Question about Maytag MVWX700XL Top Load Washer MVWX700XL
Hi I have mvx700xl when I press start nothing happens no water comes out then the lid latch starts flashing then every thing turns off now when I press power button nothing comes tell what is the deal thanks gene
SOURCE: Maytag Neptune door lock
you need a new door lock switch
Posted on Aug 07, 2008
SOURCE: maytag neptune
i have maytag neptune wash,modelo mah5500bww,my problem is: no starting,flashing start/pause button,after ten minutes is off.And now is ready for start when press start/pause button
Posted on Aug 29, 2008
dh1200s
  • 335 Answers
SOURCE: LID WON'T LATCH ERROR CODE FL
With that code FL “ Failed to lock” I would start looking at the lid latch mechanism. See this link from another site for lid latch problem.
http://fixitnow.com/wp/2006/09/06/maytag-neptune-fav6800aww-top-load-washer-op-code/
If you want to try to repair or get a better understanding of how to diagnose and repair this machine take a look at the service repair manual.
http://www.servicematters.com/maytag_library/docs/16022808.pdf
I hope this will help with your decision to try a repair or replacement.
Good luck with your issue.
Posted on Jan 04, 2009
dh1200s
  • 335 Answers
SOURCE: Neptune TL error code op
This forum member’s solution is going in the right direction I’m going to give you a bit more info to troubleshoot the issue if you want to DIY the repair. You have lost signaling from the left lid lock to the control board. The lid magnet could be out of position here is a quick check to try. Raise the lid then press Spin Only key, press on and you should throw the OP alarm to the console. With the lid open place a magnet on the left bumper as shown in this pic. If the OP alarm fails to clear we rule out the lid magnet as out of position.
Next step is to raise the washer top as shown on page 34 of the Service Manual
The Service Manual for reference. Sears Parts Direct for reference.
To raise the top of the machine insert a flat blade putty knife approximately 2.5” from the left and right sides of the washer top, depress the spring tabs securing machine top to the washer base. See page 33 of the SM for putty knife insertion point.
Disconnect the washer power cord. We can try to reseat the Left Lid Lock a couple of times to see there is there is corrosion causing a issue. Removing the plug is difficult so be careful. See page 34 of the SM, the plug you are going to reseat is shown in the pic on page 34 next to the tech’s thumb in that pic. After reseating a few times power up the machine try a Spin Only cycle, close the lid and hit the on button and see if the left lid lock is signaling the control board that the lid is closed. If you still take the OP alarm then it’s time to remove the left lid lock and inspect for corrosion or a broken wire on the magnetic reed relay. Some owners have found that corrosion has caused the soldered lead ends on the on the magnetic reed relay to break off. They can be soldered back on. See pic’s for corrosion issues and the lead that has broken off the magnetic reed relay.
Follow the SM to remove the left lid lock be careful when you release the tabs on the left lid lock case halves for inspection they break of very easy. Post back if you still need help. If you need to replace the left lid lock here is the part number 25001048 and a link, another. Good luck.
Posted on May 03, 2009
SOURCE: Maytag model MTW5570TQ0 MAYTAG LEGACY SERIES STARTER
control panel removable to access timer
Posted on Jan 06, 2011
Machine won't work.
Robert. You have a bad water valve OR completely clogged up filter screens on the valve. My past experience with this machine with this type of problem is to replace the valve assembly. part Number W10364988
Apr 09, 2014 | Maytag Bravos Series MVWB300WQ Washer
Press START and nothing happens
yes the door has a safety switch that will keep the machine from starting, this is most likely the problem.
Aug 12, 2008 | Kenmore 15762 Dishwasher
The washer will act like its going to start the lights come on, but nothing happens. i tried to unplug it nothing, made sure the door was shut and nothing is in the way or anything. no water is coming in...
Hi Levi, thank you for allowing me to assist you.
Let's try resetting the washer by either unplugging it or flipping the household circuit breaker to the off position. It is important to wait roughly ten minutes and then turn unit on. Once again confirm that the door is properly latched and try selecting a cycle. If resetting the power does not correct the issue, it could potentially mean a number of things: a potential wiring failure, damaged cord, faulty door lock switch or control board. Because it could be a number of any one of several underlying causes, it would be advisable to contact an experienced appliance repair tech to assist further.
Sep 10, 2013 | Frigidaire ATF6000ES Front Load Washer
I am trying to start a cyle and everytime i push the cycle button it does not light up and the quick rinse button comes on and flashes nothing works at all if i push heavy wash it comes on and nothing...
You haven't told me how many times the light flashes, but I will take a guess that this is an error code associated with the water entering the machine being too cool. I believe the machine expects the water to enter at 110 degrees F (43 Degrees C).
To clear the error, press "Heated Dry" then release, then press "Normal Wash" then release and repeat this sequence until all the lights on the machine go solid green. Once this happens, hit ""Cancel" and the machine will reset.
The fix for the root of the problem is to increase the temperature of the incoming water in future (Turn up your water heater temperature a little)
Jul 05, 2011 | Kenmore Elite Stainless Steel 24" BuiltIn...
! light flashing... machine won't brew coffee - when i press the button to make espresso nothing happens.. I've tried all the troubleshooting options - nothing works.
The machine is sensing one of the following is not properly fitted in.
Check bean lid, brewing unit is properly latch in, dreg drawer and tray is in, and water tank. And make sure the knob is in off position. If all those are properly in ..the green light will start flashing and warming up. When it reaches the working temperature it will start rinsing and it's ready to use.
Oct 11, 2010 | Saeco Odea Giro Plus Coffee Maker
My Hoover Optima OPH 714 D washing machine won't start
Hope your tried switching off the machine for half to one hour, to re plug. Machine might re-set.
If helped, pl click, it could help others.
Dec 07, 2009 | Bosch Washing Machines
Power light is on but nothing happens - indesit iwme12
If the door does not lock at this point it probably needs door lock replacing
Sep 05, 2009 | Washing Machines
Dishwasher wont run after pressing START ... green light blinks
NOT TOTALLY SURE ABOUT THIS MODEL, BUT IS THERE A "LOCK" BUTTON ON THE PANEL? ON SOME MODELS YOU NEED TO PRESS IT TWICE TO ENGAGE START. HOW OLD IS THE UNIT? HAVE SEEN THE INTERNAL TIMER RELAY MALFUNCTION ALSO AND IT WILL NOT ALLOW DISHWASHER TO START CYCLES. HOPE THIS HELPS
May 30, 2009 | Frigidaire 24 in. FDB1050REC Stainless...
Jan 02, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Hi, my simpson eziset 550 washing machine wont start, I press power on then the start button and beeping alarm starts with the three water temp lights flashng, this has happened intermitantly in the past...
5 beeps with the 3 temp lights flashing means lids not closed. or lid switch not working
i just fixed this problem. the magnet in the lid had come loose. I undid the two screws on the side of the lid put the magnet back where it should sit then i poured candle wax over it to hold it in place and working fine now.
Nov 30, 2008 | Washing Machines
Maytag MVWX700XL Top Load Washer MVWX700XL Logo
32 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
