Question about Health & Beauty
Produex PEV-165E scale is showing Lo when you stand on it
2 Suggested Answers
SOURCE: Scales showing Lo after battery has been replaced
Anytime you have trouble with a Taylor scale - they have a lifetime replacement warranty. You need to call their 800 number and pay for 1 way shipping and they will send you a new one.
Posted on Aug 12, 2009
What does it mean when my Boflex body fat scale reads Lo then turns off
My scale readout is now blank? Do I have to buy a new battery?
First, did you notice of the scale had a "lo" or "bat" display before it went blank? If so this means the battery needs to be replaced. If you did not get the battery indicator, did you "miss" seeing this? Has it been a week since you were on the scale? If you stand on the scale regularly and did not receive the battery indicator then you can try the reset procedure above.
Source: <http://www.taylorusa.com/faq-scales> Syz D
Aug 22, 2014 | Health & Beauty
Model ww66
In the event that the scale battery needs to be replaced, (display shows "Lo"),
open the battery cover on the bottom of the scale and replace the old battery with
a new 3V lithium battery.
Jun 04, 2014 | Conair WW60 Weightwatchers Scale
Model 9114 salter scale shows Lo. I have changed the batteries but it still only shows Lo.
I had the same problem and, suspecting that the metal contacts weren't making proper contact with the batteries, I used a long nosed pliers to gently bend all ten contacts towards to the batteries (there are eight small tabs in the battery compartment, and two on the battery cover). If you don't have a long nosed pliers a small screwdriver should do it if you held the fixed part of each set of contacts so it doesn't detach during the process.
Unfortunately, it worked, but only for one weigh, and then it reverted to "Lo". This happened twice, so I telephoned the Salter Customer Service Helpline (01732 360783) who recommended a reset, which is done by removing the batteries, standing on the scale for 20 seconds, and replacing the batteries. That also only worked for one weigh, so they are looking into it further and I'll post the results here, but in the meantime I hope one of the above solutions will work for others.
Jan 21, 2014 | Salter Stainless Steel Electronic Bathroom...
My scale showed Lo, no reading, then I replaced battery, now shows nothing, dead. What do I do next?
The Instruction Book for your scale can be found here:
http://www.taylorusa.com/media/IBs/7506_ib.pdf
Sounds like no power. Check for correct battery replacement; may need to verify that your replacement batteyr is still good.
Battery Replacement
1. Use 3 volt CR2032 lithium battery (as installed).
2. Open the battery compartment on the bottom of the scale.
3. Remove the old battery from the compartment.
4. Place the new battery with the "+" sign up into the battery compartment.
5. Replace the battery compartment cover.
Apr 23, 2011 | Taylor 7506 Glass Lithium Digital Bathroom...
Scale keeps showing lo no weight
Try taking the battery out and putting it back in, also there should be a small reset button. You will need a toothpick to push the reset button. Allow time for the scale to reset before stepping on it.
Apr 19, 2011 | Homedics Digital Scale
Scale shows "Lo"
just fixed this problem myself. so first i took out the battery then put it back in didn't wait a specific amount of time or anything. i just popped it out blew the inside then put the battery back in. next i switched it to ST from LB stepped on it stepped off it then stepped on it again and it reset. then i put it back to LB and voila it worked again!
Dec 18, 2010 | Taylor 7506 Glass Lithium Digital Bathroom...
Hi. I have a Produex glass bathroom scale. I have no idea what model it is and I can't find the instruction manual. Somehow it got switched from pounds to kilograms and I don't know how to switch it back....
I have a produex glass scale that is silver with a solid black stripe on one side and rows of poka dots on the other side. It has a tiny swicth on the back that changes the scale from pounds to kilograms.
Jul 27, 2010 | Health & Beauty
Jun 04, 2009 | Taylor & Digital Scale Lithium Scale
I replaced the batteries in my 7542 scale and it keeps showing err or Lo. What can I do?
have you replaced the batteries with duracell or energizers? I ask this because sometimes when it comes to this type scales using a lower name brand type of battery isnt strong enough for it or there just may be a malfunction in that product. Let me know if this helps and good luck!
Jan 24, 2009 | Taylor & Digital Scale Lithium Scale
Health & Beauty Logo
60 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
