Question about Braun Syncro 7630 Electric Shaver
I HAVE A BRAUN 7630, ALL LIGHTS ARE OUT ON THE CHARGER AND NO CHARGE GOING TO THE SHAVER ???
EwingElect
  • 276 Answers
SOURCE: Battery replacement for Braun 8585
I'm pretty sure that the batteries are part of a sealed unit with the PCB on this model, and after checking the Service Diagram I'm even more convinced.
I would suggest fully charging and discharging (leaving it running without the foil and cutter on) a number of times to see if you can improve the performance, as there may be a memory effect on the battey. The model is only 5 years old so your batteries should have a little more life.
It is a mains/rechargeable shaver though, so you "should" still be able to use it with the lead plugged directly into the shaver. So the shaver may not be a dead loss! :)
Posted on Apr 12, 2009
VtToolMan
  • 704 Answers
SOURCE: Braun electric shaver will not charge.
Your batteries are no longer capable of being recharged and need to be replaced.
If you are handy and can dissemble and solder, you can do this yourself, otherwise, you can send it off to a repair service that will do this for you.
If you wish to do this yourself, you'll have to take the shaver apart. There are two (2) small plastic caps on the bottom of the shaver that can be removed with a small pick or flatbladed screwdriver. Once those are out, you can unscrew the two screws that hold the shaver together and gently pry off the side panels.
This will expose the internal circuit board and the rechargable batteries that need to be unsolded. You can then reinstall NEW rechargable batteries and solder them onto the PCB (printed circuit board). You can also purchase a complete internal PCB with the batteries and everything you need, you just swap out the electronics for the new one, although this costs about $39, while the batteries alone are much less.
Put the shell together and reinstall the retaining screws and caps and you're done.
Here's a link to get the replacement batteries for your shaver. They also do the repair service, if you don't want to do it yourself.
http://www.electricshaverstore.com/search.asp?p=1&w=%5F&c=battery&t=s
Hope you find this Very Helpful and best regards!
Posted on Sep 11, 2009
SOURCE: braun 7570 shaver wont charge but wont run on mains lead
My Pulsonic Razor that I received for Christmas will not run on battery, or with the plug supplied. I have tried just about everything I can think of. Is there a way to solve this problem? I do not have a receipt as it was a gift and am quite certain it would cost me a small fortune in order to fix it at a Braun Service centre.
Please help me if you can. TY
jbabcock12@cogeco.ca
Posted on Aug 08, 2010
brector3
  • 1602 Answers
SOURCE: My Braun shaver 8585 has died. Foil, cable, box,
If I understand correctly, the shaver is dead but all other components are in good condition. If this is the case, you should consider ordering a replacement lower unit. See shaveroutlet.com link below
http://shaveroutlet.com/braun-8585-activator-lower-unit-p-364.html
Newer models made by Braun do not use all the same parts as your shaver so this would be a good way to go
Posted on Aug 23, 2010
SOURCE: hi,
While holding the neck, pull up hard on the charging piece with the blue button.... You will not break it, it will go right back in after...
DO NOT try to remove the whole neck, just the button piece will come up, an inch or two (NOT OUT COMPLETLY) The wire will only allow you to pull it up 1"-2" so dont try to remove it....
Then look inside and you can see a spring, it's not attached to anything it's just resting in a hole. Pull it out and then push the top charging piece back down till it clicks in...
Now it will stay down on its own... I had the same problem and this work around solved it.
Posted on Mar 28, 2011
Charger arm will not stay locked in place to charge the razor
This is a common problem for older cleaning bases. The part is worn out. You will need to replace the upper housing of the cleaning base. You will find this item available at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-replacement-part-p-118.html
If repairing the unit is not your thing, you can replace the entire unit instead. See item linked below
http://shaveroutlet.com/shaver-replacement-parts/braun-7000-series-syncro-clean-charge-base-p-122.html
Jul 08, 2011 | Braun Syncro 7526 Electric Shaver
Looking for new blades for a Braun Electric shaver model 7630. Where can we get them and cost. Live in Gauteng, South Africa
$21-$70 from 3 pack to 12 pack
http://shavers-and-replacement-parts.stores.yahoo.net/braunshavrep.html
$28 + http://www.nelsonappliance.com/braun+shaver+parts.asp
$28+
http://www.newcomerscns.com/index_braunfoilncutter.htm
$19.99
http://www.thepartsbiz.com/Braun-7000-Series-Syncro-Pro-Shaver-Blade-And-Foil-Genuine_p_4827.html
$10
http://www.thepartsbiz.com/Braun-7000-Series-Syncro-Shaver-Blade-And-Foil-Aftermarket_p_791.html
Jun 23, 2010 | Braun 4501 Electric Shaver
Was on travel in Australia and battery charged fine once and then the second time I tried to charge the battery it would not charge. Unit is dead, no lights come on. In Australia I used a good...
hello,
try the charger on another similar product to know if its still working, if it charges properly then the fault is not from the charger, probably the power pack has a fault. replace the charger if it is the problem but if not try to fix the shaver.
Jan 03, 2010 | Braun Syncro 7526 Electric Shaver
Hi, My braun bs 5301 does not lock my braun 7630 shaver in anymore. at the top where it clicks into the bottom of the shaver, its not actually clicking in and now it doesnt charge or clean unless i hold it...
Oct 23, 2009 | Braun Syncro 7630 Electric Shaver
Oct 23, 2009 | Braun Health & Beauty
Braun 7526 not charging the + light wont turn on? how can i fix this?
In your case, it's hard to know exactly what might be wrong without more information. Was the shaver perfectly fine and then all of the sudden won't turn on? Or was the shaver working for shorter and shorter periods over time and then just quit? Was it exposed to undue heat, such as left in a car or in a place that wasn't air conditioned in the hot summer?
Although the batteries in these shavers are fairly robust, if fully discharged and not used for a long while, it might be that they've got a "low level memory" and will need replacing. If you are handy, you could disassemble the shaver and replace the batteries. They are NiMh AA flat top batteries that you can buy on websites like onlybatteries.com. If you're handing with soldering, you can replace them yourself. If you're unsure about that, you can buy the batteries along with the circuit board as a complete unit that drops right into place. Shaveroutlet.com sells these.
Another thing is that if the shaver was dropped, there's a chance that a metal connector part has come loose and so the shaver won't function. Taking it apart, you can see if this is the case.
The Braun 7000 series are rather old at this point, so sending it off for repair is kind of out of the question, as the costs involved would be more than if you bought another shaver. If you're not wanting to spend the big $$ on the new 9000 series shavers, find a new old stock 8000 series shaver (they are better made than the 7000 series). You can search on "that auction site" and you'll find quite a few Braun 8000 (or 360) series shavers available for sale.
Sep 25, 2009 | Braun Syncro 7526 Electric Shaver
Just bought braun 8585 electric shaver, return it to the store as nothing happens while charging. Got a new one and still not able to charge it, shouldn't the indicator turn red or green? nothing happens....
Did you insert a cartridge into the cleaning base? It needs that in order to work. Otherwise, try plugging the charger directly into the shaver. It should definitely charge the shaver, as long as the shaver is fine. Depending on the model, the charging indicator may be green or blue.
Jun 03, 2009 | Braun 8585 Electric Shaver
Health & Beauty Logo
Top Braun Health & Beauty Experts
shaveroutlet.com
shaveroutlet.com
Kazim ERGUNEY
Kazim ERGUNEY
Joseph Hoffmann
Are you a Braun Health and Beauty Expert? Answer questions, earn points and help others
