Question about Frigidaire Freezer Ice Maker Kit 5303918493
Freezer Ice Maker Kit 5303918493 - Frigidaire Freezer Ice Maker Kit 5303918493
We have a Jenn-Air Refrigerator/Freezer (Model #JRSD226) and the ice maker has stopped working.
Check for blockage in the water line in the freezer. If so, defrost it. Might need a new water valve. Maybe a bad ice maker too.
Another possibility is that it's not cold enough in the freezer. Should be below +10F.
Freezer repair in Corona Del Mar, CA
Appliance repair in Corona Del Mar and Orange County, CA
Jan 25, 2011 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Ice maker will only make crushed ice and no cubes, what could be the problem
Open the freezer door.
Pull the ice bin forward about 3 inches.
Push the ice bin to the rear of the freezer until it seats and locks in place.
Then try to dispense cubes.
The ice bin can become dislodged from its locked position and the crushed ice solenoid activates automatically.
Sep 17, 2010 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
I have a liebherr freezer with ice maker. ice maker broken
Is your circulating fan working?
Sometimes they stick and need a shot of WD 40 and then work
it back and forth a little until it wants to take off again. Keep me informed
and PLEASE give a Thumbs Up for the effort. The Raz Shack
Apr 17, 2010 | Freezers
The ice-maker in my Daewoo Fridge Freezer (FRS-U20DAI) is not working. The ice tray does not empty.
is there ice in ice maker but it wont empty?
the ice maker has built in heater underneath. thats how the ice detaches itself from the ice maker and the fingers rotate them out.. if you have ice in the ice maker then replace ice maker
hope this was helpful
Mar 27, 2010 | Freezers
Clicking noise, ice maker out, freezer temp high
Low temperatures are absolutely required for proper operation of ice makers components. Dirty cooling coils or possible low refrigerant.
Jul 08, 2009 | Freezers
Freezer not cold enough/ice maker not working
Check the coils in the freezer to see if they are blocked with ice.
May 01, 2009 | Frigidaire 11.6 cu. ft. / 328 liter...
No water to ice maker or water dispenser
You're funny. This is a portable 12/120 volt model. It dosn't have a water dispenser or ice maker :-)
Dec 27, 2008 | Engel Freezer 22 Qt. Fridge/Freezer
Jen aire ice maker not working
change filter and defrost water lines if frozen
Dec 10, 2007 | Jenn-Air Freezer Jenn Air Clear Cube Ice...
Frigidaire Freezer Ice Maker Kit 5303918493 Logo
Top Frigidaire Freezers Experts
Charles T Nevin
Charles T Nevin
AJMAL KHAN
Dan Webster
Dan Webster
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
