Question about Woods INDUSTRIES 59383 OUTDOOR MECHANICAL HEAVY DUTY TIMER 7-DAY
I have the Woods 59383 outdoor timer. My pins are down so I want the Halloween lights to come on at 5:00 pm and go off at 10:00 pm. Pins are down for this whole time. I set it to 3:55 pm as the time it is now. Why are my lights on now?? e-mail my answear to hollyhock_garden@yahoo.com Thank you
SOURCE: Woods Model 59200V Indoor Mechanical Timer. Not working
book says peg should be down for on and peg should be up for stop. How the hell does one pull the peg up...it is blocked and can only be pushed down...now what I am missing?
Posted on Dec 19, 2009
SOURCE: woods industries outdoor mechanical timer 59730, I
I found a manual for this yard stake:
http://waterheatertimer.org/pdf/GE-15107-outdoor-timer-manual.pdf
There is a switch located on inner dial.
Move switch to TIMER
Posted on Dec 10, 2010
SOURCE: Where are the "never-lose pins"
Woods 59204 manual says pins, and I think the timer has tabs or segments instead.
These are located on the rotating part of dial.
Look at pictures on following link to see 4 basic pin-tab-segment layouts that are used to turn these timers on and off: It's likely that your timer will be one of these.
http://waterheatertimer.org/Woods-timers-and-manuals.html#Pins-tabs
Some timers have pins that click in and out
Some have segments that pull up
Some have segments that pull out
Some have segments that push down
Add a comment any time.
The phrase 'never-lose' means the pin-tab-segment is permanently attached to the timer dial.
Older timers, and many box timers have loose pins or trippers that you attach to the timer dial ... and of course people lose these trippers and are constantly searching for their model number of tripper which is not available. And some of these older timers were expensive. For example the older style malibu power packs have trippers, but when the tripper wears out, there are no replacements and power packs are expensive.
Posted on Dec 11, 2010
aquaman987
  • 927 Answers
SOURCE: Where are the pins on
The "pins" are the 48 little tabs that are around the clock dial. That would be 2 in every hour of the 24 hour day.
Push down a pin to start the device that you want to control and pull up the pin at the time you want the device to stop.
Posted on Dec 21, 2010
jyackle5
  • 8197 Answers
SOURCE: I just bought a Woods
You can get the manual on the link below.
http://waterheatertimer.org/pdf/Woods-59382.pdf
Posted on Jan 23, 2011
Model 59382, where are the segment pin`s located?
http://waterheatertimer.org/Woods-timers-and-manuals.html#59383
Photo of timer shows segments are located along outer edge of dial.
I'm not sure if these segments pull in-and-out or if they lift up.
Usually when segments lift up, they don't come straight up.
They lift up-and-outward or they lift up-and-inward.
Put a nail file under one of the segments and see if it moves upward.
You can also take advantage of fixya phone support.
Fixya expert will walk you through setting your timer for a price.
Dec 22, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
How many minutes does each pin represent?
You posted under Woods 59383 outdoor timer with 500 watt capacity.
This is a 7-day timer with segments (or pins) located around outer edge of dial.
Pull segments up to set OFF times.
Leave segments down for ON times.
Image of timer:
http://waterheatertimer.org/images/Woods-59383-image-500.jpg
Looking closely at image, there are 12 segments for each day.
So each on-off segment is 2 hours.
The dial shows days of week.
For example Monday (MON).
MON appears at 12 noon Monday.
TUE appears at 12 noon Tuesday
Rotate dial until current time lines up with arrowhead.
If this is not your timer, see all Woods timers and manuals:
Dec 13, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Where are the pins on the 59382 outdoor timer
The 'segment pins' mentioned in manual are tiny segments located around outer edge of dial.
There are 4 segments per each hour.
Each segment represents 15 minutes.
Use small screwdriver or fingernail to pull segment up.
When segment is up, timer is OFF
Leave segment down, timer is ON
Timer is 500 Watt.
Timer handles maximum 20 strings of 50 mini-bulb Christmas lights
Dec 06, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Lost direction on how to set the timer
Manual for 59383:
http://waterheatertimer.org/pdf/Woods-59383.pdf
If you have different model Woods timer, see link below, or add a comment.
To set Woods 59383:
Rotate dial clockwise until current time lines up with arrowhead located on inner dial.
Segments located around dial control on-off times.
Pull segments UP for OFF times.
Leave segments DOWN for ON times
Set manual override switch to arrow-down position
Switch unit to ON position.
Plug in timer.
Plug lights into timer.
If lights have switch, switch must be ON.
Max load 500 watts
50-mini-bulb string of Christmas lights is 25 watts
Dec 01, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
I can't find the pins that the instructions refer to.
Woods timers:
1) You posted question under Woods 59383 which has segments located around edge of dial.
These segments are pulled up to set OFF times.
Segments are left in down position for ON times.
2) Other Woods timers have tiny pins that stick up on the dial.
Pins are located on part of dial that rotates.
Get your glasses.
Run your finger across the dial and you can feel tiny metal pins that stick up.
Dial has 48 pins. Each represents 1/2 hour.
Use fingernail to move pins outward from center of dial.
Pins out = timer ON
Pins inward = timer OFF
Below are 2 EXAMPLES of Woods timer showing pins and segments
Nov 23, 2010 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Can't get the timer to turn on
Woods timers:
You posted under Woods 59383.
Plug timer into wall after setting timer.
Maximum load 500 watts, used for indoor or outdoor
Set current time, rotate dial until current time lines up with black triangle.
Around outer edge of dial are segments.
Pull up all segments for times you want timer OFF
Leave segments down for times you want timer ON
Locate switch on timer.
Push switch so the V shape is down.
Plug into wall outlet, plug Christmas lights into timer
Drink ale and eat turkey legs.
Add a comment if this is not your timer, or if you need more help.
Dec 18, 2009 | Woods INDUSTRIES 59204 OUTDOOR MECHANICAL...
Instructions on woods outdoor timer wth pins
go to Woods heavy duty timer and there is three tabs below the advertisement, one will say "specifications" and at the bottom of the tab page is instructions in green highlight. use the instructions given for pin timer , it works on earlier models as well.
Dec 12, 2009 | Woods INDUSTRIES 59383 OUTDOOR MECHANICAL...
Woods  INDUSTRIES 59383 OUTDOOR MECHANICAL HEAVY DUTY TIMER 7-DAY Logo
16 people viewed this question
Top Woods Hardware & Accessories Experts
Gene Haynes
Colin Stickland
Colin Stickland
jdthefixer
Are you a Woods Hardware and Accessory Expert? Answer questions, earn points and help others
