Question about Simrad Boating
My cetrek autopilot control head is playing up (930 cetrek0, can I swap it for any other brand?
2 Suggested Answers
SOURCE: Simrad AP 11 Autopilot control head
I happen to have an ap11 head unit in good condition, please contact me.
Posted on Nov 08, 2009
I have a Raymarine Autopilot with a control unit ST7002. The display has almost burned and it is hard to see. The control unit has been discontinued and it is hard and expensive to find. Can I change it...
You can probably find another control head on eBay... the ST6002 should also work, though it's smaller. The ST8002 is the same size but adds a knob meant for powerboats, but should also work. All three models are SeaTalk, which is what you need. The ST70 is also SeaTalk in addition to N2K, so I'd expect it to work.
Dec 20, 2017 | Raymarine St8002 Smartpilot Autopilot...
MOT POW SWAPPED, this is the message which appear just like that. the autopilot is working last 5 years, i have checked the wires connections, all is set as the diagram. one thing: my rudder has some...
Check if rudder reference unit is installed as before ,it seems that the pilot sense that the rudder is turning the wrong way. check when giving +10 command the
rudder turns to increase the heading,if yes, it could be the wiring of the rudder reference unit or it was installed the wrong way after service on the rudder.
Is rudder position indicating correctly?
Jun 24, 2010 | Raymarine Smartpilot Autopilot St6002 S1g...
I have an older ST4000 AutoPilot and this summer the drive motor doesn't seem to function. How do I disconnect the wires to determine if I have power coming from the control head and what voltage show I...
You can check it in 2 places:
1) the back of the control head
2) the motor itself. The wire plugs into the motor or the shaft coming off the wheel portion.
You should have approx. 12 VDC coming from the control head to the motor.
May 28, 2010 | Raymarine St 4000 Wheel Drive E12093
I would like to connect my garmin gps72 via the garmin supplied four line plug to the nmea ports in back of my raymarine st6002 autopilot controller. The st6002 controller is plugged into a smartpilot x5...
I connected my Garmin gpsmap76 to a Raymarine autopilot using the NEMA output from the GPS. The autopilot was also on the seatalk bus. It work fine. The GPS provided navigational guidance to the autopilot
Dec 21, 2009 | Garmin GPS 72 GPS Receiver
Oct 28, 2009 | Simrad Boating
Boat on screen does not point the direction the boat is going e-80 series also chart will not go course up or heading up like the radar does unit is set in relative motion mode
The direction of the boat symbol is depending on the compass course from the autopilot. You will see that your GPS course (COG) and magnetig heading on the autopilot differs. Solution is to calibrate autopilot compass. Will advice you to not use course up, stick to north up or heading up.
Sep 08, 2009 | Raymarine C80 GPS Receiver
Connect Furuno 1732 to st8002 autopilot
It will handle the voltage. as far as the wiring goes, you'll have to decide which port to use. the wire coloring is different. you'll have to send your nmea out data from port 3 white and shield ( Like you said) to the pilot and receive your heading data from the pilot on port 2.
Apr 11, 2009 | Furuno Navnet 1732 GPS Receiver
Problems talking to autopilot
I think you use the NMEA output to the autopilot .
The plotter shows you only when you have a seatalkconection with a Raymarine autopilot on you Plotter
Apr 06, 2009 | Raymarine E120 Multifunction GPS Receiver
Raymarine gps sounder
This is a common problem if the GPS is hooked up to an electronic heading sensor such as an autopilot. If the heading sensor is not calibrated properly, the boat will appear to be facing the wrong direction.
If you have an autopilot, consult the installation guide and perform the sea trial procedures. That should get your boat lined up properly.
Jul 17, 2008 | Raymarine GPS
Boating Logo
Top Simrad Boating Experts
Steve
Steve
ray gallant
Don A
Don A
Are you a Simrad Boating Expert? Answer questions, earn points and help others
