Question about Electrolux Heating & Cooling
Defrost light keeps flashing Electrolux ac ESE30HRA does anybody have the fault list on this units
2 Suggested Answers
  • 3 Answers
SOURCE: Electrolux Kelvinator - Unit on defrost
Check the defrosting sensor on the coil or the solanoid on the reversing valve.
Posted on Jun 07, 2010
Electrolux E36DF76EPS Why does the lock light keep flashing ( note oven works normally )
Hello Thecarsons, thank you for your post!
I understand that the lock light on your Electrolux range keeps flashing and everything else is working properly. This could be a potential problem with your latch or control panel. I would recommend looking over the latch or strike for any visible damage. If you do not see any, I would suggest performing a reset on your range. You can reset your range by disconnecting the power cord or flipping the household circuit off for at least ten minutes. If that does not resolve your problem you may need to have a technician out to your home to provide a proper diagnosis and repair. This will help you avoid any unnecessary part purchases. -Matt
Jun 10, 2015 | Electrolux Ovens
My electrolux split system air conditioners (ese30hra) only operates on high speed. What could be the problem and what could I do to fixit.
The air conditioner removes humidity when it's operating. This is where the water is coming from. Proper installation requires the unit to be tilted slightly down in the back so condensate will be picked up by the outside fan and be dispersed. The fan speed problem can be either a bad speed control relay or a possible open winding in the motor itself.
Dec 05, 2013 | Electrolux FRA102BT1 Air Conditioner
Defrost light flashing on ESA 30 HRA AC UNIT
look in the control panel it may have a list to tell you what the flash means. most of the time it flashes to let you know it has control power. which means you have a problem somewhere else
Oct 13, 2013 | Electrolux 5304426563
Electrolux ese30hra
This is most likely a faulty soft start or controller PCB in the outdoor unit. The soft starts are notorious for their failure rates and the control boards are easily damaged by the faulty soft start or a bug crawling across the board.
Jul 19, 2013 | Heating & Cooling
How does electrolux side by side model ei26ss55gs0 go into defrost mode?
There is an adaptive defrost board and setting that allows the unit to defrost at certain intervals. Each brand is different and runs on different times. Do you have a concern or issue with your unit frosting up?
Sep 19, 2012 | Electrolux Refrigerators
Electrolux washer dryer ewd 1409 start and pause light keeps flashing
That is a generic error code - please reset the unit at the household circuit breaker for about 10-15 minutes, and then retry the unit. No difference - please consult a professional.
Aug 22, 2012 | Electrolux EW1000i Front Load Washer
Hi Had power cut this morning and now the heat pump will not go. Green power light just keeps flashing and orange timer light on.
try turning the power off at the mains ( Isolator switch next to the unit or at the meter box.. Leave off for about 30 minutes as most AC units have a backup memory for when power goes off. Try restarting. If it still goes into a fault code mode ( flashing lights etc) there may have been damage done to the main board due to a power surge.
Jul 14, 2011 | Heating & Cooling
My Dome 40 bottle electric wine cooler keeps flashing E2. Does anybody know what is the problem?
Hi and welcome to FixYa, I am Kelly.
The defrost thermistor has failed. This E2 error code means that your appliance has experienced a defrost sensor fault. The bad thermistor will be near the top of the evaporator coils.
Thanks for choosing FixYa,
Kelly
Apr 25, 2011 | Refrigerators
Freezer FZ175 Red Warning Light is flashing
The flashing red light indicates the problem in the temperature of the unit.The temperature is rising over then required so the red light is flashing. There are some possibilities that you will have to get checked.
1) Make sure your freezer/refrigerator door is closing properly and sealing all around.If the doors are not closing properly then this can lead to rise in temperature.
2) If doors are proper and closed properly then other possibility is to check the compressor .Check the compressor is it running properly or its not running.Beside the compressor there is a fan if the fan is running the compressor is turning on if fan is not running the compressor is not running.If the unit is not getting very cold this also indicates the problem is in the compressor section.A weak or faulty compressor causes the temperature rise problem.
3) If compressor also checks out ok then the other possibility is fault in the thermostat of the unit.The thermostat is getting overheated and this is causing the red light flashing.
4) Before replacing any part in the unit try the defrost procedure first .Keep the unit unplugged from power and keep both the freezer/refrigerator doors open .let it remain unplugged for 24 hours.Then reconnect the power and check for some time.If the unit works properly that means defrost procedure solved the problem.But if same error light comes On flashing that means the faulty part needs replacement.
You can get required parts for your refrigerator from the on-line sites like :--
www.partsselect.com.
Thanks. keep updated for any more query.you can rate this solution and show your appreciation.
Jun 04, 2010 | Refrigerators
When a heatpump goies into defrost, the unit is in a/c mode. and cool air is inside. You may have a bad reversing valve or bad defrost board.
Sep 25, 2009 | Electrolux E23CS75SS Air Conditioner
Heating & Cooling Logo
Top Electrolux Heating & Cooling Experts
christian nielsen
ivan georgiev
ivan georgiev
Are you an Electrolux Heating and Cooling Expert? Answer questions, earn points and help others
