Question about Just Wireless Bluetooth Headset Wireless Headset
Will not let me connect the blue tooth to my phone
I just bought a Just Wireless Blue Tooth BT-35K2 I tried seting it up and pairing it up and will not connect. WHat is the problem with it?
  • paulmere May 06, 2009
    I can not pair my BT-35K2 headset to my Nokia phone.
Ur just a ********..haha nah jk
i got the same problem. help...
Posted on Jul 12, 2009
Need operating instructions for Jabra BT 2080 headset
ok i hope that you are trying to connect the bt device to a phone or game system or computer,the first thing you need to do is turn the power on to what you are connecting the blue tooth device to.your phone computer or game system,next you will have to put your blue tooth device into discovery mode,now most manufactures of blue tooth devices use the power button for this feature,when you turn the power on to your device keep holding down the power button for 6 to 10 seconds this will put your device into discovery mode,usually a light will remain on,then you can search or add new device from what it is you are connecting to,it will ask you for a pin or pairing code,now most manufactures of blue tooth devices use a factory 4 digit pin pairing code,they are as follows,0000,1234,9999,or 1111 enter the code and your device should pair and work with what it is you are pairring it to .i hope this helps
Feb 26, 2011 | Jabra BT2080 Bluetooth Headset
How you play music on jabara bt 2050 0n phone
first you have to pair your blue tooth device to your phone,first you turn the bt power to on on your phone menu,next you have to put your blue tooth device headphones into discovery mode,now most bt manufactures use the power button for this feature,by holding the power button down for 6 to 10 seconds when you turn the bt device on it usually puts the bt intodiscovery mode.a solid light usually remains on on your blue tooth device,then you can search or add new device from your phone menu.once they have paired or recognized you will need a pin pairing code.Most manufactures of blue tooth devices use a factory 4 digit pin pairing code ,they are as follows0000,1234,9999,or1111 i hope this helps
Feb 25, 2011 | Samsung Radio Communications
Can't remember how to pair my LG HBM-710 to my new phone - Samsung Fascinate. Can you help?
to pair a blue tooth device to a phone first you must turn the bt power on the phone to on,then you have to put your blue tooth device into discovery mode,now most manufactures use the power button for thisw feature.By holding down the power button on your device when turning it on for 6 to 10 seconds it usually puts the device into discovery mode.there should be a light that stays on on your blue tooth device.once you have the bt device into discovery mode you will be able to pair the device to your phone by search or add new device,once it pairs it will ask for a pin or pairing code.most manufactures of blue tooth devices use a 4 digit factory pin pairing code they aare as follows 0000,1234,9999,or 1111 once youve put tjhe pin code on they will pair ,i hope this helps
Feb 25, 2011 | LG HBM-710 Wireless Headset
How to put a hbh705 into pairing mode
It all depends. When you want to connect a blue tooth to a phone, You will need to switch on the blue tooth device and the phones blue tooth you are pairing with.
When pairing both device, you will ask for pairing code, You four digit numbers(default code(0000). and pair.
After pairing both device, you detected paired, you can now use the blue tooth device with your phone.
there are no special code for pairing Blue tooth device.
Normal codes used are any four digit, four numbers you want to use.(0000, 1234).
Take care.
Aug 06, 2010 | Sony Bluetooth Headst HBH705 Sandcolor...
I have the just wireless blue bt-35k2 headset and it stopped being recognized by my phone. When I tried to add it back I need a pass key and I can't find my manual.
To put the bt-35k2 headset in pairing mode, press the ON button but hold it down for about 6 seconds. Once detected, you'll be prompted for passkey; then use 0000. Pairing will complete once authenticated.
Mar 24, 2010 | Just Wireless Bluetooth Headset Wireless...
Does explorer 230 pair with nokia 2600
the explorer 230 blue tooth can be paired with the Nokia phone if only the blue tooth tooth device is a universal blue tooth.
Universal blue tooth can work with any phone no matter the model.So check the blue tooth if it is a universal blue tooth, try it with the phone and see if it will work.
Have a nice day
Mar 16, 2010 | Plantronics Explorer 220 Bluetooth Headset...
I cant get my blue tooth to connect to my blackberry
MAKE SURE THE BLUE TOOTH HANDS FREE OR ANY OTHER DEVICE IS IN PAIRING MODE. ( THE PIN TO PAIR A BT HANDSFREE LL BE 0000 )
ALSO FOR INCOMING BT BEEP RECEVING
FROM MEDIA. CLICK MENU AND SELECT. RECEIVE VIA BLUE TOOTH.
Feb 24, 2010 | Cell Phones
Pair to a sony ericsson w760a to a just wireless bt-35k2 bluetooth wireless head set
Put your device in search mode.
Put the bt-35k2 headset in pairing mode.
(Press the ON button but hold it down for about 6 seconds. As I recall, it will flash intermittent blue and red; either way, you will certainly see flash sequence that is not normal "blue" mode.)
Once device detects headset, you'll be prompted for passkey; enter 0000. Pairing will complete once authenticated.
Dec 26, 2009 | Just Wireless Bluetooth Headset Wireless...
Can I pair my Wireless Blue BT-35K2 with my 3.0 iTouch?
Give this a try:
1. Put your device in search mode.
2. Put the bt-35k2 headset in pairing mode (press the ON button but hold it down for about 6 seconds. As I recall, it will flash intermittent blue and red; either way, you will certainly see flash sequence that is not normal "blue" mode.)
3. Once device detects headset, you'll be prompted for passkey; enter 0000.
Nov 18, 2009 | Apple Premium Skin Case for iTouch 2nd...
Problems pairing my Just Wireless Blue BT-35K2
If you can get the headset into pairing mode, and your phone into detection mode and it's still not pairing, try removing the battery while powered on. Replace the battery and retry, and it should work.
Jun 26, 2009 | Cell Phones
Just Wireless Bluetooth Headset Wireless Headset Logo
640 people viewed this question
Top Just Wireless Radio Communications Experts
Rocketmanusa
Level 1 Expert
robert
Are you a Just Wireless Radio Communication Expert? Answer questions, earn points and help others
