Question about Ovens
The function light is no longer bright on my Shacklock oven
2 Suggested Answers
  • 44971 Answers
SOURCE: Shacklock wall oven, model 88102 WO570TD. Where can we get a replacement for non-functioning electronic button pad?
Check with a local appliance parts supplier or Shacklock.
Posted on Dec 29, 2015
How do you replace a spring in the door of a shacklock custom 27 wall oven?
Are you Australian? I am not familiar with this particular oven, but usually there are two types. The type used on domestic ovens is in the base area, above the warming drawer. On a wall oven it would be behind the bottom decorative strip. On a commercial oven they are in the cavity between the outer and inner walls. You access from the rear or from the side.
Apr 22, 2018 | Ovens
My oven does not reach the desired temperature. It was set for 350 and the food did not cook after over two hours. Is this an ignitor problem?
I assume it is a gas oven. It could very well be the igniter. They get old and take longer and longer to light this throws the temperature off. If it is glowing a dull orange then it will need replacing. If it is bright yellow then it should be OK.
Oct 04, 2014 | Ovens
Shacklock chef manual
Usually (with oven unplugged) the burner will tilt up and is held in by a screw or 2 and has 2 wires attached (normally push on terminals). Have you read these with an ohmmeter to see if they are bad? The oven elements need the back cover removed and you will see the element connection and maybe a screw (if the screw isn't on the inside). It too should be checked for continuity before buying new ones.
Dec 06, 2013 | Ovens
SHACKLOCK TM620D double oven - hinge spring broken. Where can I find a replacement in NZ, preerably Wellington?
Try these: http://www.egleys.co.nz/index.asp?pageID=2145828187 http://www.dougsmithspares.com.au/Appliance%20parts%20New%20Zealand%20NZ%20delivery.htm
Oct 28, 2013 | Ovens
Heating elementglowing bright red funny smell
I
make sure the fan is working o/k, because if it is not, then the element will get bright red hot.
If the fan is working o/k, then the element will still get red hot, but not bright red.
If the fan is not working, then it needs replacing.
Jan 15, 2010 | AEG D5701-4 Electric Double Oven
How do you replace an oven door lining
no need of spl.tools it can change by openig screws left bottom of the door
Aug 05, 2009 | Fisher Ovens
Zanussi ZBQ 965(X) Built-in Oven
Sounds to like the oven element has gone, the red light indicates that power is going to your thermostat o/k.
Check the oven element.
Nov 16, 2007 | Zanussi ZBQ665 Electric Single Oven
Ovens Logo
14 people viewed this question
Top Ovens Experts
ashburton
Craig Butler
Craig Butler
Are you an Oven Expert? Answer questions, earn points and help others
