Question about Precor Exercise & Fitness
I have M9.10 precor treadmill. When I begin turning up the speed after putting in body weight and mode (manual/interval) the treadmill motor stops and the control panel reads "Pace Error #1". I realize the treadmill is old but if I can salvage it for a cheap price, that would be great. Thanks in advance for any help you can give me.
  • 14 Answers
SOURCE: ???maximum user weight for Precor 9.45i
Normally most home treadmills are 250-300lb user capacity.
Call Precor with your model # and S/N and they can tell you exactly.
Posted on Apr 29, 2009
SOURCE: my sportsart 6150 treadmill gives an error code 1
I would say that it could possibly be a speed densor fault as error one means loss of speed signal!! If the mat moves first then error one shows i would change sensor before changing anything else, if the mat does not move it could be a lower control board fault.
Posted on Feb 22, 2010
maxtreadmill
  • 832 Answers
SOURCE: Carl Lewis MOTC66 E03 error HELP !
Check the motor brushes if they are find then I would go back to the board regardless if its new it could be defective
Posted on May 06, 2010
maxtreadmill
  • 832 Answers
SOURCE: Noisy precor treadmill motor
that sound is due to the bearing failing inside the motor this is cause by capacitance discharge thru the armature thru the bearings. these unit can be rebulit I 've done plenty
Posted on May 14, 2010
maxtreadmill
  • 832 Answers
SOURCE: Error message reads: Pace error #1
Errors 00 through Error 04 check upper PCA memory locations, RAM memory locations and EEPROM checksum during the power up test sequence. If a fault is found during the power up test sequence, the appropriate error code will be displayed.
These errors messages almost always indicate an upper console problem when they are consistently displayed. Failures causing these error messages to be displayed are rare.
If the error message is consistently displayed when the unit is powered up, the upper console should be replaced.
Posted on May 24, 2010
The incline on our Precor c964i is stuck in a high position (approx. 10% incline). Other than being on a high incline, the treadmill seems to be working fine.
Hi There,
Precor uses a pair of Triacs to drive the lift up and down. These triacs live on the lower board but are driven by the upper console commands via a serial link between the upper and lower. Most precor lift issues we see are related to the lower board but with Precor it could be an upper board or the CPU Chip that resides on the lower board or a failed Triac. Good Luck
Apr 07, 2017 | Precor Exercise & Fitness
Precor 9.27 treadmill won't slow down
Hi, It's probably the speed censor. Clean it up and should be good to go. When you disasemble it clean all other parts and put back togeather. Good luck
Jan 23, 2014 | Precor 9.27 Treadmill with Ground Effects...
Motor making loud buzzing noise
The grinding noise could be asking for lube. If that is possible, do it.
Dec 13, 2013 | Precor C956i Treadmills with HR /...
Cuts off and speed is variable and shows err 4
Precor Error E4, Incomplete Initialization Probable Cause Indicates that an incomplete upper PCA to lower PCA initialization occurred. When this error occurs, all lift motor and drive motor motion is ceased and the display will go blank except for the error displayed.
Corrective Action Run the initialization program. Caution: The treadmill's running belt will accelerate to the treadmill's maximum speed (12mph). DO NOT stand on the treadmill's running belt during the procedure.
  1. Set the on/off switch to the OFF position. Wait a minimum of 10 seconds to allow the internal power supply to discharge.
  2. Remove the safety key from the console and set the on/off switch to the ON position.
  3. Press INCLINE UP and SPEED DOWN keys together. While pressing these keys, replace the safety switch on the console. Continue holding the INCLINE UP and SPEED DOWN keys until the display goes blank. INIT will appear in the time window of the display. The EEPROM is now clear and reset. After a second, 1.25 will appear in the distance/calories window, 15.0 (the maximum incline) will appear in the incline window, and 12.0 (the maximum speed) will flash in the speed/pace window.
  4. Press QUICKSTART to begin the speed calibration process. Power bits will appear in the incline window, the target speed will appear in the time window and the actual speed will appear in the speed/pace window. At the beginning of the process, the target speed will be .5mph. The running belt will start. Once the actual speed reaches .5mph, the target speed will then change to 12mph and the running belt will accelerate until it reaches 12mph, then it will stop.
  5. When the running belt stops, the display will return to the user mode and the initialization process is complete.
Precor Error Code E4
Feb 27, 2013 | Precor 9.1 Mode 1 Treadmill Repair Parts...
