Question about Watches
Fossil watch band adjustment
I have a fossil PR-5338 watch and would like to adjust the band. On the inside of the band some of the links have small arrow heads pointing to the outside of the band. I have applied pressure and there is not a release. On the outside of the the same links I see what looks like bar pins but they do not press in. I have not use my full strength in either case as I do not want to mark the band. What else should I try?
SOURCE: i need to replace a fossil watch band
call foleys or dillards and ask for the number to the company
and thy can assist you
Posted on Jan 06, 2008
  • 4 Answers
SOURCE: trying to shorten the band
You need a small, (smaller than the pin hole) punch to force the pins out of the band. Since the arrows point in both directions you can push from either direction. Push enough of the pin out to be able to grasp it with a pair of small pliers and remove it. Do that on both sides of the link, replace the extra with a small hammer and you're done.
Sarvadrk
Posted on Jun 19, 2008
SOURCE: Replacement Watch Band
I also have an Adidas watch, but cannot find a replacement.
Unfortunately, very unique for the contours around the body of the watch. Where can I find a replacement watchband?
Posted on Aug 03, 2008
SOURCE: I need to know how
That means you can take the links out either way. Take a small pin that fits in the hole and lightly tap on the pin. If you find you have problems, add a LITTLE oil in the whole, this should make it easier, though a little messy.
SOURCE: How to remove links from Fossil metal band?
I did not know this was this easy, all this time with this problem. I like the internet.
Thanks!
Posted on Sep 04, 2008
Where can I get extra links for the band?
Moto 360 - Extra links for metal watch band - Motorola Support
https://motorola-global-portal.custhelp.com/app/.../prod.../2815,9141
Your metal watch band can be expanded by adding links. The small gray envelope inside the watch box (see image below) contains four extra metal links.
Order Links & Bands - Fossil
https://www.fossil.com/us/en/.../order-links-and-bands.html
Fossil GroupOrdering Links & Bands (U.S.). Order Links. Extra links can be ordered with a U.S. issued credit or debit card by calling the Metro Service Center at ...
Parts Archives - Citizen Watch - English (US)
Dec 25, 2015 | Watches
How to adjust a metal watch band Fossil Casual Metal Dial AM3861 Watch for Women
mcdevito75 here, Best bet since you would need a couple of tools to adjust the band size is to look for a small watch repair shop in your area to save on the cost, the cost of a shop to adjust the band is about the same as the tools needed, since these adjustments are in frequent let the watch repiar shop do the job.
Jun 18, 2010 | Fossil Casual Metal Dial AM3861 Watch for...
How do I adjust my watch band?
If you want to deuce the size of your band then I have found some instructions on the Fossil website and since most watches are very similar you can try the method described there.
If you need to replace links then you can get them for Skagen (free!).
Go to "fossil.com", go to the bottom of the page and you will see a menu, click on "customer care", and then look under "Product Info" on the left and you will see "watch instructions"
Go down the list to the bottom and under "Phillipe Stark" there is an item "bracelet instructions"
Feb 14, 2010 | Skagen 355LGSC Wrist Watch
Remove links from fossil metal band
The links most likely need a tool that will push the pins out so you can adjust the bracelet. This can be easily done by any jeweler or watch store. You can also order these types of tools online to do it yourself at home. Please do not attempt to remove links without the proper tools as you will not be able to remove them and you will also damage both the bracelet and the pins.
Jan 09, 2009 | Fossil Arkitekt watch
Purchased fossil ladies watch am4183 at Macy's, stainless steel band is too big, is this band adjustable, if so how.
Check the sides of watch band and you will see the pin ends. They are holding all links together. If there are arrows inside the watch band, they are pointing the way the pins must come out.
To shorten the band you have to:
Extract the pins.
Take link(s) off.
Join the rest of band together and drive pins back.
Jan 01, 2009 | Fossil JR8096 Wrist Watch
Watch band adjustment for polo club watch
There are small holes at the side of some of the links. You need to push out the small needles or pins in these holes in the direction of the arrows that are marked on the links.
You can use a sewing needle to do that (a blunt one, or break the tip).
When the small pins are pushed out, the links can be detached.
Hope that helps
Cheers Critter
PS: You can find watch repair tools on amaozon that will help you further
Also refer to
Metal Watch Link removal
Dec 25, 2008 | Fossil FS2920 Wrist Watch
I need to adjust the belt of my new watch
How do you adjust a watch band (remove a link)
Mar 14, 2008 | Watches
Need To Takeout a Link in Band
I know little about this watch, but generally there is an arrow on the inside of the band, you can use a small screwdriver to push on the side, or perhaps in a small hole on the inside of the band to force the link pin/s out in the direction of the arrow.
Jan 27, 2008 | Fossil AM3726 Wrist Watch
throw the ******* thing away
Dec 26, 2007 | Fossil AM3695 Wrist Watch
Wrist band adjustment on a fossil watch
Just take a tiny little jewelery screw driver small enough to fit in the pin hole and tap it with anything that you can find. Then pull out other end. Look for arrows indicating which way to remove pin and go in that direction Some pins are like a hairpin and have a split at one end. Replace solid end first opposite of arrow direction. If there are arrows in both directions on the same link; like Fossil for instance, that means that it doesn't matter which direction the pins are removed or replaced. They are solid and they can go back either end first. It's easy. To get the pin in all the way I just used the little screw driver and tapped it in. Good luck.
Dec 24, 2007 | Fossil CH2331 Wrist Watch
Watches Logo
520 people viewed this question
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
