Question about Microsoft Office Excel 2003 for PC
How to get a cpu usages and up dated in every one hour in the same syste.
Excel solutions
Posted on Apr 24, 2009
100% cpu usage
In Task Manager, go to the Processes tab and sort by the CPU column. See what is hogging up all your CPU. It may be a virus, if so, I recommend downloading Malware Bytes and doing a full scan. Warning, it could take several hours to scan depending on the size of your machine. Good luck!
Nov 23, 2013 | Patrick M. Kolla Spybot - Search &...
Tip
How to Protect PC from Overheating?
Laptop over heating which is also known as Thermal Overload.This is mainly due to excess usage of CPU(More than 60%) for a long time.
To check CPU usage Right click on Task Bar>Select Start Task Manager>Performance.
or
Shortcut Ctrl+Shift+Esc
If your CPU usage is more than 50% you need to close some applications which are using 20++% CPU.
To check application which are using 20++% CPU
Right click on Task Bar>Select Start Task Manager> Processes
Search in this dialog box for programs which are using 30++% CPU
You need to close this application to prevent PC from over heating.Actually %age usage indicates load to CPU by the application.If load is to much CPU is to processes at faster speed which in turn increases temperature of CPU.
To close the program select the program,and select End Process.
If didn't found any program using 30++% CPU in this dialog box.
Select Show process from all users. and search in this dialog box and close the program.
Caution:some times your system also uses 30++% CPU inn some processes like anti virus scanning,at this if you closed the program your PC may shutdown.At this time you need to restart the PC.
This usually happens for out dated anti virus or incompatible programs.
There are some other factors like Graphics Properties and Graphic Memory,Display size, Processor type,etc.At this time its better top use a cooling pad.
Some program like camera drivers,Simulation softwares,games uses 50+% CPU.This is common these programs need to process large amount of data at short interval time which increases CPU usage but this is normal.
The processors properties are tested at 140*c so no need to worry.If the CPU exceeds the limited temperature PC will shuts down automatically,and after cooling you need to start the PC.
Thank you...:)
ANY SUGGESTIONS...?
on Feb 16, 2011 | Computers & Internet
Intel r pentium r 4 cpu 1.80ghz driver download free
try this link Home Drivers Manufacturers Device Types DriverScan Search Contacts Search Driver Name
Newest Drivers:
More
OPTi Audio 16 OPTi Audio 16 High Definition Audio-Ger?₪t Broadcom NetLink (TM) Fast Ethernet Intel(R) 82801G (ICH7 Family) USB Universal Host Controller - 27C8 MORE ... Top Manufactures
Click here to view more
Intel Dell HP Sony ASUS Top Device Type
Network Sound Card Webcam Printers Modem Useful Links
DriverIdentifier
Drivers ' Microsoft
Intel(R) Pentium(R) 4 CPU 1.80GHz
Driver Information Old drivers impact system performance and make your PC and hardware vulnerable to errors and crashes. We suggest you to download the latest drivers. Keep your Intel(R) Pentium(R) 4 CPU 1.80GHz driver upto date to maximize its performance, fixing any error related to driver. Download Now (1MB)
Intel(R) Pentium(R) 4 CPU 1.80GHz is a windows driver. It's released by Microsoft Type: Processor
Version: 5.1.2600.0
Date: 2004-04-01
Hardware IDs: ACPI\GenuineIntel_-_x86_Family_15_Model_1
*GenuineIntel_-_x86_Family_15_Model_1
*GenuineIntel_-_x86
Compatible IDs: ACPI\Processor
The following operating system has used this driver: Microsoft Windows XP Professional
Microsoft Windows XP Home Edition
Microsoft Windows 7 Ultimate
Microsoft Windows 7 Professional
Microsoft Windows XP Professionnel
Microsoft Windows Vista?™ Ultimate
Syst?©m Microsoft Windows XP Prof
This download is valid for the product(s) listed below:
Nov 22, 2012 | Intel Computers & Internet
Is high CPU usage will make battery life reduction?
Anything that requires more activity from your CPU will shorten the battery charge. It is eating power. I am not sure about "Magician".
Jan 13, 2012 | HP Computers & Internet
Laptop dell inspiron n5010 hanging suddenly
There are many things that might cause your PC to run slowly or restart at time and then. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
To check your CPU and memory utilization, run Task Manager. You can start Task Manager by pressing CTRL+ALT+DEL and then clicking on the Task Manager Button. In Task manager, click on the Performance tab and check CPU Usage and PF Usage. PF Usage is an indicator of memory usage. If one or both of these is high, click on the Processes tab, and sort the columns by CPU or Memory to see what processes are consuming the resource. If you are not sure what the process "Image name" is for, Google the name and you should find what the process is for.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. Here is a few good virus scanners that you can run to check your PC:
http://c74b6qq6lbo8zlievtv2q810g1.hop.clickbank.net/?tid=DMWDH6W3
Nov 24, 2011 | Dell Computers & Internet
A problem has occured in my pc.it starts normally.but after 15-20 min. it shows blue screen written on it-starting dump of physical memory,contunies till 100.and reboots but doesnt start again.it starts...
