Question about Samsung CLX-2160N All-In-One Printer
Wrong colours (only red and blue present) on laser colour copying
Samsung model clx-2160. Produces accurate colour for one third of copy, then remainder comes out in just red and blue. Have tried new yellow toner, cleaning etc.., updated software, but to no avail.
  • gumchops Apr 24, 2009
    Had a feeling that this might be the case! Many thanks for your help!
    alec
  • 326 Answers
It sounds as though you may have to replace the Image Transfer Unit.
Posted on Apr 24, 2009
  • NitrusInc
    NitrusInc Apr 24, 2009
    Hello, In case needed, I found the user manual for your device:
    http://downloadcenter.samsung.com/conten...
    There are instructions, again if necessary, for replacing your ITU.
    I hope this helps better solve your issue.
    Thank you.
Need to override replace toner message on samsung 4195fn
The new units must be replaced but in the service mode you press
menu
menu
and look for ignore toner then the printer will still say toner emty but will work
Nov 30, 2013 | Samsung Clx-4195Fn 4-In-1 Colour...
The problem I have with my Samsung CLX-2160 is that it is only the blue which is not printing evenly - it fades out across the page. The others colours + black are all printing fine & evenly. Any...
you'll need to get to the transfer rollers and de-magnetize them. There should be a "Corona wire" that you can slide from one end of the transfer roller all the way to the other. On the other hand, you may be facing a clog in the blue toner channels, so a thorough cleanup of the entire assembly should help. Or, make a full-blue A4/letter sized document and print it out. Maybe the large amount of blue toner can de-clog the channels. Also, keep the old blue toner if it's not empty because this is not a toner issue.
Jan 11, 2011 | Samsung CLX2160 Multifunction Color Laser...
My samsung clx 3170 keeps jamming up after every copy. You can see where the paper is trying to roll thru. because there is a slight indentation in the paper about a third of the way on each piece of...
Use this link and you will have all the information on your printer you should ever need
http://www.samsung.com/au/consumer/print-solutions/print-multifunctions-copiers/colour-multifunction/CLX-3170FN/XSA/index.idx?pagetype=prd_detail&tab=support
good luck
Nov 29, 2010 | Samsung CLX-3170FN All-In-One Laser...
My Samsung CLX-3160FN has stopped printing colour. I have changed all the cartridges and it will copy in colour, but prints in black and white.
You need to check your document print settings on your PC. Drill through the printer properties menu until you get to the colour settings. At a guess you currently have it set to "Greyscale" rather than colour or auto.
May 03, 2010 | Samsung CLX 3160fn All-In-One Printer
I have a samsung clx-3160fn printer. All toners are ok, espcecially the black one - BUT when I print black&white doc, it is comign out really faded - as if the black toner is low. BUT it is not!! ...
Go to printer properties and check whether you have selected print in grey mode and also check whether you have selected the economic mode. Rectify the same will solve your problem.
Revert back for more assistance.
Jan 31, 2010 | Samsung CLX 3160fn All-In-One Printer
Samsung CLX Printer printing unevenly
it is possible that this is a fuser prob, fuser works applying heat and pressure, if the roller, either the pressure roller or the fuser roller is defective this is most likely will happen too, you might want to  check the number of copies or prints made
Mar 22, 2009 | Samsung CLX-2160N All-In-One Printer
My Samsung Color laser printer indicates all four color toners as 'invalid' despite changing them. It also indicates the imaging unit is invalid. It was bought new and functioned without any problems for...
When you changed the toner did you change the chip for them? you need a special chip for each and evry one of them. I had that problem with my CLX-2160 and i fixed it this way.
Dec 02, 2008 | Office Equipment & Supplies
Copy problems
try to adjust color saturation :
Press Menu/Set, 3, 4.
2 Press ▲ or ▼ to select Red, Green or Blue.
Press Menu/Set.
3 Press ▲ to increase the colour saturation.
—OR—
Press ▼ to decrease the colour saturation.
Press Menu/Set.
4 Return to Step 2 to select the next colour.
—OR—
Press Stop/Exit.
Jun 26, 2008 | Brother MFC 210C All-In-One InkJet Printer
Samsung CLX-2160N All-In-One Printer Logo
221 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
CheckitRight
CheckitRight
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
