Question about Kicker CVR12 Car Subwoofer
How do I wire two 40 cwr122 12 in sub woofers to a Kicker 12cx1200.1 mono sub woofer amp the best way
5 Suggested Answers
Cerfer39
  • 709 Answers
SOURCE: subwoofer
Hi yeahonda,
Your Kicker L7 Ohms may be too low for the MA Audio Mono block amp. The MA Audio Amp is probably 2 Ohm Stable. The kicker will either be 2 ohm or 4 ohm Dual voice coil.   To eliminate the low ohms as a possible threat to causing the map to go into Protect, Wire the kicker Voice Coils in Series.  This adds the ohms, so that you either have 4 or 8 ohms.
I am using the following codes to show wiring. VC1+ stands for the Kicker  Subs Voice Coil #1 Postive post. AO+ is the MA audio Amp output positive.
AO+ to VC1+
VC1- to VC2+
VC2- to AO-
This shopuld give you 4 or 8 ohm depending on the 15" L7 setup.  Crutchfield does not carry the Kicker  L7 in 15" They do  have the L5 in 15".
If you know how to read a Volt Ohm Meter, set it to OHMs 20 and measure across VC1+ to VC1- and you should see between 1.5 and 5 ohms..  Do the Same with VC2+ to VC2-.  you should see the same voltage. Also read from the Voice coil metal housing to VC1+ , VC1-, VC2+, and VC2-. and you should not read any ohmage to the case. The meter should say OL, or -1.
Good luck.
Posted on Oct 15, 2007
sepsi
  • 7 Answers
SOURCE: Kicker solobarrick...still not working...
check ur ohms you are probably running to low.....
Posted on Feb 12, 2008
Shadowmaru
  • 33 Answers
SOURCE: wire my kicker
This will help you :)
Below is a link to the subwoofers manual where is clearly states how to wire it all up, it includes both the 2ohm DVC and 4 ohm DVC models.
Click Here for the L7 Solo Baric Manual
Posted on Feb 11, 2009
ruwidperd372
  • 279 Answers
SOURCE: best wiring hook-up from car amplifier to sub-woofers
Try this wire diagram for speaker connection
Posted on Apr 14, 2010
How do I wire a kicker mono amp for my subwoofer
You'll need to take the low frequency from the crossover to drive the sub woofer amp otherwise you'll get full range out of the mono amp which will reduce the low frequencies presented to the sub spesker.
Sep 23, 2014 | Car Audio & Video
Have a 1996 soundstream reference 1000s amp 2 chan. Want to hook up 2 2011 12 inch kicker cvt woofers 4ohm. What is the best way to run this set up?
I have Ref-1000s with two Pioneer TS-W1200C 4-ohm subs bridged in series. So it is 8-ohm mono load, easy for an amplifier, long durability, less heating, low current consumption. I have heard that this amp might break if used with low impedance loads.
Mar 18, 2011 | Soundstream Car Audio & Video
What is the best way to wire four 6" 55 watt
My advice would be to connect the front speakers and the sub woofer to the amplifier and run the remaining rear 2 speakers from the headunit. This way you dont stress the amplifier to run on two different loads at the same time and still maintane control over your system. Bridge your sub woofer on chanel 3&4 and do not forget to set the LPF for chanel 3&4. If your speakers are not components in the front set the HPF on chanel 1&2 to roughly 60 to 80 Htz.
dreamsystems.
Feb 10, 2011 | Clarion APX490M Car Amp
Sony xplod XM ZR602
What ohm is your sub running at. Sounds like your runnig your amp to low an impedance causing it to thermally shut down, when it cools a bit it turns back on. Either that or you have wires crossed somewhere. Check your wiring and make sure the load of the speaker does not fall below the rcommended ohm of the amp. Usually 4ohms mono and 2ohms stereo
Sep 07, 2009 | Eclipse EA3422 Car Audio Amplifier
How to get the best out of this amp
"google" subwoofer wiring diagrams to find out how to hook it up to the right ohms and everything..........hope this helps
Mar 21, 2009 | Kicker ZX350.2 2-Channel Amp - 220W ZX...
Confused about system
If what you're telling me is correct you're trying to drive a stereo sub -woofer with a mono amplifier. If so, that could be a bad situation for the amp, if the voice coils are not wired together correctly. Before we go too far, I have some questions I need answered.
1. Is the MA unit an M1889i?
2. Do you have the 4 terminals of sub-woofer tied together. For example the 2 positive terminals are tied together & the 2 negative terminals are tied together?
3.How do you supply 12VDC to the amp?
While I'm waiting to hear back from you, I'll try to draw a schematic (wiring diagram) of the way it should be wired for your particular setup that I'll send to you.
Mar 06, 2008 | MA Audio M1889I Car Audio Amplifier
kicker aint kickin? warranty,warranty,warranty!!!
Oct 16, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Subwoofer
Hi yeahonda,
AO+ to VC1+
VC1- to VC2+
VC2- to AO-
Good luck.
Oct 15, 2007 | Kicker Solo-Baric L7 S15L72 Car Subwoofer
Kicker CVR12 Car Subwoofer Logo
Top Kicker Car Audio & Video Experts
Professor_V
Professor_V
Tygh Duval
Tygh Duval
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
