Question about Water Heaters
Error e29 and e15 showing on display of ariston a30 mffi combi boiler, water is heating fine but no heating
djchillsnyc
  • 152 Answers
SOURCE: Radiator Leak rust
what part is leaking ?what type of set up do you have? steam or water
make sure you completely drained and refill the system before use. your water level needs to be corrected or this will force water up the lines instead of steam
your radiators need to be pitched so that the steam (water) can return back when the system shuts off
as for the leak. where it is or what part is leaking
heres a manual for your system
http://www.ariston.co.uk/uploads/doc4947b0d538f79.pdf
hope this helps
Posted on Dec 24, 2008
tborn6
  • 700 Answers
SOURCE: Boiler problems
heres a copy of the serviceing manuel for the unit. just click on the link and download the manual. http://www.ariston.co.uk/uploads/doc482c2cada6e71.pdf good luck
Posted on Jan 11, 2009
  • 152 Answers
SOURCE: pilot light on boiler
The plumbers repair should be guaranteed, give him a call back.
It sounds to me that the pilot flame needs to be adjusted or the thermocouple is not aligned properly or there is a draft that is blowing out the pilot.
Good luck...
Posted on Feb 23, 2009
gary1121
  • 332 Answers
SOURCE: vokera combi boiler
there is a zoneing valve thats suppose to be in the line to keep this from happening, might even have a check valve either way which ever one you have is bad and should be changed with a new one
Posted on Jun 06, 2009
SOURCE: ariston A01 fault combi boiler
its not definately the pcb. change the detection sensor first( £3.20p). if this doesnt fix a01 fault then change the main pcb(£145).
Posted on Jul 06, 2009
No hot water pressure in bathroom
bleed the system,sounds like an airlock issue
Apr 05, 2017 | Water Heaters
Ariston euro-combi boiler not giving hot water
odd noise like popping or singeing fire....clicking noises.....sounds like you have a water leak putting out the pilot.......or your thermo coupling is bad....or the noise is the tank full of calcium buildup and that will make noises when the burner is on
Jan 19, 2013 | Water Heaters
I have an ariston 20/24 mffi combi pressure rises when switched to central heating but pressure ok when asking for hot water ? expansion vessel ?
over heat limit stat on central heating circuit ? if hot water is ok and hot to temp when run for 5 minutes the expansion vessel is doing its job.remember hot water is the maximum demand for any boiler ,,heating is secondry?once you establish hot water at maximum rate then the only real problem is on you demand for heating??
Dec 10, 2012 | Water Heaters
Ariston ACO MFFI 35 E34 fault code present
This is the manual for your boiler. I hope the information contained in the manual will help you identify your problem.
http://www.ariston.co.uk/uploads/doc47e92b04013d8.pdf
Mar 30, 2009 | Water Heaters
Pilot light on boiler
Good luck...
Feb 22, 2009 | Water Heaters
Boiler problems
Jan 11, 2009 | Water Heaters
Moved in house Monday & have a radiator leak due to bad rust...what's best temporary repair to hold for a few weeks b4 plumber available? What sort of Boiler is Ariston Genus 24 mffi ?
turn both valves off at each side of radiator and once the pressure balances it will stop leaking, there is no solution to this whilst using this as a radiator to heat the space, but will stop the leak.
Dec 24, 2008 | Water Heaters
Water Heaters Logo
32 people viewed this question
Top Water Heaters Experts
Paul Carew
Gil Shultz
Are you a Water Heater Expert? Answer questions, earn points and help others
