Question about Watches
Shorten band on armitron 20/4664TI 6P29 - Watches
  • 161 Answers
SOURCE: shorten band
Hi Go to www.skagen.com top r/h search box - input your model number click on go,
On the new page at bottom/left, click on customer service.
On new page left side click on instructions.
On new page you will find instuctions on how to shorten/lengthen bracelet.
Posted on Nov 03, 2008
SOURCE: skagen mesh band shorten
just solved the mystery...U probably have too ..by now....but just in case..
here is a fun link to the solution by an actual user....was actually inspired by him...coz like I said I had mispaced the manual...
http://www.amazon.com/review/product/B0000C9ZBX/ref=dp_top_cm_cr_acr_txt?_encoding=UTF8&showViewpoints=1
I just used my nail file and lifted the locking mechanism and moved it forward...Now I can sleep better tonite....!
Mrs Martin
Posted on Dec 27, 2008
WatchTech
  • 13 Answers
SOURCE: remove a link from an armitron ladies watchband model 6P29
More than 90% of Fossil's watches utilize pins that push out.  You can determine whether or not it pushes out by checking if there is an arrow on the back of the link.  If there is an arrow, you should push the link out in the direction of the arrow.  Usually, the link needs to be pushed at least 25% of the way out before it will be loose enough to pull out.  I suggest using pliers and be sure you pull straight out or you risk damaging the pin.  Be sure to watch for a small tube or 'sleeve' that may be in the link.
Posted on Jan 20, 2009
escapement
  • 2334 Answers
SOURCE: how to shorten the watch band without breaking it
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Apr 09, 2009
  • 183 Answers
SOURCE: shorten watch band
For this you will need a pair of fine tweezers, a small flat blade screw driver and a lot of patience.
Determine how many links you need to take out by pinching the band while it is on the wrist. Once you know how many you are ready to remove the links.
spread the band and you will see that the very end of the links is tabbed. Be careful and fold down the end of the link with your small screw driver. Be careful not to bend anything. You will then need to turn the band over and bend down the tab of the link on the opposite side but right beside the first tab you bent down. Now you will see how the band is held together. If you look into the two tabs you just bent down you will see a small peice of metal connecting the two links. This is a staple. Pull the staple out with your tweezers.
Now go to the exact opposite side and perform the same task. The band should now be apart where you remove the staples from each side.
Now count down the number of links you want to remove and perform the task again.
*Remember that you must do it the exact same way on each side or the band will not go back together.
Once you have the correct number of links out the band will go back together the same way you took it apart.
When folding down the tabs be sure to use gentle even pressure so you dont over bend them and keep the band from moving freely. I usually find it easiest to use the fla part of the screw driver in a gentle pressing motion.
Remember that this take watch makers and technician a lot of practice. Be patient. If you arent patient or good with very small parts, pop into your local jewlery store for help.
Posted on Sep 17, 2009
I need a pin and buckle for 45/7053 m1099 watch.
Hello, Jennifer -
Are you asking about a band for the Armitron M1099 women's wrist watch?
By "pin and buckle" are you referring to the closure part of the watch band and/or one of the thin metal rods which attach the watch band to one end of the watch?
If I am correct in my guess about a replacement band or parts of a band for an Armitron M1099 women's wrist watch, if you have not already contracted Armitron directly about the needed parts, this is the link to the Armitron Watches web page regarding Service Centers:
https://www.armitron.com/pages/service-centers
Near the bottom of that web page, you will see a list of authorized service centers. I suggest you make a telephone call to one nearest where you reside and ask about the replacement parts you need before sending it (insured) for repair. Note: Also ask about the estimated repair cost.
Best wishes.
Apr 02, 2018 | Watches
Where can I purchase a watch band for a 40-8191 Armitron watch.
David, Check the attached links for replacement watch band, Good luck.
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Shop Men Women Watches One Watch Many Faces Armitron
Armitron Watch Bands eBay
http://www.target.com/s/armitron+watch+bands+replacement
Kmart com
Jun 14, 2016 | Armitron Watches
Where can I get a replacement band for an Armitron 40/8225?
Google it! http://store.swatch.com/search/category/accessories?q=armitron+all-sport+40+8225
Search results for armitron all sport 40 8225
Jul 03, 2014 | Armitron Mens 40/8225 Chronograph Digital...
How do i adjust armitron 6p27 watch band
Armitron Watch bands have to have a link taken out. Any jeweler can do it, but I had Kohl's jewerly counter do it for free- But I did buy my watch from them...yet as I remember, they didn't ask if I bought it from them.
Dec 28, 2010 | Armitron Watches
How do you shorten the wristwatch?
Thank you for contacting Fixya.<br /> <a href="http://www.webwatches.co.uk/how_to.htm">http://www.webwatches.co.uk/how_to.htm</a><br /> That link will dirct you to directions for different types of bands.<br /> Best regards. Jewel
Aug 26, 2010 | Armitron Blue Dial Stainless Steel Watch...
I am looking for the watch model number 20/4488sv 6p29. I just bought it today and am looking for an instruction manual
mcdevito75 Here is the contact info for Armitron online www.armitron.com or by phone, 800-840-2933 9--4 PM EST.
Jul 17, 2010 | Armitron 165 watch
How to set date and day on armitron 6p29
Go to the Armitron web site "armitron.com" and select "support" from the menu across the top. Scroll down the watches illustrated and choose the one that is similar to the one you have and download the instructions.
Jan 20, 2010 | JCPenney Armitron Men's Steel Blue Dial...
Watches Logo
133 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
