To reset the drum light on your Sharp AL1631 series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "
print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone.
Good Luck and Thank You for using Fixya.
Is you Al-1631 Connected to the machine or in the network ????
Then there is some problem with the Logic Card ..... Check that first you hv done the rest of the .... Problem
