Question about Canon FAXPHONE L170 Plain Paper Laser
HOW TO STOP VERY LOUD SCREECHING RING
Does anyone know how to stop the very loud screeching ring the fax machine makes when a fax is about to come in. Does anyone know what I am talking about? It rings for like a second, but it is horrible.
  • jackiegirl Sep 25, 2007
    There is nothing in the manual.
    I will try that tape idea.
  • JChalups May 11, 2010
    I just tapped the side of my L170 and it still presents a loud screaming beep. Any idea where the speaker might be? Nothing I can see on the surface or inside by removing the cartridge.
  • 363 Answers
Assuming there's nothing in the manual that tells you how to stop it. Is there a hole where the sound comes from? Block it up with blu-tack or sticky tape. Regards
Posted on Sep 25, 2007
  • Martin B
    Martin B Sep 29, 2007
    Let us know if it worked!
    Regards
SOURCE:
I have a Samsung Tab A6 that keeps making a loud screeching noise And boots itself it was freezing the screen but when I factory reset it that seem to stop now it's just making the loud screeching noise...
Where did you get the phone from.?
I suggest you take it back to them & get your money back as a screeching sound is usually a network-lockout noise from a stolen phone.?
Best of luck.
Mar 09, 2018 | Samsung Tablets & eReaders
Making loud screeching noise
check drive belt driving altanator and air con it sounds like it needs adjusting
Dec 30, 2013 | Saab 900 Cars & Trucks
When i try to start it makes a loud grinding
Your starter bendix is not kicking far enough to mesh with the ring gear, replace your starter and shim it is it take shims.
Jan 08, 2010 | 1995 Oldsmobile 88
Loud screeching noise coming from car after stops.
the screeching noise is most likely caused by a slipping belt or pully. transmission probably needs fluid and filter changed.
Jun 02, 2009 | 1990 Ford Tempo
Loud screeching noise on spin cycle
I have the same problem...during SPIN it make a LOUD SCREECHING sound.
Apr 20, 2009 | Maytag PAV2300 Top Load Washer
Monitor makes loud screeching vacuum sound; no screen display..?
check to make sure that there arent any magnets near or around it
Apr 13, 2009 | HP Vs17 17" LCD Flat Panel Monitor
The fax machine is making an unbearably loud screeching sound
that will be the drum unit arching you will probably need a new drum unit. you can try cleaning the drum some times that helps'
PS. remove the toner before you clean the drum unit use compress air and make sure you are outside the house it is messy.
any other question please let me know.
Mar 04, 2009 | Brother IntelliFAX 4100 Laser Fax
HOE TO STOP VERY LOUD SCREECHING RING
I have the same problem. If you get an answer, please share with me. thank you....
Sep 25, 2007 | Canon FAXPHONE L170 Plain Paper Laser
Canon FAXPHONE L170 Plain Paper Laser Logo
417 people viewed this question
Clive
Clive
old marine
old marine
Ekse