Precore m9.43 treadmill error 22
Precor Error Code 22 Error Code: 22 Manufacturer: Precor
Model: All Models
Error Description: Error 22, No Motor Pulses at Start Up - Error indicates that the display has sent a command for the drive motor to start, however, the speed sensor has not returned the signal acknowledging that the drive motor has started. Possible Reason:
  1. The line of sight between the speed sensor and the speed sensor target is obstructed.
  2. Badly worn drive motor brushes.
  3. Incorrect gap between the speed sensor and the speed sensor target.
  4. Incorrect adjustment of the speed sensor potentiometer (when equipped).
  5. Inoperative speed sensor.
  6. Faulty lower PCA.
  7. Faulty interconnect cable between upper and lower PCA.
  8. Faulty upper PCA.
Recommended Action:
  1. Using a static safe vacuum cleaner, carefully vacuum out the drive motor compartment. Be sure to thoroughly clean the area between the speed sensor and the speed sensor target.
  2. Bady worn drive motor brushes cannot make proper contact with the motor commutator, therefore the drive motor will not start when voltage is applied. Inspect and replace drive motor brushes if necessary.
  3. Inspect the gap of the speed sensor to the speed sensor target. Proper gap is 3/16" and the speed sensor photo eye should be aimed at the larger portion of the targets wedge shaped section. If unit has a magnetic speed sensor, the gap between the end of the sensor and the flywheel tooth needs to be 3/16".
  4. Locate the speed sensor potentiometer (when equipped) on the lower PCA. Set the speed sensor potentiometer to mid-range. Start the treadmill and increase speed to 6 mph. Carefully adjust the speed sensor potentiometer until the treadmill is operating the smoothest. Increase the speed to full speed and again adjust the speed sensor potentiometer until the treadmill is operating the smoothest. These two adjustments are typically small and are generally only a matter of fine tuning.
  5. An inoperative speed sensor will allow the drive motor to start and run briefly before the error appears. If able to access the speed sensor wiring, measure the DC voltage between the speed sensor leads. Two of the leads will always read about 5 VDC. Two will toggle between 0 and 5 VDC as you slowly turn the speed sensor target. If both measurements are not seen, the speed sensor needs replaced. Some units have the speed sensor mounted on the lower PCA and the lower PCA needs replaced.
  6. Determine if the lower PCA is bad by swapping with a known good lower PCA.
  7. Determine if the interconnect cable is bad by swapping with a know good cable.
  8. Determine if the upper PCA is bad by swapping with a know good upper PCA.
Feb 05, 2013 | Precor 9.21 Treadmill
Model: All Models
Recommended Action:
Precor C966i The unit turns off at random intervals. When reset it comes back on then shuts off a few minutes later. Error log is empty so not an error with software.
LUBE or wax the deck belt, this happen because you do not lube or wax your equipmente according with the schedule maintenance, you must do it, every week. Do it now.use 100% silicone lube-
2) LUBE the rollers bearing too use WD-40 for rollers b only.
3) Test the drive belt motor, and adjust it or replace
4) test the input voltage motor, if there are the motor need repair.see my personal TIPS for troubleshooting helps.
5) test the output voltage board, for input voltage motor, if there are NOT the board is faulty. see the block diagram
God bless you
Nov 13, 2012 | Precor C966i Treadmill C 966i
My treadmill work fine when i turn it on but when i step on it the blet. slows down to crawl.
What make/model is the treadmill? What speed does this behavior occur? Does the walking belt slip, while the motor and rollers continue to turn? If the walking belt is slipping then the motor belt needs to be tightened. If the walking belt slows with your weight on it, does this happen at 1-3 mph and still occur at 4-5 mph? It could be your body weight causing it to slowdown, try to increase the speed to 4 or 5 and see if it still happens. If so, is the treadmill rated for your body weight? Please be more specific.
Feb 08, 2011 | Exercise & Fitness
Elevation has gone too high. foot rollers are hitting front plate
Apr 30, 2009 | Precor EFX 546i Elliptical Version 4
Apr 27, 2009 | Precor C956i Treadmills with HR /...
Exercise & Fitness Logo
16 people viewed this question
Top Precor Exercise & Fitness Experts
Sportsmith LLC
Sportsmith LLC
Howard
Howard
Ross Metcalfe
Ross Metcalfe
Are you a Precor Exercise and Fitnes Expert? Answer questions, earn points and help others