Switch On your PC/ Laptop and log in to windows.
Go to 'Start'--->Programs--->Accessories--->System Tools--->Click 'System Restore'
A 'System Restore' window will appear.
Here you will have to check "Restore computer to an earlier time' and click Next
Now you will find one Month Calendar window with Dates below, go to the previous month by clicking the '<' sign in the upper left hand corner of the Month Calendar and select any date that you see in Bold.
Note: It is better if you could remember from which date you are facing the issue, try to select a date prior to that date.
The detail of that particular date should show "System Checkpoint" and time on the right hand side box. Select that date.
Now, Click on Next and System Restore will start and windows will take a reboot.
After reboot
Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
Now restart windows.
After reboot Just do the following steps and your issue will be resolved.
1) Delete all unwanted data from Drive C.
2) Delete all data that you have copied from Drive C to External HDD
3) Open My computer and go to Tools---> Folder Options---->Click on View Tab----> Check 'Show hidden files and folders' and select OK.
4) Go to C:\Documents and Settings\Administrator\Local Settings\Temp and Delete everything that you see inside Temp Folder
5) Go to C:\WINDOWS\ here you will find folders like $hf_mig$, here you will have to Delete all the folders starting and ending with $ sign.
6) Empty Recycle bin and restart the PC and your issue will be resolved.
There are many things that might cause your PC to run slowly. It could be a fragmented disk; fragmented registry; a virus, Trojan, or spy ware; high CPU and/or utilization due to too many programs running; high disk I/O; or something else.
If your CPU and memory usage are reasonable, then you may have a different issue. Even if you running anti-virus software, it may be beneficial to scan your PC with another scanner to check for viruses. No anti-virus software is 100% perfect at catching everything. Here are a few good free online virus scanners that you can run to check your PC:
http://security.symantec.com/sscv6/home.asp?langid=ie&venid=sym&plfid= 23&pkj=RRJEDTKJBTVISBYWWYP
http://onecare.live.com/site/en-us/default.htm
http://www.eset.com/us/online-scanner
http://www.pandasecurity.com/homeusers/solutions/activescan/
An excellent free utility for overall system maintenance is Advanced System Care Free ( http://download.cnet.com/advanced-systemcare-free/3000-2086_4-10407614 .html ). I use this utility on a regular basis.
Aug 25, 2011 | Computers & Internet
My Dell PC shutdown by itself. After troubleshooting, it still fails to come up. How can I make it work?
System Restoring Windows 7
1. Open the Start Menu.
A) Click on All Programs, Accessories, System Tools, and System Restore.
2. Open the Control Panel (All Items View).
A) Click on the Recovery icon.
B) Click on the Open System Restore button.
A 'System Restore' window will appear. Here you will have to check "Restore computer to an earlier time'
A) Click on the Next button
Now you will find a window with Dates, Description and Type,
Now, Click on Next and System Restore will start. Click on the Finish button and windows will take a reboot.
SYSTEM RESTORE Windows XP
Switch ON the PC, boot the PC in 'Safe Mode' by continuously tapping F8 button after you switch On.
Let windows boot in Safe Mode and log in to windows.
After reboot your problem should be resolved.
If you feel that my answers have helped you getting solution to your problems then please give a vote.
Thanks.
Jul 08, 2011 | Dell Computers & Internet
I am not really sure if this caused by the fan performance, but I can confirm that my laptop dell inspiron 1420 is very hot after running about 1 hours.. and often my CPU usage reach 100% when I use Vista...
First, I appreciate the details provided in your question. Thanks!
The specification of your laptop are fine and enough to run and support Vista. It is true that greater number of processes and CPU usage causes, but normally the machine can handle it well if it gets proper ventilation.
Laptop heating issue generally occurs due to fan failure, which may damage the system, if not checked properly. Another cause of overheating is the dust present inside the laptop, which clogs the fan and heatsink. I suggest that you should get you laptop checked by a professional for servicing (if required). I believe immediate action is required to prevent any damage to your machine and data.
Hope it Helps! Let me know if i could be of any further assistance.
CreativeTECH
Nov 25, 2010 | Computers & Internet
We have a samsung SP-a400B DLP Projector which we need to set the lamp hours to Zero following a lamp change. How do you reset the lamp usage hours to Zero ?
Not a good idea. It is better to just use a tab for the new installation. Hourly usage is not an exact science and the lamp life is approximated based upon tests. The true life of the system with the tab of the time and date of replacement is much better suited for a technician...
Jun 10, 2010 | Televison & Video
I have a AcerPower FH P4 -- 100% CPU usage all the time prob...
Boot your PC into "Safe Mode" (tapping the F8 key on boot to get to the option) and run a full/complete Virus scan with Anti Virus with up to date virus definitions and see what that yields.
Feb 09, 2009 | AcerPower FH - P4 631 3 GHz (S6463624) PC...
Microsoft Office Excel 2003 for PC Logo
26 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Piyal Perera
Piyal Perera
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
