Question about Hughes SDHBH DirecTV DTV Receiver
Direct tv receiver wont turn on - Hughes SDHBH DirecTV DTV Receiver
Why wont my 6.3 dish remote turn on 612 receiver
You can check out this link for directions on programming your remote: http://www.mydish.com/support/program-non-hopper-to-receiver. Let me know if you have any other questions!
Sarah J.
DISH Social Media Representative
Sep 22, 2014 | DISH Network Televison & Video
Why would JVC 8010 optic digital randomly malfunction?
I don't know if this helps but, if you have your bluray hooked directly to your tv some times TVs can have issues sending the proper channel to audio out to the receiver. You should always connect your bluray and other devices directly to your receiver.
if that's not the case,
Try turning the tv speakers back on, test the bluray hooked directly to the tv and see if things work flawlessly just with the tv and bluray.
If they don't there may be something just wrong with the cables.
If they do work flawlessly then there may be something wrong with the receiver.
If you already had your bluray connected to the receiver, I would still try direct to tv test and swapping cables.
The randomness leads me to think cables. But you can rule them out by testing directly to TV.
I hope that helps
Sep 06, 2014 | JVC Audio Players & Recorders
ViewSonic 37" Wide (N3733W) TV Set that is connected to Direct TV has picture but no sound.
Based on your description, it is possible that the power supply is starting to go. Before doing anything, first check to see if it is the TV or the source. Use a few different sources to narrow down the problem. You didn't mention what type of hookup you used from the receiver to the TV. Assuming you are using HDMI, it is possible that the cable is intermittent. Try using a different one. Also try as below.
1. Once the TV is working with sound, what happens if you turn the TV off and then back on, is the sound still there?
2. Use the TV antenna input to see if you can replicate the problem using an antenna. If the problem is indeed the TV, it should do the same with the antenna.
Feb 17, 2013 | ViewSonic Televison & Video
Westinghouse 32' flat screen tv wont work with cox cable receiver
Hello
You haven't stated the type of signals that comes with your co-axial cable; analogue or digital. Anyway, you have to retune the TV after connecting it properly with Cox-Cable receiver with TV.
Feb 23, 2012 | Westinghouse LTV-32w1 32 in. HD-Ready LCD...
Westinghouse wont connect to cox cable receiver
Hello
You ahve to setup the cable receiver to your Westinghouse TV. For more details, try these links to download the setup proceedings. I hereby attaches the links that might help you.
If you feel any difficulty in downloading the same, inform your email address to me by Fixya comment. I'll send a copy of the setup manual to you by return mail.
www.cox.com/hr/support/dc/docs/HDUsersGuide.pdf - United States
www.cox.com/support/cable/pdf/userguide_1.3.pdfSimilar
http://www.dataentryjobs.us/67948.html
www.cox.com/hr/docs/channel_lineup.pdf - United States
Feb 23, 2012 | Westinghouse Televison & Video
Hooking up my x-box 360 through Direct TV
Ok i had it installed today too....i already had it so i have experience with it....get a vcr....in th eback there should be some ports for AV cables hook that up and get one of those cords that look like the direct tv cords and put that in you VCR out to tv...and screw it in with your hands in your tv.....when you have your VCR on the direct tv wont show and if your direct tv is on when your xbox and VCR are on it still wont so turn off the VCR to get direct tv back again.....im 13 and i figured this out...hopefully this helps a bit
Sep 26, 2009 | Microsoft Xbox 360 Console
Digital optical output for technics 5.1 surround sound receiver
I went to the HDTV plasma manual. It stated the only way the digital optical audio output would work (from this TV) was to go to the menu, select audio and turn off the TV speakers. Basically, it had nothing to do with the technics receiver.
Sep 16, 2009 | Technics SA-DX930 Receiver
Direct TV remote quits working - conflict with Samsung LCD?
Turned power saving feature on the TV to low and moved the receiver about four feet away from the TV and the remotes work fine now.
Sep 03, 2009 | Samsung TV Remote Control
Probles with dual screens on sat. receivers
if both receivers are plug into their own inputs on the back of the television, go into the remote set up screen and program the av1 or av2 as a seperate receiver. this will all the remote to send a different signal to the receivers so they wont change at the same time.
Jan 03, 2009 | Televison & Video
RF module related to Direct TV.
yes you can but the 2nd tv wont be in HD. The modulator can be purchased for any electronics store. what it does is turns a composite video signal (yellow, red, white cables) into a coax (screw in cable). it has an composite input that you would connect from the receiver and a coax output that you would connect to the other bedroom tv.
Oct 11, 2008 | Samsung SIR-T451 DirecTV DTV Receiver
Open Questions:
See all Hughes SDHBH DirecTV DTV Receiver Questions
Hughes SDHBH DirecTV DTV Receiver Logo
Top Hughes Televison & Video Experts
Jim London
Jim London
Edward Talavera
Edward Talavera
Are you a Hughes Televison and Video Expert? Answer questions, earn points and help others
