Question about Ricoh Priport VT6000 Copier
MISFEEDING - Ricoh Priport VT6000 Copier
Paper remaining on the transport path: The multiple feeding of preceding paper caused the misfeeding of upcoming paper.
Fan the stack of paper before loading it in the printer. Clean the paper dust off the pickup roller with alcohol and a swab.
Oct 04, 2017 | The Office Equipment & Supplies
What is causing misfeeding?
Either the paper is slipping and not reaching the sensors at the right time. or a sensor flag is broken/missing/out/stuck and the device stops the paper thinking there's a jam. Clean all the paper feed rollers with a clean lint-free towel and water only. See if that will improve the grip of the rollers. If they appear shiny, replace the rollers. They are too worn out to continue working properly.
Feb 29, 2016 | Xerox Phaser 6360 Laser Printer
E-studio 282 e130 error code
Upper drawer misfeeding (Paper not reaching the
1st transport sensor):
May 12, 2014 | Toshiba Office Equipment & Supplies
The paper is misfeeding to the right
clean the rubber roller carefully so it can guide the paper again properly canon ink cartridges
Dec 03, 2011 | Canon Pixma Mp250 Allinone Inkjet Photo...
How do i solve the misfeeding of my epson r230?
epson r230 print double edges printing result very bad please give me how o solve this problem.
thanks.
ashok kumar
Jun 14, 2010 | Epson STYLUS R230 InkJet Photo Printer
Regarding my Panafax UF-8000: Why does evrey page misfeed? I started with 24lb white paper and switched to 20lb, but still it is misfeeding.
clean the rubber feed roller/rollers that actually feed the paper from the paper tray.. clean soft lint free cloth dampened with water
Mar 31, 2010 | Panasonic PanaFax UF-8000 Laser Fax
Paper jam
What that sounds like is misfeeding.
Remove your paper tray and take a soapy cleaner, like formula 109 or fantastic and thoroughly clean the rollers.
If that helps and it statrs misfeeding in a day or two, you probably have slick rollers.
Watch inside the paper feed. Make sure the paper is going against the rollers then see if they just spin on the paper.
Mar 27, 2008 | Canon imageCLASS D860 All-In-One Laser...
Copier malfuntion.
I think we need a bit more information.....like make , model, where is the misfeed or jam (they are different) over to you
Feb 23, 2008 | Office Equipment & Supplies
18 people viewed this question
Top Ricoh Office Equipment & Supplies Experts
Adorjani Laszlo
quennie732
fares
Level 1 Expert
Are you a Ricoh Office Equipment and Supply Expert? Answer questions, earn points and help others
