Question about Dell Dimension 2400 PC Desktop
Need to change vidio mode to display input to 1024-768 @60hz to use my new monitor dell 2400 diminsion and acer monitor please help me''
  • 696 Answers
This should be fairly simple
If you're using XP:
close or minimize existing windows, right-click on an empty part of the desktop(background pic), when the grey menu pops up select Properties, when the properties sheet opens, select Settings(top far right), assuming your in dual monitor mode you should see two monitors in the picture. If you don't press your FN key and hold while looking for then pressing the F-Key(top row) with a pic of two monitors or the initials "LCD/CRT". If you only had one window before close the properties shet and re-open same way.
Now you have two monitors showing, click on the "2" monitor on the picture, then select extend my desktop to this monitor option and click apply
now grab the slider bar and adjust to 1024x768 and click apply again, assuming the monitor comes on as desired click yes on the confirmation window that pops up. Click OK, DONE!
If your using Vista the instructions end the same but start with, Close all windows then right-click the desktop, select Personalize from the grey menu and wait for the window to open, then select Display settings(same as settings tab in XP from here on in)....
Hope this helps,
Chris Armor-IT
Posted on Apr 24, 2009
  • 83 Answers
Go to control panel. look for personalize or display menu. select display settings and change your resolution and apply. then go to advance settings and see if set to 60 hz
I have a Dell Dimension 2400. It will power up but nothing will display on the monitor. monitor says it is still in sleep mode. The green power light is on and also the other green light flashes along...
http://support.dell.com/support/topics/global.aspx/support/my_systems_info/manuals?c=us&cs=19&l=en&s=dhs&SystemID=DIM_PNT_P4_CEL_2400
This a link to get an owners manual from Dell for your system, if you don't already have one. There should be a toubleshooting section as well as sugesstions on how to get out of modes. Ifyou need help with this, let me knowin "add comment' at end of solution.
Mar 16, 2011 | Dell Dimension 2400 PC Desktop
I am working with Dimension 2400 with monitor 773c blank or no display, drivers load after safeboot, but I am not sure what to do from there, nothing happens when I push enter, but the monitor works with a...
Refresh Rate, the reason why it works in safe mode and not normal mode is because in safe mode the system only loads the most basic and reliable drivers and sets the screen resolution and rate to their default values. In safe mode right-click on the desktop and go to properties, go over to the tab Settings and click Advanced. You should see another tab that says Monitor, there you can change your Hz, change it to something like 60hz to be on the safe side.
Jan 27, 2010 | Dell Dimension 2400 PC Desktop
How to change input timing without a monitor
you will not able to do it without a monitor. you'll need to get another montior in order to change the settings on computer. you need to change the resolution on that computer. sounds like the resolution is either too big or too small that it will not display it.
Oct 17, 2009 | Computers & Internet
Monitor does not display desktop
I'm not sure that you in fact have a dell, but take a look at this link and see if it helps.
Normally you should be able to use the osd (on screen display) by pressing the buttons on the monitor itself to change the monitor settings and get it to display properly. You need to make sure the monitor cable is connected properly, and perhaps check the cable itself by substituting another one in its place.
If that doesn't change the situation, you can check the monitor on another computer to be sure it's working correctly. In that case, perhaps a local tech could have a quick look at your new system and figure out why it's not sending a good signal to the monitor.
Best of luck!
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
May 13, 2009 | Dell Dimension 2400 PC Desktop
The vidio on my screen is sometimes shifted so that the vidio that is suppost to be on the left is on the right and the left is black. can you help me
check for the resolution that ud set for the video card, which should not exceed beyond the card liit, also check monitor settings, on the digital panel evtything aligned properly.
Mar 23, 2009 | Dell Dimension 2400 PC Desktop
How do I change boot order on Dell Diminsion 2400 XP Home?
Have you tried using a boot disk that gives you cdrom support?
If not, download those files and make a floppy boot disk, then set bios to boot from floppy and toss that disk in.
I think this website should have the files you need
Hope that helps you
Input Not Supported
You need to go into display settings, click advanced, and then click the monitor tab, and change the hertz setting to 60 HZ
Aug 07, 2008 | Acer AL1916W 19" LCD Monitor
Input not supported
Vista Driver perhaps required
Try Acer Website
Jun 13, 2008 | Acer AL1916W 19" LCD Monitor
Monitor
When your computer is starting up, hit F8 and you'll see the safe mode, safe mode with networking, etc. screen...You should see a choice that says "enable vga mode". Select that and windows will start and the os will select a screen resolution for you. After that, everything will work fine...I hope.
Good Luck!
Anonymous
Mar 15, 2008 | Acer X193W LCD Monitor
Dell Dimension 2400 PC Desktop Logo
89 people viewed this question
Alun Cox
