Question about Sharp AL 1631 Copier
What is the code for installing Sharp copier drum?
I bought a new drum for my Sharp 1000 series copier & the light still indicates that the drum needs to be replaced. Somebody told me that I need to type in a code. Please help!
    Sniper:
  • 67 Answers
Using 1 finger
Press clear
press auto (exposure setting)
press clear
press auto
when it works your display will go blank
enter 24
press start
enter 07
press start agin then turn it off and back on
Posted on Apr 24, 2009
My Sharp AL-1551CS,drum ligth came on and say needs drum,so bugth new one instaled di d some coping and now ligth drum came on againg and does not want to print. I do not have the manual!
To reset the drum light on just about any Sharp AL series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Press "C" then the far left key (exposure mode) then the "C" key then the far left again.
So in other words C, far left, C, far left
Some model's use 2 other initial codes, so you may need to use one of these 2 alternate codes to get your display to go blank. The rest of the procedure is the same.
Alternate codes are: #, * , C, * or pound,star,C,star and also
#, Interupt, C, Interupt
If done correctly the display should go blank.
Then key in 24 as if you were going to make 24 copies.
Now press the "print" button
Now key in 7 as if you were making 7 copies
Now press the print button again.
You should now be getting flashing zero's on the display.
Turn the machine off then on again and your drum light should be gone!
Good Luck and Thank You for using Fixya.
WheatlandServices
Oct 29, 2010 | Sharp AL-1551CS Copier
Tip
Sharp AL Series Copier Drum Light Cartridge Counter Reset
You can usually reset this counter at least once to get twice the life out of your drum unit.
This works in the following models:
Sharp AL1000, Sharp AL1010, Sharp AL1020, Sharp AL1041, Sharp AL1200, Sharp AL1215, Sharp AL1220, Sharp AL1250, Sharp AL1251, Sharp AL1340, Sharp AL1451, Sharp AL1520, Sharp AL1521, Sharp AL1530CS, Sharp AL1540CS, Sharp AL1551, Sharp AL1551CS, Sharp AL1631, Sharp AL1641CS, Sharp AL1651, Sharp AL1651CS, Sharp AL1655CS, Sharp AL1661, Sharp AL1661CS
on Jan 04, 2010 | Office Equipment & Supplies
I have replaced my drum cartridge on my sharp copier, however, the drum indicator light remains on. How do I get the light to go off?
I am not sure about the 208 but try this procedure I have posted here on Fixya. I beleive it may work for you. It sure won't hurt to try.
To reset the drum light on just about any Sharp AL or AR series copier press the following key's in sequence and as quickly as possible (with 4 seconds for the first 4 keys)
Oct 14, 2010 | Sharp AR-208S Black and White Copier
I replaced a new drum cartridge for Sharp AL-1631 Copier, but the warning indicator light is still on and the copier is not working.
Sep 17, 2010 | Sharp AL-1641CS Color Copier
I HAVE A SHARP AL 1641 CS COPIER AND THE DRUM I WAS GIVEN WAS SHARP AL 1000 DRUM UNIT AL 100 PART MS1DR AND THE DRUM LIGHT IS STILL ON AND THE COPIER WON'T WORK, DO I HAVE THE RIGHT DRUM AND IS THERE...
The AL1000 drum unit is the same as the AL1641 drum.
I do not recognize the MS1DR as a sharp part number.
You can reset the drum indicator by pressing these keys in sequence:
Press "C" then press "Exposure Mode" then "C" again then "Exposure Mode" again.
Note that the Exposure Mode key is the far left key on the panel.
One you press these 4 keys in sequence the display should go blank. Then key in 24 as if to make 24 copies. Then press Print (Green Button)
Then key in 7 as if to make 7 copies.
Press print again. You should now get flashing 000.
Turn machine off then back on and the light should be gone.
Here it is in a short version:
C, far left, C, far left, 24, print, 7, print,
then power off and back on.
This should make the copier operational again if all you have is the drum light.
Dec 02, 2009 | Sharp AL-1641CS Laser Digital Copier
I've lost my manual. Does the red light that
The red light that looks like an empty cylinder on the Sharp AL 1631 Grayscale Copier panel is the "drum replacement required" indicator. The "cartridge replacement" indicator is represented by 6 dots forming a triangular shape.
The drum replacement indicator lights up when there are about 1000 copies left until its end of life. It is only when the indicator starts blinking that the drum really needs replacement.
The part number for the drum is AL-100DR.
I hope this helps.
Nov 19, 2009 | Sharp AL 1631 Copier
Reset drum cod
The codes are C Auto C Auto display off, press 24 print 7 print , 00 will display then press C twice.
May 06, 2009 | Sharp AL-1642CS Copier
SHARP AL-2040CS Drum reset code
c - auto - c - auto - (machine is off) 24 - start - 07 - start (000 blink) - 4x botton c . Finish ok.
Apr 28, 2009 | Sharp AL 1631 Copier
Sharp AL-1631 - would not copy.
Your unit definetly needs a new drum. The usual yield for this consumable is upt ot 15,000 pages, so at the stated rate, the unit yielded more than average. AL-1000 series share the same toner and drum, so finding remanufactured (or recycled) drum units should be no problem. In Puerto Rico, they are sold for about $79.00.
Oct 05, 2007 | Sharp AL 1631 Copier
Sharp AL 1631 Copier Logo
124 people viewed this question
Top Sharp Office Equipment & Supplies Experts
Anthony Karuku
jasbo
jasbo
Adorjani Laszlo
Are you a Sharp Office Equipment and Supply Expert? Answer questions, earn points and help others
