A pair of wire crimpers and the problem was fixed. I also bought ½ inch Sheet metal screws to secure the back it was good as new. So I returned the smoker to my buddy and kept the new one. When it arrived I saw Masterbuilt has since fixed the problem and provided an access panel to the element and connectors.
Mike in Alaska
PSU313@yahoo.com
Posted on Jul 03, 2010
heatman101
  • 43501 Answers
SOURCE: can you buy a replacement heating element
Here is a pdf of the smoker book and on page 4 there is a parts list with the cust. service number to order replacement parts...there is an element kit listed there, that is what you need.
http://www.masterbuilt.com/pdf/manuals/Smokehouse%20models%2020070206,%2020070106.pdf
heatman101
Posted on Jul 25, 2010
kel1guy2002
  • 3740 Answers
SOURCE: Masterbuilt smoker model 20070910 with
Hi and welcome to FixYa, I am Kelly
It is telling you that the temp is below 40 degrees F. All you need to do is warm up the temp probe to 40F and it should work just fine. Use a hand held hair dryer or a warmed up shop vac on b.l.o.w to warm it up.
Happy New Year,
Kelly
Posted on Jan 01, 2011
  • 4736 Answers
SOURCE: where can i buy a
The following two places carry Masterbuilt parts.
www.appliancefactoryparts.com
http://www.searspartsdirect.com/partsdirect
Posted on Feb 19, 2011
Model 20070410 masterbuilt smoker has the chip tray touching the element. will this burn out the element
Have the same "smokehouse" and faced the same issue today. First, ensure the Wood Chip Grate is rotated so the highest part of the Grate is to the left. Next , place the Water Bowl on the left (that highest part) and the Wood Chip Bowl w/ Lid to the right (balanced on the Grate so it doesn't fall through the supports.
Dec 01, 2012 | Masterbuilt 20070106 Electric Smoker
I am new to smoking. I have the Masterbuilt 30 inch electric smoker (model 20070410). When do you use the water tray - put water in it. I know to use the wood chips, but when should I add water to the...
According to Masterbuilt, you should use water all the time. It pan should be filled the the lines indicated on the pan, prior to turning the smoker ON.
Hope this helped you and thanks for choosing FixYa.
Aug 13, 2011 | Masterbuilt Electric 30inch Smokehouse ...
I have a Masterbuilt electric smoker and have lost the instructions that came with it. Would instructions from a different smoker work with my Masterbuilt? Do you know how I might get the Masterbuilt...
Masterbuilt makes several different models of electric smokers. f you can furnish the correct model number of yours, I may can help you.
Thanks for choosing FixYa.
Aug 05, 2011 | Grilling
Smoker was working great. Went to smoke some ribs this morning and my controller won't go above 90. Help!
Your heating element is now probably inop. You'll have to go onto masterbuilt.com and order another element. Try this site:
http://www.masterbuilt.com/pm-smokers.html
Feb 26, 2011 | Masterbuilt 20070106 Electric Smoker
How long to cook a turkey The instruction book
depends on the weight 10 to 14 pound maximum, is the time limitations usually involved. It takes between 6 and 8 hours to smoke a 12 pound turkey and the bigger they get, the longer they take.
Can you buy a replacement heating element for the masterbuilt smoker
heatman101
Jul 23, 2010 | Masterbuilt 20070106 Electric Smoker
More receipes
Try this link. http://www.masterbuilt.com/recipes.html
Also try to Google "smokering". There are some great smoker sites on the web.
Hope this helps.
May 29, 2010 | Masterbuilt 20070106 Electric Smoker
Do you know of a good recipe book that works with masterbuilt smo
If you really want to learn the art of smoking and slow cooking food, Google "smokering" Lot's of forums and helpful people to get you started. Lots of smoker recipes also.
Apr 19, 2010 | Masterbuilt 20070106 Electric Smoker
Need manual for masterbuilt mini 7in1 smoker
http://www.masterbuilt.com/pdf/manuals/7%20in%201%20Smoker.pdf
Apr 26, 2009 | Masterbuilt Mini 7-in-1 All-in-One Grill /...
Masterbuilt 7 in 1 gas smoker
here is the pdf format link, hope this helps :)
Nov 09, 2008 | Masterbuilt Master Barbecue 7 in 1 Smoker...
Masterbuilt 20070106 Electric Smoker Logo
48 people viewed this question
Top Masterbuilt Grilling Experts
Dan Webster
Dan Webster
Paul Carew
Are you a Masterbuilt Grilling Expert? Answer questions, earn points and help others
