I need value of Zener diode zd601 on power supply bd. of samsung t220 hd
5 Suggested Answers
  • 2318 Answers
SOURCE: UNKNOWN VALUE OF VOLTAGE ZENER DIODES
I was not able to find any service or schematic for this model. The colors means that the value is 22.6 volts zener diode with the other blue band indicating where the cathode is.
Could you tell me where or what other components this zener diode is connected to?
Posted on Jul 02, 2008
taran_2005
  • 10515 Answers
SOURCE: sylvania tv model 6419TA. power supply problems
The solution woule be 5.6 v .
Thanks for using Fixya.
Posted on Mar 26, 2009
6,2 V zener dioda red,red,blue
Posted on Sep 23, 2009
SOURCE: tv does not power up
I have seen the schematic, d982 is a 13v 1/2w zener
-GR
Posted on Jun 03, 2010
WHATIS THE VALUE OF ZENER DIODE IN THE POWER SUPPLY?SAMSUNG TV
If you wish to get some details; check the site linked here. Pull up older posts.
http://electro-medical.blogspot.com/
Aug 23, 2016 | Samsung Televison & Video
Equilent for a zener diode (RD 30ESB2)
Zener diodes are invariably used as low power voltage regulators or as a voltage reference for voltage regulating circuitry.
Zener diodes are sold by wattage and reference voltage by numerous component suppliers and constructor stores and in theory the voltage is marked on them, though difficult to see and easily defaced.
Finding an equivalent for what appears to be a manufacturer's part number presents a rather difficult challenge. The official service sheet will probably provide the required voltage. Without that information you will either have to purchase the component from the manufacturer under the part number or experiment until the required value is discovered.
Mar 02, 2016 | Televison & Video
MCS 160 Boston Subwoofer ZD3 Zener Diode Value
ZD3 is a 18v zener. Also check the surface mount resistor on the back of the board that is attached to ZD3, I think it is R9. Should be 10 ohms. This resistor sometimes opens when the diode goes short.
Jul 13, 2013 | Audio Players & Recorders
Power Supply bad working. Blue led doesn't light.
Hi, I'm having the same problem with one of mine M1 Active 620. Please have you found out characteristics of D5 Zener diode, voltage?
Nov 13, 2012 | Alesis M1-Active-MK2 Powered Studio...
LG 32lh200 power supply failure common problem
You might try to follow the diode back to the source and read voltage to know the value of the diode and also look on the diode for generic number--short of that Google the model number with "parts" as it might be cheaper to replace the board than try to fix it by guessing values.
Aug 27, 2012 | LG 32LH200C-A1 LCDTV 32LH200C 32inch Wide...
My hitachi 29in ctv power supply 110vac had a problem on zener diode will blown if we switch on the tv. what spare parts to change so that the power supply zener diode will not blown again and the supply...
The secondary output voltage comes out from is more than it should be there. That is why, the protection zener diode blows off, as soon as you switch ON the set. First find and repair the power supply regulator, for correct output voltage. Refer its repair book for details. After repair include the zener diode in place. OK.
May 08, 2012 | Hitachi Televison & Video
Polaroid 860-AZ0-GF371H Power Supply Unit. After replaceing all bad caps and and shorted fets Q102,103 I still need to know the value of smd zener ZK2 in Parallel with 3 low value smd resistors. I think...
HZK Series
Silicon Epitaxial Planar Zener Diodes for
Stabilized Power Supply
open the following link and it help you it has all the detail about the mentioned diode
Aug 26, 2011 | Polaroid FLM-3232 Television
Burnt Zener diode... Voltage spec??
On the cathode of the zener diode look for a filter cap and check its value the voltage of the zener should be less than the working voltage of the zener. Basicly its likely being used as a shunt regulator as protection and regulation of the voltage. When the zener hits a certain threshold it will breakdown and start conducting to ground until the supply regulates and then it will recover. If the filter cap for that voltage rail was 25V I would guess that the zener would probably be regulating between 12 and 20 volts. I'd pick a 15V Zener its probably +- %10 on the original and any system should be able to take a %10 tolerance as a general design rule.
May 07, 2009 | Emerson Televison & Video
Zenerdiode
hi
vishu here ,
this is 8.2volts zener diode
mail me ur response @ vishwas_4u@rediffmail.com
Feb 26, 2008 | Computers & Internet
Televison & Video Logo
52 people viewed this question
Top Televison & Video Experts
Electro Med Services...
