My fedder azhp12d2a portable air conditioning unit
My fedder azhp12d2a portable air conditioning unit will not turn on, the light above where it says "built in three minute cooling delay" is blinking red continuously. When I plug it in it beeps and everything comes on the screen, but then it turns off and the light behind blinking again. My house is extremely hot, I would be grateful for any help?? Thanks!
    New Friend:
    Greenhorn:
    A rookie expert who has answered 20 questions on their first day.
  • 53 Answers
Every time when you turns your ac on it takes 3min , dear it is just a time delay to protect your ac comp , it is not harmful. You can by pass it by pressing turbo key in remote aur by switching off your ac by remote only not by mains. it is helpful , try it
Posted on Oct 15, 2013
3 Suggested Answers
SOURCE: wiring diagram for portable air conditioner
I think the wiring diagram is on a printed sticker on the side of the water collector, just pull it out of the right side as you look at it. There should be one on there hope this helps as i have the same unit in the other room. regards Richard
Posted on May 29, 2009
SOURCE: model # m6p09s2a portable maytag
Greetings,
I have the same model air conditioner, and had the same symptoms. As you've probably discovered, Fedders is the company that actually built it, and went of business. No one is supporting it any more.
However, you may be in luck. I fixed the problem by simply tipping the unit almost all the way over on its back (leave a little gap) and letting the water drain out of the hose and the filter. After that, it started right up.
Hope that works for you. Stay cool. :)
Posted on Jul 08, 2010
My switch that turns on heater,air conditioner blinks when turning on air conditioner
What is the make and model of your Air Conditioning unit? Airbulance would love to help you with your Air Conditioning Repair problems.
Dec 19, 2016 | Heating & Cooling
Tip
Portable Air Conditioning great portable air cooling
Portable air conditioning offers you the convenience of mobility. All you have to do is roll the portable air conditioner to the room in which it's needed. Install an exhaust hose out a window or other opening (everything you need is provided) and turn it on. The installation process for these units is very simple. These portable air conditioning units are built small enough to be very mobile and are supplied with wheels for easy movement. A portable air conditioner will also work very well in apartment situations where you will often find a window unit is unacceptable.
Portable air conditioners are very unique in that they are portable and can be easily moved to different locations in your home or business. They can be a highly effective way to either help out an existing HVAC system in one room or cool a single room entirely. They are also one of the best ways to cool a room or area without having to install a window mounted unit.
These air conditioners use a compressor and Freon to cool just like normal air conditioning. They are very effective in cooling rooms and to keep the humidity low. Like normal air conditioners portable units extract hot air that must be vented. That is why they need to have the exhaust hose to the outside. These units can cool air as well as air conditioning done with window air conditioners. However they do not require installation like conventional window air conditioners this makes them very convenient for seniors or physically challenged people. Most portable air conditioners are supplied with a window kit. This kit contains exhaust hoses that will work in any window: double-hung, casement, awning or slider. Because they vent through an opening like a window they require no permanent mounting like window air conditioning.
Portable air conditioners are a very good cooling option for those who can't use the more conventional air conditioning methods. Remember though that this type of unit is not as efficient as most window units or conventional air. So while they may make your environment cooler, it won’t turn your tent into a room at the local hotel.
So as you can see these air conditioning units have some great advantages over other types of air conditioning. They are a great alternative for unique applications where central air or conventional window units are either unfeasible or too expensive. During special events, portable air conditioning can also be a great way to keep guests or equipment cool and comfortable. Always be aware though that because portable air conditioning will remove moisture from the air, they will also need to be drained occasionally similar to a dehumidifier.
Does your application warrant a permanent air conditioner of some form or should you just use a portable one? There are some interesting things to consider when making that choice. Weigh out all of the different options and make that decision based on what will best suit your needs.
on Dec 13, 2009 | Heating & Cooling
Whats the right settings for the window air conditioner.
i operate my a/c's in summer at 72 to 74 degrees. in the winter at72 to76.
Jul 30, 2015 | Fedders AED24E7F Wall/Window Air...
My EverStart portable air conditioning unit
sounds like you need to wash your condenser coil. Sounds like your compressor is kicking out on high head pressure. Once it cools off it starts cooling again take it out and give it a bath don't get the electric wet.
Sep 12, 2014 | Heating & Cooling
Why is my Kenmore 72012 blinking?
Does the display blink no matter what is displayed? If the display always blinks the same info, what might that be(i.e. error code)? If you are able to cycle through settings and the display changes while blinking, the problem is likely in the control circuitry. The controls have a built in delay to protect the system from abrupt changes. You'll notice this delay, and the blinking display, when you first turn these units on and when changing modes.
Jul 12, 2014 | Kenmore 72012 Portable Air Conditioner...
My unit to my house wont turn on outside. This happened last night at about 8:30. I have checked the circuit breaker/fuses and the little red switch on the unit itself-- I pushed that. I turned the...
Turn power off to indoor unit. Remove red, yellow and green wires from tstat and wire nut the three together. Turn power to indoor unit back on. This should bring on indoor fan and outdoor conpressor and fan. Let me know
Jun 22, 2017 | Fedders Q Chassis A6Q10F2A Air Conditioner
I have a fedders portable a/c unit and it works for five minutes and it then shuts down. The circuit braker does not trip and I plugged the unit on different locations with the same results. The unit has...
Thanks for your information that " The unit has very cold air".It's cut off by indoor coil sensor.
Reason for shut off in 5 minutes.(There are one or more reasons for the problem) Check as follows.
1. Evaporator coil,air filter and bower wheel full of dusty. Service your unit completely.
2. Check rpm of blower motor. If less rpm replace capacitor.
3.If all above is o.k and still problem means defective coil sensor. Replace it.
Hope, it's helpful?
Jan 19, 2011 | Fedders A6X05F2D Air Conditioner
Model # m6p09s2a portable maytag air conditoner unit...red light keeps blinking at the unit where power button is located....unit will not turn on. the light just keeps blinking
Greetings,
Jun 16, 2010 | Maytag Portable Air Conditioner M6P09S2A
FEDDER'S PORTABLE UNIT SAYS STOP. WONT RUN
Disconnect power to the unit and reconnect. If "stop" is still on the display you will probably need a qualified technician to trouble shoot. The best mode is the snowflake (cooling). The rain drop is dehumidification which can cause condesation on unit.
Aug 30, 2009 | Fedders A&B Chassis A1A07W2B Air...
Need Owners MAnual
Go to safemanuals.com and then to this link: http://safemanuals.com/user-guide-instructions-owner-manual/FEDDERS/A6Y12F2B-E-_E
to get your manual. If its not the specific one, put in ur request and leave ur email. They will inform you the moment they find one.......sodeep
Jun 25, 2009 | Fedders A6X05F2D Air Conditioner
Heating & Cooling Logo
199 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
