Question about Kitchen Ranges
I would like to engrave my last name on my cast iron Dutch oven. Can you recommend the proper tool?
    Mentor:
    An expert who has written 3 tips or uploaded 2 video tips.
  • 275 Answers
You can buy an inexpensive set of steel letter stamps on Ebay and tap your name into the metal that way. This will not work for knives or other such harder steel.
Posted on Jun 09, 2016
2 Suggested Answers
reg501
  • 413 Answers
SOURCE: cleaning the cast iron grates and griddle
Try This....
Place the grates in a sink of hot, soapy water and let soak for 15-20 minutes. For tougher stains, add a cup of sudsy ammonia to the water. Make sure grates are thoroughly dried after each cleaning. After the cleaning process, Lightly coat the bottom of the grates with a cooking spray and then blotting them dry.
Or
If you self clean the oven on occasion, put them in the oven when running the self clean cycle.
Posted on Jun 22, 2008
Is there a specific tool recommended to loosen the set screw so I can change the tip? It doesn't mention anything in the directions
Engraver Kit / Model: 290-01 - Dremel.com
www.dremel.com/en-us/Tools/Pages/ToolDetail.aspx?pid=290-01
DremelFeaturing a replaceable carbide point, Dremel's engraver kit lets you work on metal, ... http://mdm.boschwebservices.com/files/Dremel Engraving Tool 290 ...
Amazon.com: Dremel 290-05 120-Volt Industrial Engraver ...
www.amazon.com/Dremel-290...Engraver/.../B000VZ...
Amazon.com, Inc.
Rating: 4.2 - ‎62 reviews
Dremel 689-01 11-Piece Rotary Tool Carving and Engraving Kit .... tips and came from a different source ie there is no Dremel 290-05 tool. ... On the very first tool, afterengraving the serial number, the diamond tip began to loosen and slip out. ... When I returned to the engraver to tighten the set screw the tool fit perfectly, ...
Home Depot Dremel 120-Volt Corded Electric Engraver ...
reviews.homedepot.com/.../dremel-120...engraver...tool.../questions.htm
Afterwards you can remove the paper and glue with a simple adhesive remover or alcohol. ... I use the Dremel Electric Engraver Tool to engrave manufacturers name and model .... hardware store and they should be able to supply a new set screw for you. .... The 290-01 Engraver is for engraving applications only and is not ...
FAQ - Customer Service - Dremel
www.dremeleurope.com > Home > Customer Service
Dremel Europe
Dec 16, 2015 | Dremel 290 - 01 Engraver
I had a skillet pan made of cast iron and when I saw it now, it has rusted. Why does it rust?
Any kind of iron implement is at risk of rusting over time, especially if it is exposed to moisture. In the case of cast iron cookware it is possible it was not seasoned properly when it was new, was stored in a damp area, soaked in water, or it was washed with soap which is not recommended since it will remove the oil coating protecting the skillet. The good news is rust can be cleaned off. After cleaning the rust though, the pan should be seasoned to prevent this from happening again.
Here is a link to advice on cleaning and seasoning your cast iron skillet:
There's Rust on my Cast Iron
Sep 07, 2015 | Grilling
Can I use Cast Iron Pots and Skillets on my new Frigidaire Gallery Stove Top?
Hello friend, thanks for your post!
It is not recommended to use any cast iron pots or skillets on a Frigidaire smooth top. In your manual it provides the best type of cookware material and cast iron is a poor heat conductor. Due to the weight of the cast iron it can cause scratches or damage the cooktop. I hope this information has been helpful. -Matt
Oct 09, 2014 | Kitchen Ranges
What are the dimensions of t his dutch oven?
According to Amazon, the dimensions are as follows: 15 inches in length, by 13 inches in width, by 9 inches in height/depth. It also weights 13.8 pounds.
Feb 16, 2014 | Tramontina Gourmet Dutch Ovens: Enameled...
Find artifact images
In cooking a dutch oven is the original slow cooker. Usually made from cast iron, and can be used on top of a wood burning stove, in a wood burning fireplace, over a campfire, or with coal/charcoal. Some have domed lids, while others have a flat lid with a raised edge (aka flagged lid) which is idea for holding charcoal above the kettle. This allows for heat both above and below the dutch oven. These are generally available in stores such as Cabela's, BassPro and others.
Dec 02, 2013 | Ovens
How do you clean a wok without ruining it?
After use;
1. Rinse your wok in warm soapy water and remove any food from the inside surface.
2. If you need to clean the wok more thoroughly you can do it in hot water but don't use any soap or chemicals.
3. Dry the wok with a towel
4. A properly seasoned wok won't give off any black smudges. If yours does, it may still be dirty or just need to be seasoned again.
Feb 18, 2013 | Home
What are the advantages of a cast iron wok?
when cast iron woks are seasons properly, they help create the special 'wok style' flavor. They also have good heat retention and cook the food evenly.
Feb 18, 2013 | Home
I ruined the enamal finish on my cast iron dutch oven. I put it in the dishwasher. Can I still use the pot and can I fix the enamal?
I wouldn't use it. Often these things are made with a Teflon lining and you wouldn't want that or any other non edible material in your food. Plus, adding heat and cooking for long hours could damage the finish even more.
Jan 29, 2013 | FOOD NETWORK 3 1/2-Qt. Enamel Cast-Iron...
Can I use cast iron on a glasstop electric range?
yes it is true, the heat transfer will be to great and will crack or explode the glass. definately not recommended.
Nov 08, 2009 | Whirlpool 30" Self-Cleaning Freestanding...
Cutting cast iron soil pipe
Phil, I recommend a ratchet snap cutter as it will allow you to cut the pipe in a clean manner. These are available for rent at most major home improvement stores in the US. One can also rent one at a tool rental company. I rented mine for $35.00 the bulk of which was a deposit on the tool. Just a reminder when buying the coupling device ensure you ask for or get a 4 inch cast iron to 4 inch PVC coupling. A bit of vaseline will help you get the neoprene coupling to seat properly with the PVC if you encouter resistance. Good luck. If you need more assistance let me know.
Sep 25, 2008 | Plumbing
Kitchen Ranges Logo
111 people viewed this question
Top Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Kitchen Range Expert? Answer questions, earn points and help others
