Question about HP Pavilion dv4000 Notebook
Battery release slide broke off
My HP DV4000 battery release latch broke off and i need to remove the battery. Is there another way to open it manually?
    President:
  • 2,976 Answers
You can probably release it with a medium crochet hook or a small screwdriver. Make sure the screwdriver doesn't have any sharp edges. You will have to fish around to get hold of the linkage.
Posted on Apr 24, 2009
Battery change on Dell latitude c6400.14inchlaptop
I think the Laptop you have is E6400,
Steps to Remove the Battery.
They are 3 Release Latches to remove the Battery.
1) Make Sure all cables including Power cord is unplugged.
2) Please look at the image attached.1a2dca20-03d2-447a-9f36-95e42448fc94.jpg
3) Turn the Computer Upside Down.
4) I have numbered the Latches.
Latch# 1 - Slide the battery door release latch# 1 into the unlocked position and Slide the battery door release latch# 1 toward the base of the system.
5) Latch# 2 and 3 - Slide the battery release latches into the unlocked possition.
6) Open the battery door on Latch# 1
7) Using the battery pull tab slide the battery out of the system.
Let me know if you need any other help.
Thanks
Feb 10, 2014 | Dell Computers & Internet
How to change battery on Dell latitude c6400.14inch laptop
Thanks
Feb 10, 2014 | Dell Latitude C640 Notebook
Battery release latch won't open
If you push the battery in and try to release? Try a little silicon spray, mind not to over spray.If you hold open the release switch and manually pry out the battery with your finger nails?
Nov 12, 2012 | HP Computers & Internet
Can't open service door
HP Support > Probook 4530S Notebook PC > Manuals > Service Manual,
http://h20000.www2.hp.com/bizsupport/TechSupport/DocumentIndex.jsp?contentType=SupportManual&lang=en&cc=us&docIndexId=64179&taskId=101&prodTypeId=321957&prodSeriesId=5060880#1
Under the bold subheading -
Service and maintenance information -
Click on -
HP Probook 4530S Notebook PC and HP Probook 4730S Notebook PC - Maintenance and Service Guide
Bottom Door - Page 49
1) Remove ALL power. Remove the AC adapter (Charger), and Battery.
2) Position laptop bottom side up, Battery Compartment facing you.
3) Remove the Locking Screw if installed.
(Area where Battery Compartment meets Bottom Door, and in the Middle; is screw location)
4) Slide the Bottom Door release latches to release the door.
(One latch on each side of Bottom Door; where Bottom Door meets Battery Compartment. The Latches slide to the INSIDE of the laptop)
5) Slide the door towards the Front of the computer, and lift off.
(Front of computer is AWAY from you. On the opposite side of the Battery Compartment)
Regards,
joecoolvette
[ P.S., you remove the Bottom Door; you wear an ESD wrist strap, and have it's alligator clip attached to a good ground source; or you risk using the laptop for a Frisbee from now on, or a doorstop.
Average cost is around $3 to $6 ]
Nov 06, 2012 | HEWLETT-PACKARD Probook 4530S 156 I52410M
Need to remove battery, dont know how compaq presario v 3000
Hello sexychispa. To remove the battery of your Compaq Presario v3000, start by turning the laptop over so that the bottom side is viewable. Look for a rounded slot in the bottom that has a sliding tab within. This is the battery release latch. Using your finger, slide the latch and hold to release the battery. With your free hand, assist the battery out of its compartment and allow the release latch to slide back into place.
For more information on the process, be sure to view this link to HP's guide to removing batteries from Compaq laptops.
Hope this helped!
Feb 27, 2011 | HP Computers & Internet
Battery release latch locked in open -hp pavilion dv4 1313dx
The same thing happened to my HP laptop. The sliding lock mechanism relies on three little hooks to hold the battery in place. What had happened to mine was that one of the hooks (the one nearest to the switch) had gotten stuck (this is quite difficult to explain, but just examine the three little hooks closely and you'll notice it the difference.) I freed it simply by pushing it with my thumb to unsnag it. The battery is now securely back in place, where it will stay!
Jan 13, 2010 | Computers & Internet
How do I remove battery from hp pavilion notebook
Turn the laptop upside down (closed and off)
To remove the battery from your laptop, simply press the battery release lever on the bottom of your computer and allow the battery to slide out. Refer to your instruction manual if you can't find the release lever.
Good luck dear.
Rate this please.
Jan 08, 2010 | HP Pavilion dv6000z Notebook
I have a HP Pavilion dv6225us laptop, and cannot get the battery compartment out. The release latch does not work.
Cheek for screws if any. if not (1) Press slide and hold the battery latch toward the outside edges of the computer. (2) Slide the battery Straight back still pressing to Remove.
Dec 09, 2009 | HP Pavilion dv6225us Notebook
Need to remove case from HP Pavilion dv-7 notebook. Case is cracked. I have a new one, but can't figure out how to get the old one off.
You need to remove the battery, the hard disk and the covers. Then remove screws at the bottom to release the keyboard and the upper casing.
Follow detailed instructions on pdf for dv4000 here , the procedure is the same : Service Guide HP Pavilion dv4000 Notebook PC Compaq Presario V4000 Notebook
Apr 01, 2009 | HP Pavilion dv7-1132nr Notebook PC
HP Pavilion dv2120us Notebook PC battery release latch
My battery latch got stuck in the open position after replacing the battery on HP's DV 6300 series. The battery was thus stuck. I used the 'screwdriver' technique but with a rounded end kitchen knife not an actual screwdriver to remove the battery. It is important to push the knife down a little into the groove at the outer long edge of the battery and pry that outer edge up. AFTER DOING THIS THEN GOING TO REPLACE THE BATTERY I REALIZED THE LATCH PROBLEM OCCURRED BECAUSE I HAD PUSHED THE BATTERY LATCH TO THE OPEN POSITION TO REPLACE THE BATTERY. THIS IS WHAT JAMS IT. TO REPLACE THE BATTERY 'DON'T TOUCH THE LATCH AT ALL'. LEAVE THE LATCH IN THE CLOSED POSITION AND REPLACING THE BATTERY WILL SET THE LATCH IN THE CORRECT CLOSED POSITION, READY TO BE SLID TO OPEN POSITION ONLY TO DO THE ACTUAL BATTERY REMOVAL.
Dec 13, 2007 | HP Pavilion dv2120us Notebook
HP Pavilion dv4000 Notebook Logo
237 people viewed this question
Top HP Computers & Internet Experts
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
