Question about Maytag PTB1954GR Top Freezer Refrigerator
Freezer is working but main fridge is not getting cold
The Freezer is working but the main fridge is not getting cold. How do we access the vent to see if they are working or not. This is a under 10 yer fridge so would be nice to be able to fix it.
Thanks in advance for any help you can provide.
  • 1 more comment
  • Anonymous Apr 28, 2009
    Fan in the freezer compartment is not running, is it supposed to run non stop? Fresh food section is not getting cold. No ice build up. Freezer is freezing.
  • Bailey's Appliance Service
    Your unit utilizes a simple mechanical damper in your fresh food vent. If the freezers appears cold, and the fresh food compartment is too warm, check if the "inside" back wall of the freezer compartment is covered with heavy frost.
  • Mark Nichols May 11, 2010
    Here is a couple questions to narrow the problem.
    1) is there seem to be a frost build up on the back of the freezer?
    2. sound like the fan is running inside the freezer?
    3. do you feel any ice or debri in the vent in the fridge in the back on top?
    if no to any then explain any other findings and i need the model number as well
SOURCE: freezer is cold fridge is not
fridge thermostat which adjusts the cold air flow by means of opening and closing a damper at the back of the inside of the fridge is faulty. Try forcing the by-metal plate open slightly at first until you get near the required temperature.
Posted on Jul 30, 2007
  • 14 Answers
SOURCE: Freezer just not getting cold enough
The defrost heater element is bad, Do you know enough engineering to tackle the job ? You will need some hand tools and a spare Saturday afternoon .. Alternaively you could call a technician...
Posted on Sep 17, 2007
Benimur
  • 6966 Answers
SOURCE: Fridge not cold...freezer is ok.
Hi and welcome to FixYa,
Initially, this normally would point to the fan not spinning. The function of the fan is to draw the cold air from the freezer and force it through the vents to the refrigerator area. Even having said this, the fan is activated by the logic controller based on the the thermostat setting of the refrigerator and condition of the door (it must be closed).
Good luck and Thank you for using FixYa. Happy Holidays.
Posted on Dec 11, 2008
  • 118 Answers
SOURCE: admiral fridge, freezer won't stay cold
Check the condenser fan, listen and see if it kicks on, if it doesn't then find someone that know how to take it apart and change them.
Posted on Jan 31, 2009
  • 686 Answers
SOURCE: fridge is warm even when i adjust temp. control.freezer is good.
if your fridge has 2 set of dials one numbers and the other letters than you need to adjust the dial that has letters on it. If the fan in your freezer is not blowing, then it won't force the cold air from the freezer to the fridge. Make sure fan blows then adjust the letter knob.
Posted on Feb 17, 2009
Freezer is cold, fridge is warm; replaced main board already
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. Make sure this fan is running. You may have to hold the door switch in for it to run. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp.
The problem could be the electronic control if you have one or the mechanical linkages.
Apr 25, 2010 | GE 19.5 Cu. Ft. Bottom-Mount Refrigerator...
Drawer temperature is ten degrees cooler than main part
This is affected by whether the fridge is bottom freezer or top freezer.
The drawer temperature is controlled by air drawn from the freezer. There is usually a vent control to adjust the amount of cold air that gets pumped into the drawer.
Do not allow food or bags to block the vents where the cold air is injected into the main compartment.
Open the drying vents more on the drawers if there are any.
Mar 20, 2010 | LG Refrigerators
Freezer cold, fridge isnt. Vent issue. Please Help before thaw!
Is there any ice/snow whatsoever built-up on the rear panel of the freezer ????(very important to know this).
If so, you have a problem with the frost free part of your fridge,causing it to ice-up,
and blocking the air flow to the fridge section.
Repost, and we should be able to go from there.
Wigo.
Mar 04, 2010 | KitchenAid Refrigerators
Refrigerator section not getting cold - air vents not blocked - cold air coming into freezer but not out of vent at top/rear of fridge
Evaporator fan may not be running. This fan distributes cold air throughout the freezer and to the refrigerator. The fan is likely located behind an access plate at the top of the freezer. If it's running, you should be able to hear it. If you can't hear it, open the access plate and look at it. If it's not turning, you will likely have to replace the fan motor.
Oct 20, 2009 | Whirlpool GB2SHKXL Bottom Freezer...
Maytag wide by side MZD2667HEW freezer works fridge does'nt
Was it the damper control you replaced and it's still not adjusting the vent(damper)? And is the cold air from the freezer being blown through the vent by the fan in the freezer.
The circuit board mainly controls the defrost timing and the fans. I don't know that it would solve your problem.
Sep 21, 2009 | Maytag MZD2667HE Side by Side Refrigerator
We have a freezer bottom fridge- the freezer is working but the fridge stopped working. We tried cleaning the vents and unplugging and re-plugging. It sounds like it's on but there's no cold air on the...
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it.Make sure the fan is running. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 29, 2009 | Amana Easy Reach AFD2535DE Bottom Freezer...
Freezer works, fridge part does not
The fridge gets its cold air from the freezer through a vent(damper) between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp ..
Aug 21, 2009 | Refrigerators
Refridgerator side not cold freezer side fine
Difficult to properly diagnois with such a brief description, but try the following as a good first step at correcting the problem. Reset the freezer and fridge thermostat settings at the factory default. Also, check the freezer section to make sure nothing is blocking the cold air supply vent into the fridge, do the same on the fridge side too.
Normally is the freezer is working fine, and the fridge is warm, it can be due to either a blockage of the cold air cross vent by items in either the freezer, fridge, or both, preventing proper cold air flow from the freezer into the fridge. Also, check to see if the cold air vent is not frozen or obstructed, with a fashlight (you;ll need to remove stuff from fridge and freezer to make this possible to check.
If the vent is not obstructed and you can clearly feel cold air passing from the freezer into the fridge, it is possible that the cold air vent control has ceased operating properly and needs to be replaced. Usually though this type of problem is caused by people over stuffing things into the freezer section and blocking the cold air cross over vent. Hope this helps.
Jul 13, 2009 | Maytag MSD2756G Side by Side Refrigerator
Refrigerator not cold/Freezer cold.
The fridge gets its cold air from the freezer through a vent between the freezer and fridge.The fan in the freezer blows air through it. There is a flap you adjust with the fridge temp. control. Make sure it's opening and closing when you adjust the fridge temp .
If the evaporator coils behind the back panel of the freezer are icing up because of auto defrost failure that will stop the circulation of cold air and eventually affect the freezer too.
Jul 03, 2009 | Kenmore 73502 / 73504 / 73509 Bottom...
MY FREEZER IS GETTING TOO COLD AND THE FRIDGE IS NOT GETTING COLD AT ALL
In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Oct 08, 2008 | Whirlpool Refrigerators
Maytag PTB1954GR Top Freezer Refrigerator Logo
47 people viewed this question
Top Maytag Refrigerators Experts
Bailey's...
Bailey's...
Shehu Pro
Shehu Pro
Are you a Maytag Refrigerator Expert? Answer questions, earn points and help others
