Question about Ovens
Westinghouse pak143w how to remove element for cleaning
I am replacing an oven element for a Westinghouse POH967s/1. The rear element doesn't appear to have screws on the plate that has the elements going into the back of the oven? It had 1 screw on a bracket...
If they are about 1/4" in size and you have a screwdriver that has removable tips, remove the tip and use it as a nut driver to remove the bolts. Otherwise get a nut driver or 6 sided socket the size you need and remove them.
Mar 07, 2015 | Ovens
How do you change the oven element on a Westinghouse PAJ143W as the element is hidden
To replace Westinghouse PAJ143W oven element you need to look at the back of oven with a torch etc, and you will see the element ends go into the back through clips on each side. At the top of these clips in the middle there is a bit where you get a screwdriver to push down and lever forward and it will come out a bit you do this on both sides. Then lift the clips and element 'both sides'' together and carefully pull forward making sure you're careful with the wiring and pull out a little making sure you stop the wires slipping back while you swap elements. Make sure you put plate at front back in place to keep element up off the bottom, it has two reswts for element on it.
May 20, 2012 | Sharp Ovens
We have a Westinghouse Continental Electric Range KHB30XKI that was installed in the early 1960's. My mother loves it. Tiny kitchen, slide out burners, space saving. Please help me find elements for...
Do the elements look like the pictures here?
http://www.repairclinic.com/PartDetail/Bake-Element/5300210961/2548 bake element
http://www.repairclinic.com/PartDetail/Bake-Element/5300210911/2183 bake elemenet
http://www.repairclinic.com/PartDetail/Heating-Element/5300210972/1070 bake element
http://www.repairclinic.com/PartDetail/Heating-Element/5300210922/609530 broil element
I hope it is one of the these the first 3 are different bake elements the last one is a broil element that the only pull out elements westinghouse used and i appears all are still available from there on repair clinic
I hope i have helped you to find the element you need,
Gene
Aug 15, 2011 | Ovens
Can i change the element myself on a Westinghouse avondale? Dave
unplug oven and unscrew element from inside oven...pull out of rear of stove...if having problem bring out..the rear panel behind oven can come off to help you...remove wires going to element and re-install on new element and put together
Jan 21, 2011 | Ovens
I am trying to install my oven element. I am replacing old one. Oven is Westinghouse Model POL667S
tand pull the elelment out about 3". The element should lead back to a small plate at the back of the onen. Remove the two screwsi at the back of the oven.
Pull the element out about 3" and this will expose the connecting
wires, dissconnect them and remove the element. To install the new one, Just
do the removal procedure from last to first.
Nov 30, 2010 | Ovens
I need the bottom heating element in an old westinghouse wall oven. the model # is OG25HXO
I am not certain what geographic region you are in but... Bake elements are often generic between brands. The key is to match up voltage, wattage, size, bends and terminals. Here are 2 pages of westing house elements:
http://www.partselect.com/PartSearchWizard.aspx?Appliance=Range+%2f+Stove+%2f+Oven&Brand=Westinghouse&PartType=Element+or+Burner&Electrical=Yes
I tried searching using OG25HXO with little success even on westinghouse sites US and AU.
Thanks for choosing FixYa,
Kelly
Nov 18, 2010 | Ovens
I need to replace the element on my westinghouse freestyle 808 oven . where can i order one how do i change the element? thanx
pull the unit out of the housing and rest on a suitable work bench. turn off the power and remove the rear cover you will see the grill element, ring element and the bottom element. depending on whcih one has blown they are relatively straight forward to replace.
as for where to purchase one depends on what country and area you live in. best to search for someone local on line
Aug 19, 2010 | Ovens
I have a Westinghouse 678 freestyle.the element remains on. It may be due to the setting of the clock or timer. i do not have a manual to regulate either as this was not left by the previous owner. could...
I also have the same oven, it turns itself on at random at heats up, also is the oven door easy to remove for cleaning, I dont have a manual either
Jun 29, 2010 | Ovens
Westinghouse POC700M Ultimate One wall oven. We are putting a new element in it. How many wires should connect to the element on either side (ie. looking into the oven left and right)?
if you have not removed the old one yet . reinstall the ones onthe right to the right. and the same on the left . there is on most ovens only two . mm
Nov 22, 2009 | Ovens
Need to know wiring for element
i removed the wires from the fan and element and cant remember which colour wire goes where is thir a pictures for baumatie oven that i can use as a guide
Feb 20, 2009 | Ovens
Ovens Logo
75 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
