Question about Pyle Pl1157rd Led Brake Lights Light Bulbs Pl1157rd
Brake light allwas on and gas gage moves alot
My brake light is alwys on but no problem with the brakes. and my gas gage likes to do a lot of moving not sure y never did befor. does enyone no a good way to fix this anoying problem its a 1990 chevy pick up 305 v8
  • justin_rober Apr 24, 2009
    thanks that help alot.
    Problem Solver:
  • 10 Answers
Make sure that you ground the brake at the end of the vehicle with the supplied wire then check if it is still on look at the switch at the pedal that activates the light as for the fuel gauge it may just need a new sending unit if everthing is attached right at first
Posted on Apr 24, 2009
Sticking brake caliper
Alot of things could cause it. If your brakes are binding, then your brake caliper should be inspected to see if the pistons returns or not. Also the flex hose should be checked.
There is a possibility that you need to calibrate the steering angle sensor and the yaw rate sensor. If you have your abs light ON on your instrument cluster, kindly run a scan on the chassis.
Oct 20, 2013 | Chevrolet Cars & Trucks
Brakes lock up when driving
It appears that you have a brake cylinder that is not returning to its default position when you take your foot off brake pedal.
Check for that.
Jun 10, 2017 | Hyundai Sonata Cars & Trucks
Driver side blinker goes double time when headlights are on and all the bulbs in the rear flash at a different time. When the brake pedal is pressed driver side brake light goes out and both reverse l
You have a broken Ground wire From Body to Frame . You Should Have a Heavy Braided Ground wire From Engine Block to Frame on Pass side, Then You will have another one that goes from firewall to engine , like at the back of the Head on passenger side to a screw to firewall.,....One of these is Broken,Loose, Corroded.
Feb 29, 2012 | 1998 Chevrolet K2500
I need a transmission,and need to no if my car is an awd or fwd also when i push on the brakes to stop if feel like the pad is push my feet back up and jerking what do that mean awd light comes on...
if you have an awd light coming on then you have an awd transmission(car).if the brake pedal is pulsing while pushing on it to come to a stop then it sounds like the rotors are warped and need replacing.this can be caused by alot of heat build up on the rotors,a lot of miles on them,the wheel nuts were not torqued when tightened,rotors are rusting and coming apart,a loose brake pad moving around.get the brakes checked.
Jul 17, 2011 | Buick Rendezvous Cars & Trucks
Brake light not coming on with foot brake. have to apply a lot of pressure on front brake for brake light to come on
Loosen the bolts that hold the front brake master cylinder and move the master cylinder slightly towards the center of the bike. "Adjust" the brake light by moving the assembly out and back until you get it like you want. Another method requres disassembly of the brake lever. Remove the E-clip from the bottom of the lever pin and remove it. Take the brake lever out. There's a plunger with a tab on it that actuates the front brake light switch. By bending this tab, you can adjust when the light comes on. Bend the tab forward to make the light come on earlier.
Good luck
Steve
Aug 16, 2010 | Harley Davidson FXST Softail Standard...
Handbrake light comes on but fluid level is topped up
When you engage the handbrake the handbrake light should come on. It has nothing to do with the fluid level.
If it is coming on without the handbrake being applied, then you possibly have:
1. A faulty switch. The switch activates the handbrake light.
2. A stuck braking cable. To eliminate this place the handbrake on and attempt to back-up (reverse). It should not move with your foot off the brake. Do not put your foot on the gas (accelerator). Place your foot on the brake and disengage the the handbrake. Again with your feet neither on the gas or brake. The vehicle should move backwards.
In all likleyhood the switch is bad. It is easily located right under the handbrake arm and easily removed and replaced.
Let me know if this helped, or if you have any additional information, problems, or questions. Feel free to contact me at FixYa.com!
Jan 29, 2010 | 2003 Ford Focus
Car wont acceleart fast
Yhe emergency brakes is engaged. Need to check back brakes, check E,R< brake cable.
Nov 10, 2009 | 2005 Ford Ranger
Brakes are locked up.
If you have disk brakes. I would suggest you remove inspect one brake by removing the wheel. Then remove the brake pads using a piece of board and a 6" clamp push the calaper mechanism in and then apply pressure to the brake pedal. If the calapier wont move out .The brake calapier's may be defective.
Jun 11, 2009 | 1999 Dodge Durango
Transmission moves when I step on the gas hard. It's like the lines are clogged.
The transmission moves? In what way? If under hard acceleration your motor mounts could need looking at. Put vehcle in gear parking brake on foot on brake pedal and give it some gas then sudenly let up on gas. If you feel a thud, the tigh motor mount is probably your culprit. You can test the left mount same way but be extra carefull, your psrking brake won't hold as well so use the foot brake when accelerating . Acceleration need not be alot, just enough to make it do what you feel or hear. Motor mounts are not a major problem. good luck
May 18, 2009 | 1995 Ford Windstar
1999 chev corvette
No nothing like that, but there is a feature that will no allow you to get out of park unless the brake pedal is pushed and the brake lights are working, check the brake light circuit.
Oct 04, 2008 | 1999 Chevrolet Corvette
Pyle Pl1157rd Led Brake Lights Light Bulbs Pl1157rd Logo
64 people viewed this question
Top Pyle Car Audio & Video Experts
xxxxxx xxx
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pyle Car Audio and Video Expert? Answer questions, earn points and help others
