Yamaha rx v371
Audio dialogue will randomly chose when to work. Usually the problem resolves itself after the receiver has been turned off and on again. lately this issue has become more frequent and require more attempts to bring the dialogue audio back. Have looked in the manual and all trouble shooting guides... no luck. I have about 6 months left on my warranty and am wondering if this problem will result eventually with the receiver being un-usable. Please notify me if there is a fix or if this is a valid problem.
SOURCE: Audio but no video from Sony Blu-Ray w/ HDMI hookup to RX-V663
Okay...my first contribution to any forum but I have the same problem (Yamaha RX-V663 and Samsung Blu Ray) and found the solution. The problem is you probably have your HDMI cables from your DVD player and reciever connected to a DVI input on your TV. The DVI may have problems communicating--not HDCP compliant. My system was working great then I hit a button on my remote...just playing around. I think it was the pure audio and I turned off the receiver. After that, the audio worked but there was no video. After many frustrating hours, the fix was to unplug the HDMI and DVI cable then turn the power off, cycle the power again, and plug the HDMI and DVI cables back in (the DVI was the last cable plugged in, not sure if that matters). By unplugging everthing you've reset the communication between the HDMI components and the DVI TV.
See page 18 of the yamaha owners manual, second to last note on bottom right of the page. It says there may be a problem...
I also noticed that the yamaha reciever was sending 1080p (my older tv is 1080I) and that is why the video wouldn't display on the TV. You can see this in the video signal info screen, unfortunately there is no setting to switch it back, just recycle the cables and power and it should reset.
Uncredibly frustrating but I got my picture back!
Jason
Posted on Jan 10, 2009
  • 125 Answers
SOURCE: Yamaha RX-V995 receiver turns on & then powers off 2 seconds late
I suggest you run self diag.  press [FM/AM] key + [Input mode] key and press the [power/standby] switch.
ps prt = power supply problem
dc prt = shorted output or leakly cap in channel
tmp prt means to hot on heatsink
you'll likely have to measure the resistances of the output FETs to find a short,
Posted on Feb 03, 2009
  • 17 Answers
SOURCE: My Onkyo tx-sr606 7.1 receiver turns off by itself
hi, when the unit shuts off by itself, it means that the protection circuity inside has been activated. it can be a problem with the receiver itself or it is just detecting something hooked up to it that can cause possible damage so it shuts off.
you would need to disconnect everything from the back and by itself, try to turn it on, see if it will stay on and then crank the volume way up to max. if it stays on, the receiver is ok and you then need to rehook your devices one by one starting with the speakers until you determine the one causing the receiver to shut off.
however, if the receiver shuts off and won't turn on even by itself, it means that the problem is internal and it either has to go back to your dealer for an exchange or it has to be sent to a repair center for servicing.
hope this helps a bit.. ^_^
Posted on Mar 09, 2009
SOURCE: Yamaha RX-V3800 receiver zone two audio problems
To get audio with this set up also hooked up analog audio RCA cables for the audio for each piece of equipment for 2 channel out put. Zone 2 will not out put a digital signal and this receiver will not down convert a audio signals to analog if using digital audio hook-ups.
Posted on May 08, 2009
  • 127 Answers
SOURCE: Intermittant Audio with Yamaha RX-V465 only from cable box
I have the same receiver... You can try pressing the Option button and choosing Signal Info to see what audio signal the receiver sees and if that changes over time. Maybe the cable box is not outputting according to specifications... TV can live with that, but receiver maybe can't.
You can also try to connect the cable box via SPDIF cable (optical or coax) to see if it helps or not.
Posted on Mar 02, 2010
My Yamaha RX-A1010 turns on and shuts off by itself on occasion. It also randomly switches between inputs by itself.
Your receiver may be detecting random signals from some other source. Infrared is pretty much line of sight but RF can come from anywhere.
Aug 29, 2016 | Yamaha RX-A1010 Aventage Audio video AV...
Why won't it turn on?
may be locked in protect mode. Try holding 'tone control' and 'info' buttons and pressing power
Nov 02, 2015 | Yamaha RX-V371 A/V Receiver
Yamaha Receiver RX-V371 broken speaker wiring connection on the back, what are different solutions?
That unit give you the option for a second set of speakers ?
If so , connect to Output 2 ( or B) on the speakers connections and select Spkr 2 ( or B) from the front panel
Dec 16, 2014 | Yamaha Audio Players & Recorders
I have a yamaha receiver rx-v371 the speaker imput clamps on the back are broken. Can i use banana plugs?
For the main speakers , Yes, you can use banana plugs. Theyre built for that.
I hope that helps
HAVE A YAMAHA RX-V371 RECEIVER, NO CABLE BOX AND I CANT GET ANY SOUND FROM MY PHILLIPS HDTV.
if you have a coax digital out on your tv, why not use that, you have coax, optical, and hdmi inputs on your reciever, but the easiest, low cost way is the coax
Feb 20, 2013 | Yamaha RX-V371 A/V Receiver
Yamaha rx-v371 comcast remote codes DO NOT WORK!
Yes it will not work , Your just wasting your time trying,
Nov 28, 2012 | Audio Players & Recorders
Yamaha RX-395 receiver problems
This may be a relay problem, could be fixed for under 100.00 this is a normal problem for this unit.http://www.nextag.com/yamaha-home-theater-system/compare-html
Feb 18, 2010 | Yamaha RX-395 Receiver
 Grubhead
Grubhead
