Samsung ht c463
How repare prot on ht-c463
  • 9 Answers
SOURCE: i have a samsung HT-Z320 home theater system. when
the player's amplifier is blown and needs to be repaired or replaced.
Posted on Jan 26, 2010
SOURCE: HT-Z320 displays PROT code and then shuts down
i had the same problem a prot display then it would shut down. turns out i had the sub disconnected(noise complaint from the shaking at my apartment complex) but the speaker wires for the sub connected to the amp or central unit. when i disconnected the sub i left the wires on the floor behind the sub separating the pos. and neg. somehow the wires got moved around and the pos was touching the neg. as soon as i noticed and fixed this problem the system was working fine. my samsung hometheater model is HT-BD1250
Posted on Apr 08, 2010
SOURCE: samsung ht c550, enciende, saluda,
when i turn on my Samsung HT-C550 IT showing PROT and DVD turn off. What this is mean PROT?
Posted on Jan 10, 2011
  • 55 Answers
SOURCE: when i turn on my
PROT means that the AMP is protecting itself from damage due to bad or incorrect wiring or damaged and or incorrect speakers. Check your wiring and speakers.
If you find no problem then, DISCONNECT YOUR SYSTEM FROM THE POWER, disconnect your speaker wires...all of them, then reconnect the power ONLY, turn on the system and see if it still says PROT. If it does then your amp is damaged.
Posted on Feb 20, 2011
  • 105 Answers
SOURCE: i have a samsung HT-Z120 it show a PROT error
This error means that you are trying to play a region-protected disc that is not in the same region as your player.
It is possible to "hack" the region on your DVD player by following these instructions:
http://www.videohelp.com/dvdhacks/samsung-ht-z120/10244
Please rate my answer.
Thanks,
Chris
Posted on Mar 05, 2011
When I turn my system on, it waits 5 seconds, says "PROT" then shuts itself off.
There could be a short circuit in one of the speakers. This would cause high current flow thru the amplifier and result in self-protect. Disconnect all speakers from the unit and try powering up again. If there is no PROT, then reconnect speakers one by one until fault found or all speakers are reconnected.
Oct 04, 2015 | Samsung Ht- C550 5.1 Channel 1000 Watt...
Samsung dvd player display says "protection" . Wont turn on.
Swtch off and disconnect and reconnect all the wiring especially speaker wires.
Also try resetting as per manual.
If that doesn't work then could be capacitor blown on motherboard.
Aug 06, 2014 | Samsung Ht-c650w 5.1 Home Theater System -...
My dvd player keep shutting down on me it says PROT and it shut down is there someone that can help me. HT-C463
Generally speaking, an amp attempts to protect itself from heat, shorts, overloads and operator exuberance by refusing to turn on or stay on.
Overloads can be from excessive periods of high output or marginally low impedance loading by the speakers; and shorts would be wiring issues or a speaker blowing up.
You should be able to feel if it's hot. WHY is it overheating? Make sure it has sufficient ventilation on all sides and that vent holes are not blocked by dust balls. Ensure the fan (if equipped) is running as designed (some only operate on demand). Clean dust and debris from it.
If the amp comes back on after cooling, you're lucky. They only have so many self-protection cycles in their lives so continuously resetting or cycling their power without addressing the cause can do more harm than good.
If it protects immediately on a cool power up you should disconnect the speaker connections and try it 'nekkid'. If it comes up then diagnose which lead(s) are shorted. If it does not come up the problem is internal and should be left to an experienced and competent hands-on tech.
Check for loose speaker connections at the speaker as another possible root cause for intermittent shutdown.
Sep 08, 2011 | Audio Players & Recorders
I have a samsung HT-Z120 it show a PROT error
Thanks,
Chris
Mar 05, 2011 | Samsung HTP-1200 System
When i turn on my Samsung HT-C550 IT showing PROT and DVD turn off. What this is mean PROT?
Feb 20, 2011 | Samsung HTC550 Theater System
Whatb does it mean when the PROT comes on and then shuts off the dvd player
hello, prot mean protect the output transistor may have blown or a capacitor has poped or swelled up or the just could be a case of a dry joint
regards
shaun
Nov 22, 2010 | Samsung HT-X50 System
Samsung ht c550, enciende, saluda, lee y aparece el mensaje PROT y se apaga.
Oct 11, 2010 | Samsung HTC550 Theater System
When I put on my DVD player, it says "hello, DVD, LOAD, PROT" and turns off...
I assume "PROT" means some sort of protection mode. I would check to see if any of your speaker wires are crossed at the speakers or the receiver. If not you may have shorted something internal.
Mar 18, 2010 | Samsung HT-WP38 System
Dec 29, 2009 | Samsung HT-DB120 System
43 people viewed this question
 Grubhead
Grubhead
