Question about Nokia N80 Cellular Phone
Nokia n80 white screen
When i put the phone on, the display flickering. I don't recognize notting on it. I put the phone off.Now i will put it back on but i can't get it on.
    Scholar:
  • 151 Answers
There is problem in your display screen. Get it changed.
Posted on Sep 25, 2007
SOURCE:
My new Samsung SM-T310 tablet screen flickers so much I cannot use it. is there a fix?
find out if the actual display or just the back lights are flickering first .
turn on a good flashlight lay it on the face of the display when lights go out if the picture remains then it is the back lights not the display
but either way i believe you will end up replacing the display (backlights included( and probably LEDs) ) i will look at availability and feasability of this, come back with item model number and year
Jan 12, 2015 | Samsung Galaxy TabPRO SM-T320 16 GB Tablet...
How do I fix the vetch phone when it displays no battery
It will not recognize the return of the battery until the handset
is placed again into the charging dock or base.
FWIW, amazon.com has the best prices on new batteries
for these cordless phones.
Oct 05, 2014 | Vtech Lands Phones
My phone keeps telling me that my SD card has been removed but it hasn't been. I've tried taking it out and putting it back in but it keeps telling me the same thing
maybe because your phone don't recognize your SD card anymore. try to put your SD card to other phone and try if the other phone recognize your SD card, if the other phone don't recognize your SD card, the problem is in your SD card. you should buy a new SD card if that's the case. Also try to put a different SD card on your phone and you'll see your phone will recognize the different SD card.
Kindly rate this post. Thank you for your question and I hope I help you a lot.
Jan 20, 2012 | HTC Cell Phones
Memory card. !! please help );
Don't know much about the Samsung phone; Can you put music on the 1 Gb memory card from another source (like a computer) and have it recognized by the phone?
Does the phone require music in a particular format? For example, if the phone recognizes .mp3 music files, but all your music is in Ogg Vorbis (.ogg) files, you will not be able to play them on the phone.
1) Find the Samsung phone manual (online?) and see if it requires music files to be in one format, or another.
2) Try loading music, in the proper format, from different sources onto your memory card.
Best of luck!
Nov 12, 2011 | Samsung Cell Phones
My phone is already white screen.nokia N80
White screen are symptoms for Contact retailer. try to call 112 (emergency call) if its working, meaning it's LCD problem. If 112 working try to clean the terminal of LCD. IF this doesn't work consider replacing it.
Sep 09, 2011 | Nokia N80 Cellular Phone
My lenovo LCD screen is flickering black and striped lines, how to get it fixed in Richmond Hill Ontario
Laptop computers have LCD displays that are sensitive to many things. LCD displays have faults that sometimes produce a flickering screen, lines, dots or a faint display. These screens are sensitive to magnetic fields or electronic items near the computer. Speakers, cell phones, lights and other electrical items are examples. Your display also could be flickering due to software issues such as the video drivers or hardware issues relating to the inverter going bad or the LCD screen itself needing to be replaced. Trace the cause of your problem to come to a resolution.
1.Turn off the computer. Disconnect all external devices. Turn the computer over (bottom facing up). Take out the battery and reseat it. Turn the computer on.
2.Reset your resolution and refresh rate.
Windows XP:
Right click an open area on your desktop. Click "Properties" in the drop-down menu.
Click the "Advanced" button at the bottom of settings tab. Another dialog box appears. Click the "Monitor" tab. Change the Refresh rate to your default, or 60 hertz. Click "OK."
Windows Vista:
Click "Start, Control Panel." Find and click "Appearance and Personalization." Click "Adjust Screen Resolution." Change resolution to the default, or 800 x 600. Click "Advanced Settings." Click the "Monitor" tab. Change the refresh rate to the default, or 60 hertz. Click "OK."
Windows 7:
Click "Start, Control Panel." Find and click "Display" Click "Change display settings" on the left side. Change screen resolution to 800 x 600. Click "Advanced Settings" in the lower right. Click the "Monitor" tab. Change the refresh rate to 60 hertz. Click "OK."
3.Check the computer's surroundings. Move away any speakers, fluorescent lights, fans, cell phones, radios and any other electrical device that can cause flickering. Temporarily move electrical items away from the computer to see if they are producing this issue.
If the flicker stops, put back one item at a time to determine what is causing the problem.
4.Connect an external monitor to your laptop computer to see if that screen is also flickering. If there is no flicker, then the problem is strictly with the laptop, indicating a possible hardware failure. Contact the manufacturer for a replacement LCD.
If the flicker continues, go to next step.
5.Reset/Update your video driver. Click "Start" and right-click "My Computer." Click "Properties." The "System Properties" dialog box will appear.
6.Click "Device Manager." A list of items will appear. Click the (+) sign next to "Display Adapters."
7.Right-click the video adapter and click "Uninstall." Confirm removal. Restart the computer. The video driver will automatically reinstall itself.
8.Check to see if the flicker still exists. If so, go to the manufacturer's website. Download and install the newest video driver and BIOS for the computer.
9.Restart computer once drivers are installed. Continue to the next step if there is still flickering.
10.Open up your display screen all the way. If the flicker stops by opening it a certain distance, it is the display inverter. If the flicker still exists, the LCD screen should be replaced.
11.Contact the manufacturer of the computer for more information and a possible replacement inverter and LCD display. This will depend on the manufacturer and the computer itself.
I hope you find it very helpful. Thanks
Sep 05, 2011 | Lenovo 3000 N200 Notebook
My laptop emachine g720 screen flickering
Windows XP:
Windows Vista:
Windows 7:
I hope you find it very helpful. Thank you for using fixya.com
Aug 19, 2011 | Computers & Internet
My problem is with your new security device you put on Facebook. I chose to have a text sent to my phone when I logged on. I accidently erased my phone number and then later in the day deleted cookies so...
My problem is with your new security device you put on Facebook. I chose to have a text sent to my phone when I logged on. I accidently erased my phone number and then later in the day deleted cookies so that my laptop wasn't recognized. I now get the message as follows... We don't recognize the device you're using.You currently have no phone listed on your account. Please log in from a recognized device to regain access to your account.Once you regain access, we recommend adding a new phone or disabling the login approvals feature.If you don't have any other recognized computers, you can contact our User Operations team. I tried to get on from my friends computer and a computer at school but it still doesn't recognize any of them. The problem is without my phone number to send the confirmation text to I won't be able to get on my account. Is there a way to take that off by having you do it? Then I can get on my account and add my phone number back.
please send me solution above issue
my email id is [email protected]
PLEASE
Aug 14, 2011 | Facebook Social Network
My daughter dropped the cordless phone and there is no power to the phone , no display.please tell me how to troubleshoot
open the battery cover. remove the battery for about ten minutes. plug the battery back in and put the cover back on. then put it in the base (not the stand alone charging cradle) the light should flicker on the base for a second. take the phone out and it should be working.
Nov 03, 2010 | Uniden 5.8GHz Dual Cordless Phone
Cell Phones Logo
165 people viewed this question
Top Nokia Cell Phones Experts
jonathan mariano
jonathan mariano
Ekse
