Question about Dwin TransVision 3 Plus Multimedia Projector
Dwin lamp turns off
My Dwin transvision 3 is about 3 years old. After about 45 minutes the picture becomes unstable, flashes and gets unclear. If we turn it off, then on again, the picture is fine for a short time (about 2 minutes) (if the projector is started cold its fine for 45 minutes). Should I send it back to Dwin (the repair charge is approx $500!!) or can I fix it myself?
  • rick7908 Apr 28, 2008
    After the projector is running about 1.5 hours it starts flashing and the picture looks like a negative. Shut it off and wait 10 minutes and you can finish watching the movie. Its not the source it happens on dvd or cable inputs.
  • Wepcar Jun 14, 2008
    I have a four year old Dwin TV-3 which has worked just fine until last night. I turned it on and the projector came on as normal. The bulb lit and I had an image for about one minute. Then the bulb went out, but the fan kept running. I have 2584 hours on the bulb so I have been expoecting it to go sometime soon, but I would think that it would stop lighting altogether if it had failed? Whne I turned it on again, the same thing happened. The bulb came on and then went off within one minute. Is this typical for the Dwin when the bulb is failing or is something else going on? I would appreciate any advice someone might have. Thnaks in advance. WP
    Cheetah:
    An expert who has answered 20 or more questions within one hour.
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 45 Answers
I design and implement switching power supplies for the commercial lighting industry. I also own a DWiN Transvision and have opened it and worked on it several times. I believe I can answer this question.
The DWIN projectors use a proprietary switching power supply to strike the lamp and keep it burning. The power supply is extremely sophisticated and maintains tight voltage and current tolerances. This is important because the halides in the lamp are damaged by power supply fluctuations. The halides can often be seen in an unfired lamp, they appear as small specks of dirt or tiny beads inside the lamp envelope. When a metal halide lamp is struck, the halides (which are rare earth elements) vaporize and cling to the inner wall of the lamp envelope. The mixture of halide gas in the lamp is what determines the color temperature of the lamp, as well as the accuracy of the lamp across the entire color spectrum.
One of the ways that DWIN is able to deliver such great color is because they use a lamp which delivers this great color across the spectrum, but, as I pointed out earlier, can be damaged by fluctuations.
The power supply contains three switching sections and five references for such things as input and output voltage for each psu section, as well as overcurrent demands from the lamp.
From my experience, your lamp(s) are all exhibiting issues that require replacement.
Posted on Nov 27, 2008
I have a transvision 3 that starts up and runs fine. at some undetermined point the picture will flash back and forth from snow to the clear picture????
prestopete here...no kidding..I have the same problem...Can't find any cables. I do have a source for bulbs if you need.
Mar 25, 2012 | Dwin TransVision 3 Plus Multimedia...
I have a Dwin TransVision 4 that is not working. It started out with us being able to watch a movie for about an hour and the bulb shutting down. I finally ordered a bulb from Dwin (at 458.00!!) and...
honestly it sounds as if a capasitor is overheating and once it overheats the machine is shutting off.... I myself would be able to look at it and see if this was correct or not. i am not sure how familliar you are with these types of things, probably best to take it in and tell them exactly what is wrong...
Feb 26, 2011 | Dwin TransVision 3 Plus Multimedia...
Plays for couple minutes or hours, then goes
Have you considered checking the lamp? It could be going bad.
Nov 15, 2009 | Dwin TransVision 3 Plus Multimedia...
Replacment of bulb on dwin transvision 3 plus ceiling mounted
It is fairly simple. Take the unit down as you need to get to the underside. There you will see the retaining screws that hold the cover on. Remove these and open the unit. Inside you will see the bulb and mounting bracket. Off hand I don't remember exactly how it is held in place but there are a number of screws and a lead to disconnect to remove it.
Mar 09, 2009 | Dwin TransVision 3 Plus Multimedia...
Projector turns on but no light or image from lens.
The bulbs do not always look broken when dead. You say it is used often. The life of a bulb is around 1400 hours I believe. This normally equates to a year or two depending on your usage levels. Did you notice your image getting dimmer in the months before it stopped working? This would be a good sign it was in need of replacement. Are the lights flashing very rapidly or blinking slowly? If they are flashing very rapidly this indicated the bulb will not fire and needs replacing.
Jan 16, 2009 | Dwin TransVision 3 Plus Multimedia...
Picture becomes unstable after turning it on (lack of color,
The problem is with overheating!. after a few years the fans accumulate dust and "stuff" and don't work as well. Get a can of compressed air and blow out all the ports and fans. I take the cover off and with everything cool, I blow out all the internal fans also. The 3 big fans on the back are easy to remove and clean and get spinning again. Usually this fixes the issue for several months but eventually, professional cleaning may be needed at DWIN.
Dec 23, 2008 | Dwin TransVision 3 Plus Multimedia...
I HAVE DWIN TRANS3 PROJECTOR 3 YEARS OLD PROJECTOR STOPS WORKING IN 5 MINS, FIRST PICTURE GETS FUZZY AND NO PICTURE BUT SOUND STAYS ON, I ALREADY PUT NEW BULB BUT SAME THING
it's time to clean it out. the colorwheel might be going and if it doesn't spin to keep in sync with the dmd chip, the lamp goes out.
Nov 21, 2008 | Dwin TransVision 3 Plus Multimedia...
Bulb or power problem?
You have to order it on the website and they are terrible about getting back to you. Worste customer service in the world. Terrible
Jan 03, 2008 | Dwin TransVision 3 Plus Multimedia...
Video then Black
the colorwheel is going bad and needs replacing.
Jul 27, 2007 | Dwin TransVision 3 Plus Multimedia...
Degrading picture with my Dwin projector
the colorwheel is going bad and needs replacing. the colorwheel needs to spin fast enough to sync up with the dmd chip. if it cannot, the pic goes bad then off. the flashing is the colorwheel trying to catch up.
Jul 05, 2007 | Dwin TransVision 3 Plus Multimedia...
Dwin TransVision 3 Plus Multimedia Projector Logo
490 people viewed this question
Top Dwin Office Equipment & Supplies Experts
k24674
Marvin
Marvin
Are you a Dwin Office Equipment and Supply Expert? Answer questions, earn points and help others
